Just upgraded to OH3 running as docker image on my NAS. Seems to run fine w/o major issues
Nevertheless a tremendous number of processes/threads (> 200!) are launched on my nas:
Most of them are karaf processes, here is the detailed call:
openhab 31893 66.6 6.9 8326924 1137064 ? Sl 17:50 9:03 /usr/lib/jvm/default-jvm/bin/java -XX:-UsePerfData -Dopenhab.home=/openhab -Dopenhab.conf=/openhab/conf -Dopenhab.runtime=/openhab/runtime -Dopenhab.userdata=/openhab/userdata -Dopenhab.logdir=/openhab/userdata/logs -Dfelix.cm.dir=/openhab/userdata/config -Djava.library.path=/openhab/userdata/tmp/lib -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dnashorn.args=–no-deprecation-warning -Dorg.apache.cxf.osgi.http.transport.disable=true -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Dfile.encoding=UTF-8 -XX:+UseG1GC -Dlog4j2.formatMsgNoLookups=true --add-reads=java.xml=java.logging --add-exports=java.base/org.apache.karaf.specs.locator=java.xml,ALL-UNNAMED --patch-module java.base=/openhab/runtime/lib/endorsed/org.apache.karaf.specs.locator-4.3.4.jar --patch-module java.xml=/openhab/runtime/lib/endorsed/org.apache.karaf.specs.java.xml-4.3.4.jar --add-opens java.base/java.security=ALL-UNNAMED --add-opens java.base/java.net=ALL-UNNAMED --add-opens java.base/java.lang=ALL-UNNAMED --add-opens java.base/java.util=ALL-UNNAMED --add-opens java.naming/javax.naming.spi=ALL-UNNAMED --add-opens java.rmi/sun.rmi.transport.tcp=ALL-UNNAMED --add-opens java.base/java.io=ALL-UNNAMED --add-opens java.base/java.lang.reflect=ALL-UNNAMED --add-opens java.base/java.text=ALL-UNNAMED --add-opens java.base/java.time=ALL-UNNAMED --add-opens java.desktop/java.awt.font=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.file=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.ftp=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.http=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.https=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.jar=ALL-UNNAMED --add-exports=java.base/sun.net.www.content.text=ALL-UNNAMED --add-exports=jdk.xml.dom/org.w3c.dom.html=ALL-UNNAMED --add-exports=jdk.naming.rmi/com.sun.jndi.url.rmi=ALL-UNNAMED --add-exports=java.rmi/sun.rmi.registry=ALL-UNNAMED --add-exports=java.security.sasl/com.sun.security.sasl=ALL-UNNAMED -Dkaraf.instances=/openhab/userdata/tmp/instances -Dkaraf.home=/openhab/runtime -Dkaraf.base=/openhab/userdata -Dkaraf.data=/openhab/userdata -Dkaraf.etc=/openhab/userdata/etc -Dkaraf.log=/openhab/userdata/logs -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/openhab/userdata/tmp -Djava.util.logging.config.file=/openhab/userdata/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /openhab/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.3.4.jar:/openhab/runtime/lib/boot/org.apache.karaf.jaas.boot-4.3.4.jar:/openhab/runtime/lib/boot/org.apache.karaf.main-4.3.4.jar:/openhab/runtime/lib/boot/org.apache.karaf.specs.activator-4.3.4.jar:/openhab/runtime/lib/boot/osgi.core-7.0.0.jar:/openhab/runtime/lib/jdk9plus/istack-commons-runtime-3.0.10.jar:/openhab/runtime/lib/jdk9plus/jakarta.xml.bind-api-2.3.3.jar:/openhab/runtime/lib/jdk9plus/javax.annotation-api-1.3.2.jar:/openhab/runtime/lib/jdk9plus/jaxb-runtime-2.3.3.jar:/openhab/runtime/lib/jdk9plus/org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:/openhab/runtime/lib/jdk9plus/txw2-2.3.3.jar org.apache.karaf.main.Main
Tested with 3.2.0 and 3.2.0M1.
Is this amount of processes normal or do I miss something? Thank you.
