Java Runtime Environment: _which java platform is used and what version_default installation
openHAB version:latest stable
Issue of the topic: how to recalcutae data in report
Hooe to be clear…
i have some Shelly in my home and monitor power consumtion.
I successfully create location, equipment and point and i can see realtime power consumtion in watt.
also i can switch in detail with graphs and aggregate valute for day and see for every hour total watt .
Now i would like to have not total Watt but in kWh and this can be do by this function: totalwatt / 60 (minute in an hour) / 1000 ( watt for 1Kw)
result is correctly my kWh consum in that hour and is the same reported by native shelly cloud.
How i can change for aggregation graph this formula or is possible to have a new option like custom forumla?
are there any other way to have this grafics?
thanks
and if you aggregate using average aggregation for every hour you have the average of watt consumption for every hour.
for 8 for exaample you have an average of 2,532.127 Watts if you divide per 1000 you have 2.532kWh
