I’m getting from MQTT a valid JSON string. If I store this value in a string item, OH changes every : to a =. The problem now is that i cannot use the JSONPATH transformer to get out a the needed value.
For example: I am getting {“barometric_pressure_1”:974,“relative_humidity_1”:44,“temperature_1”:20} from MQTT and store it in a string item linked to my MQTT Channel. But now the shown value of the item is {barometric_pressure_1=974, relative_humidity_1=36, temperature_1=23} and I want to get the temperature value with JSONPATH but that doesn’t work obviously.
May we see your config? Will you show your events.log for a change to your Item?
A generic MQTT Thing suppots multiple channels, each of which can extract a different bit of JSON from the same payload, and update multiple Items of different types.
