Running 3.0M5, I’m migrating my rules and keep seeing error messages
Cannot create a duplicate value 'newState'
in some of my rules.
It’s no generalized error but apparently it happens whenever I sendCommand()
or postUpdate()
to an ‘expire’ type of item and I believe (not sure) only when I update it to prolongue the timer (i.e. not on timer creation on first access).
Here’s the item the rule chokes upon, it was defined in OH2 as below. I imported that definition into the OH3 GUI.
Switch filename_Nachlauf { expire="30m,command=OFF" }
Anyone an idea ? Sorry for the ‘dev’ category but I 'd think as expire was a very recent addition this is probably more suitable.
BTW @Kai could you please create a ‘migration’ or ‘OH3’ category either in development or in Setup/… ?
All users to migrate (like me) run into errors of some sort related to the difference of OH2 vs OH3 and don’t know where to post them is most appropriate.
thanks
2020-12-07 17:13:42.178 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'filename-4': Fail to execute action: script
2020-12-07 17:13:42.179 [DEBUG] [e.automation.internal.RuleEngineImpl] - The trigger '0' of rule 'filename-4' is triggered.
java.lang.RuntimeException: Fail to execute action: script
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1187) ~[bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:987) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:90) [bundleFile:?]
Caused by: java.lang.IllegalStateException: Cannot create a duplicate value 'newState'.
at org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext.newValue(DefaultEvaluationContext.java:46) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.createEvaluationContext(DSLScriptEngine.java:149) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:124) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) ~[bundleFile:?]
