I’m kind of stumbled and need some guidance/suggestion re problem I encountered.
I help to migrate medium sized (1000+ items) OH setup, from 2.5 to 3.3. Setup is using both KNX (mainly) and zwave (only 40 nodes). Upon migration, zwave most of the time works, however I’m constantly observing strange patterns (logs and details below) of errors regarding zwave things & items:
- zwave binding reports every days multiple “UFO” nodes with different ids
- there is repeatedly pattern of repeated (10…20) withing 1 second of ‘received command’ with ‘predicted to became’ log entries for the very same zwave connected item
- I’m seeing dozen (sic!) times a day situations, when value of some meter on a specific zwave device, jumps to different value and then within 1s, returns to the previous value.
All three things, looks for me like some kind of garbled content of zwave messages, or some error in higher (radio? binding?) layer, however I thought that securitykey and checksums are protecting from such messages reaching even zwave binding.
I did restart openhab. Did also clean cache/ & tmp/
Did not reboot hardware (rpi3b + aeotec stick on usb)
hardware is the same (2.5 and 3.3), all locations etc, not changed, added 2 new zwave devices during migration, while removed one. all this cases (1,2,3), happen multiple times every day, starting from the day of migration from 2.5 to 3.3. NB, a lot of zwave messages are passed to OH properly and correctly, maybe 2% result in such cases as 1,2,3 i’m looking to solve.
Suggestions highly welcome
example of 1:
2022-10-19 17:10:48.802 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 25: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:52.555 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:52.644 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:52.657 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:52.841 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.245 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.355 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.439 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.511 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.542 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.555 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.636 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:30:53.694 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 139: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:48.637 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.054 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.084 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.244 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.351 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.550 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.601 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.687 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.699 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.767 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:49.965 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:50:50.107 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 26: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:51:34.959 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 136: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:51:35.178 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 136: Not initialized (ie node unknown), ignoring message.
2022-10-19 17:51:35.192 [WARN ] [ng.zwave.internal.protocol.ZWaveTransactionManager] NODE 136: Not initialized (ie node unknown), ignoring message.
example of case 2:
2022-10-19 18:41:31.350 Item 'zwaHACKsensorUniMotion' changed from ON to OFF
2022-10-19 18:44:52.450 Item 'zwaHACKsensorUniMotion' changed from OFF to ON (this action causes ONE invocation of rule to be send to enable zwaHACKpowerpDesklamp)
2022-10-19 18:44:52.465 Item 'zwaHACKpowerpDesklamp' received command ON
2022-10-19 18:44:52.467 Item 'zwaHACKpowerpDesklamp' predicted to become ON
2022-10-19 18:44:52.520 Item 'zwaHACKpowerpDesklamp' received command ON
2022-10-19 18:44:52.522 Item 'zwaHACKpowerpDesklamp' predicted to become ON
2022-10-19 18:44:52.541 Item 'zwaHACKpowerpDesklamp' received command ON
2022-10-19 18:44:52.542 Item 'zwaHACKpowerpDesklamp' predicted to become ON
2022-10-19 18:44:52.574 Item 'zwaHACKpowerpDesklamp' received command ON
2022-10-19 18:44:52.575 Item 'zwaHACKpowerpDesklamp' predicted to become ON
2022-10-19 18:44:52.623 Item 'zwaHACKpowerpDesklamp' received command ON
2022-10-19 18:44:52.624 Item 'zwaHACKpowerpDesklamp' predicted to become ON
2022-10-19 18:44:52.665 Item 'zwaHACKpowerpDesklamp' received command ON
2022-10-19 18:44:52.667 Item 'zwaHACKpowerpDesklamp' predicted to become ON
2022-10-19 18:44:52.709 Item 'zwaHACKpowerpDesklamp' received command ON
2022-10-19 18:44:52.711 Item 'zwaHACKpowerpDesklamp' predicted to become ON
example of case 3:
2022-10-19 15:48:27.446 Item 'zwaLIBRlidimmReadinglampEnergy' changed from 3.53 to 240.838
2022-10-19 15:48:38.010 Item 'zwaLIBRlidimmReadinglampEnergy' changed from 240.838 to 3.53
