I’m looking for a way to compare a DateTime item with the current date.
So I tried:
var ago10secs = new Date(date.getTime() - diff*10000)
var lastAction = new Date(items["LastActionTime"].getTime());
I’d like to create:
the JS-date from 10seconds ago
the JS-date from my DateTime item
so, I can compare them.
I get this in the logs:
2021-01-02 23:15:53.043 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'lastAction' failed: ReferenceError: "date" is not defined in <eval> at line number 3
I’m looking across and I mostly find either some DSL-rules examples or some information, which seems odd or outdated. Thanks for your help!
While looking for an example i have found out that i have somt Date variables still working which makes me wonder…
Anyway i would suggest too use Zoneddatetime, since it has replaced jodatime everywhere.
Here is some sample example code (not tested, except for the Java Type)
// Get the Java Type into ECMA Script
var ZonedDateTime = Java.type("java.time.ZonedDateTime");
// Do some cool time stuff here
var ago10secs = ZonedDateTime.now().minusSeconds(5)
This maybe could also still work with Date
About the lastAction:
I think you have a typo in there. Try:
var lastAction = new Date(items["LastActionTime"]).getTime();
var zdt = Java.type(‘java.time.ZonedDateTime’);
var mytime = zdt.now().toLocalDateTime();
events.postUpdate(“Spuelmaschine_OpStateLastChange”, mytime);
Ok, one step for, and two steps back…
I work on the following rule and don’t get it to work (apart from the message format). The problem is the time calculation:
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.model.script.Rules.Experiments");
var telegramAction = actions.get("telegram","telegram:telegramBot:49b7f025cb");
var duration = Java.type('java.time.Duration');
var zdt = Java.type('java.time.ZonedDateTime');
var jetzt = zdt.now().toLocalDateTime();
MODE_OFF = 0
MODE_STANDBY = 3
MODE_ACTIVE = 2
MODE_FINISHED = 1
logger.info("Spuelmaschine State changed");
if (itemRegistry.getItem('Spuelmaschine_OpState').getState() == MODE_FINISHED) {
//Aktualisierung Counter
var counter = itemRegistry.getItem('Spuelmaschine_counter').getState() //der counter zählt ab 01.05.2019
counter = counter + 1
events.postUpdate("Spuelmaschine_counter", counter);
//Berechnung der Laufzeit
var lastAction = itemRegistry.getItem('Spuelmaschine_OpStateLastChange').getState();
var differenz = (jetzt - lastAction);
var differenz = duration.between(jetzt, lastAction);
var laufzeitminuten = Math.round(differenz.getSeconds()/60);
/* var report = "Status: 1 (Fertig)\n" +
"Start: " + lastAction.toDateTime.toString(dd-MM-yy HH:mm) + "Uhr \n" +
"Ende: " + jetzt.toDateTime.toString(dd-MM-yy HH:mm) + "Uhr \n" +
"Laufzeit: "+ laufzeitminuten + " Min.";
var message = "Spülmaschine fertig:\n\n" + report
//sende Nachricht
telegramAction.sendTelegram(message); */
else if (itemRegistry.getItem('Spuelmaschine_OpState').getState() == MODE_ACTIVE) {
telegramAction.sendTelegram("Spülmaschine wurde gestartet!")
// remember last change
events.postUpdate("Spuelmaschine_OpStateLastChange", jetzt)
