I have an instance of Openhab 3.1 and a Doorbird running on the same network. I succesfully connected the Doorbird via the Doorbird Binding to Openhab (Doorbird - Bindings | openHAB).
When I now press the Doorbell Button, I can also see the following entry in the event.log file:
2021-10-06 14:29:39.546 [INFO ] [openhab.event.ChannelTriggeredEvent ] - doorbird:d210x:doorbell:doorbell triggered PRESSED
The problem which I am currently facing is that the folowing rule which shall ring the bell is not triggered (it is more ore less what is documented on the binding page linked above)
rule "Doorbell Button Pressed"
Channel "doorbird:d210x:doorbell:doorbell" triggered PRESSED
I_EG_FLUR_G001.sendCommand(ON)
Do you have an idea what could be wrong ?
Thanks for your support!
