Hello, I get that error when using cron with “SAT-SUN”:
[ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.core.automation.internal.RuleEngineImpl$2@6c650a" about the "ADDED" event: Value too high in range in cron expression '0 0 5 ? * SAT-SUN *' in field 'DayOfWeek': value 8, minimum: 7
But then it should be fixed in the allready distributed version??
I am using openHAB 3.0.0-1 (Release Build)
and I get this error. Or am I using the wrong OH3 version?
