My current setup:
OH 3.1.0-SNAPSHOT (build #2127)
Oracle java version “11.0.9” 2020-10-20 LTS
macOS Mojave 10.14.6
I’m facing some issues with basicui on my iPhone iOS 14.3.
To control my heat pump I setup some buttons to switch between modes Auto, Party, Ferien, Aus.
My test sitemap:
sitemap test label=“Mini Casa” {
Frame label=“Licht Erdgeschoss” {
Switch item=Licht_Kuechenschrank
Switch item=Hue_Esstisch
Frame label=“Heating” {
Text item=Heat_Mode
Text item=Heat_Stat
Text item=Water_Stat
Switch item=Heat_Prog icon=“temperature” label=“Heizung” mappings=[“0”=“Auto”,“2”=“Party”,“3”=“Ferien”,“4”=“Aus”]
Switch item=Water_Prog icon=“temperature” label=“Brauchwasser” mappings=[“0”=“Auto”,“2”=“Party”,“3”=“Ferien”,“4”=“Aus”]
Setpoint item=Heat_HkTemp label=“Heizkurve Abweichung [%.1f °C]” step=0.5 minValue=-5 maxValue=5
Text item=Heat_HkAbweichung label=“Heizkurve Abweichung [%.1f °C]”
Setpoint item=Water_Temp label=“Warmwasser [%.1f °C]” step=0.5 minValue=30 maxValue=50
My problem is that the button doesn’t respond on single click/tap. I’ve to click the buttons 2-3 times before I can switch between heating modes. Seems to be that some tweak / css is required? Does anybody have an idea?
anybody got a clue what’s going wrong here? Is this a html/css bug?!?
I tested again. Safari on MacOS is working fine…the buttons also change asap on my iPhone but using the web ui on my iPhone I’ve to click two times on the button.
