me again. I am trying to create a “widget” which can be used in widgets later on. Hopefully this can be achieved.
The control I am trying to create is a button with a count down. This will be used for irrigation purposes.
At least I could achieve this with habpanel in V2.5.
I’d like to define 2 items:
- itemButtonToTurnOnIrrigationValve
- virtualItemToSaveIrrigationDuration
- virtualItemWithRemainingDuration
Basic layout:
PowerImage
[HiddenDurationTillOff]
Label
When I push the widget, then the power image should switch to green, the rule in the background creates 2 timers and sets the virtualItemWithRemainingDuration to virtualItemToSaveIrrigationDuration.
1st timer will run every minute reducing the virtualItemWithRemainingDuration by 1 minute
2nd timer will run after virtualItemToSaveIrrigationDuration time and turns off the 1st timer and turn the button item off.
=> This I can achieve by myself.
What I never ever will get to work - I am realizing that I will never ever be a designer - is the layout.
I started with f7-col, f7-row(button), f7-row(LabelDuration), f7-row(LabelButton)
Either I can not align the contents or even have a “nice” spacing between rows (or cols later on for vertical vs horizontal layout).
uid: widget_irrigation
tags: []
props:
parameters:
- context: item
description: An item to control
label: itemFrontWater1
required: false
type: TEXT
- context: item
label: itemFrontWater2
required: false
type: TEXT
- context: item
label: itemFrontWater3
required: false
type: TEXT
parameterGroups: []
timestamp: Jun 3, 2021, 7:09:38 PM
component: f7-card
slots:
default:
- component: f7-col
slots:
default:
- component: f7-row
class:
- justify-content-center
- text-align-center
slots:
default:
- component: oh-button
actionItem: =props.itemFrontWater1
iconF7: power
large: true
- component: f7-row
slots:
class:
- text-align-center
default:
- component: Label
class:
- text-align-center
text: 5
- component: f7-row
slots:
class:
- text-align-center
default:
- component: Label
class:
- text-align-center
text: 5
