@boehan
Dear Hans
over the last days I noticed something strange and I don’t know where it exactly comes from. So let’s start.
- OH 3.1.0.M4 - Milestone Build
I have two rules which control the speed of the Airing. Which both are working fine.
Some days ago I implemented another rule that check twice per day the difference between filter runtime and maximum duration. And sends it out as a mail containing
Filterlaufzeit: 2856 aktuell 2401.0, verbleibend 455.0 Stunden.
While the control rules due theire job. At some point to notice rule still gets executed but the value of
comfoair:comfoair:64509ff4:times#filterHours stays the same.
excerpt from event.log:
2021-06-16 12:15:22.301 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2381 h to 2382 h
2021-06-16 13:15:22.187 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2382 h to 2383 h
2021-06-16 14:14:22.572 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2383 h to 2384 h
2021-06-16 15:13:23.656 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2384 h to 2385 h
2021-06-16 16:13:22.832 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2385 h to 2386 h
2021-06-16 17:12:22.809 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2386 h to 2387 h
2021-06-16 18:12:22.886 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2387 h to 2388 h
2021-06-17 07:03:26.200 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2388 h to 2389 h
2021-06-17 08:02:24.976 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2389 h to 2390 h
2021-06-17 09:02:28.461 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2390 h to 2391 h
2021-06-17 10:01:25.043 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2391 h to 2392 h
2021-06-17 11:00:25.817 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2392 h to 2393 h
2021-06-17 12:00:25.997 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2393 h to 2394 h
2021-06-17 12:59:25.979 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2394 h to 2395 h
2021-06-17 13:58:25.558 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2395 h to 2396 h
2021-06-17 14:58:25.434 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2396 h to 2397 h
2021-06-17 15:57:26.313 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2397 h to 2398 h
2021-06-17 16:57:26.589 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2398 h to 2399 h
2021-06-17 17:56:25.263 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2399 h to 2400 h
2021-06-17 18:55:27.950 [vent.ItemStateChangedEvent] - Item 'AiringFilterRun' changed from 2400 h to 2401 h
As you can see from this, it was last updated yesterday in the evening. The value corresponds with the value that I received tonight (2021-06-18) at 18:00
Also other items where stopped to be updated and only the commandItems seem to continue to work.
Kind regards
Stefan
