[INFO] BUILD FAILURE
[INFO] ------------------------------------------------------------------------
[INFO] Total time: 18.098 s
[INFO] Finished at: 2020-12-28T19:22:26+01:00
[INFO] Final Memory: 70M/250M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-jar-plugin:3.0.2:jar (default-jar) on project org.openhab.binding.carnet: Error assembling JAR: Manifest file: /Users/markus/Dev/openhab-3/git/openhab-addons/bundles/org.openhab.binding.carnet/target/classes/META-INF/MANIFEST.MF does not exist. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
Usually I just need to re-run “mvn clean install” and it’s gone.
Any idea?
Do you use eclipse? In which case I suspect eclipse auto build fights with maven where eclipse detects changes during maven build and starts also doing stuff. For that reason I sometimes disable auto build in eclipse when running a maven build (only to forget about it and wondering why eclipse doesn’t give errors on typos )
Yes I do, sounds like a reasonable reasons. I never had this with OH2 build environment, but it looks that the build process for OH3 is more complex = needs more time.
I’ll have an eye on it and let you know if that also happens when Eclipse is closed.
