Java Runtime Environment: as per recommendation for OH3
openHAB version: OH3 latest release
Issue of the topic:
I tried to change the background image of the automatically generated “Location” tab tiles as well as tried the rearrange button, whereas both leads to an error: “Error while saving page: Server Error”.
I cannot find anything in the usual OH logs on said error.
Any direction on how to solve this? Might it be a permission issue (whereas I did a normal apt install)?
For me - strangely - if I restart OH3, edit a page (any page) and save it then, it works once - then if I try to save again (even without changing anything) I get the server error.
login to your server with ssh
run openhab-cli console
set loglevel to debug: log:set DEBUG org.openhab
watch the log: log:tail org.openhab
try to save again and you should see a stack trace in the tail maybe with better error information.
Thanks!
That helped a lot as I was able to pin point the error.
If someone has maybe a similar issue, for me it was coming from having another Page UID called “home”.
It seems that the auto-generated Location page also uses this UID (?).
java.lang.IllegalArgumentException: Cannot add UI component to namespace ui:page, because a component with same UID (home) already exists.
Thanks from me, too - similar issue, there was apparently an old leftover page in the /jsondb/backup folder which caused the problem.
in my case:
08:46:36.563 [DEBUG] [.io.rest.JSONResponse$ExceptionMapper] - Exception during REST handling.
java.lang.NumberFormatException: For input string: “._1609411310964”
That input string was the pre-fix for the corrupted backup file.
don’t forget to set the log level back to info or your log will grow fast: log:set INFO org.openhab
I had the similar issue withe the ‘home’ but i can’t reproduce it. The ‘home’ Page seems to be the second default page. I think it appears if you modify the default generated location, things or equipment section.
When i select the site for edeting over ‘page’ from settings menu the error went away. There are now two sites, layout and home.
But can confirm, I got now a “page” in the list with UID “home” as well, which was not there before.
And before I had my own page with UID “home” design, hence I guess the conflict.
I tried to find in community and found out only this topic is looks like for my issue.
I have OH3 and migrated to it from OH2.
I created a simple model in Modeling but when I open “home” page or it is called “overview” page there is nothing on it, just blank page.
In that time I opened it in “Run Mode” and it shows me what i need. The same situation with Semantic Model and auto generated “home” page. In Run Mode all is fine but I see blank pages (not active) Locations, Equipment, Properties in default page on http://myopenhabserver:8080
