Just tried an update from 2.5.11 to 3 on Ubuntu 20.10. Based on the topic 'Guide: OH3 using APT". I’ve also purged all old stuff. At first sight, everything went fine. Update went without issues, openhab is started.
Openhab.log is giving updates as usual.
But events.log stay empty?
I downloaded the deb-package seperately, and restored the files in /var/lib/openhab/etc/*, but after restarting openhab, it stays empty.
My items seem to be working (knx, zwave nodes are acting as expected). But my rules aren’t reacting as well. But guess this is something else. First thing to get in order are the logs to debug…
Some info:
/var/log/openhab/
-rw-r--r-- 1 openhab openhab 0 Dec 23 15:44 events.log
-rw-r--r-- 1 openhab openhab 32024 Dec 23 16:17 openhab.log
bundle:list
START LEVEL 100 , List Threshold: 50
ID │ State │ Lvl │ Version │ Name
22 │ Active │ 80 │ 2.10.3 │ Jackson-annotations
23 │ Active │ 80 │ 2.10.3 │ Jackson-core
24 │ Active │ 80 │ 2.10.3 │ jackson-databind
25 │ Active │ 80 │ 2.10.3 │ Jackson-dataformat-YAML
26 │ Active │ 80 │ 2.10.3 │ Jackson datatype: JSR310
27 │ Active │ 80 │ 2.8.2.v20180104-1110 │ Gson: Google Json Library for Java
28 │ Active │ 80 │ 27.1.0.jre │ Guava: Google Core Libraries for Java
29 │ Active │ 80 │ 1.0.1 │ Guava InternalFutureFailureAccess and InternalFutures
30 │ Active │ 80 │ 3.0.0.v201312141243 │ Google Guice (No AOP)
31 │ Active │ 80 │ 4.8.35.v20190528-1517 │ ClassGraph
32 │ Active │ 80 │ 2.1.0 │ swagger-annotations
33 │ Active │ 80 │ 2.1.0 │ swagger-core
34 │ Active │ 80 │ 2.1.0 │ swagger-integration
35 │ Active │ 80 │ 2.1.0 │ swagger-jaxrs2
36 │ Active │ 80 │ 2.1.0 │ swagger-models
38 │ Active │ 80 │ 3.5.6 │ JmDNS
39 │ Active │ 80 │ 1.0.0 │ Units of Measurement API
41 │ Active │ 80 │ 1.1.0.Final │ Bean Validation API
43 │ Active │ 80 │ 0.5.10 │ Jollyday
44 │ Active │ 80 │ 3.2.0.v201101311130 │ ANTLR Runtime
45 │ Active │ 80 │ 1.0.1 │ Apache Aries JAX-RS Specification API
46 │ Active │ 80 │ 1.0.9 │ Apache Aries JAX-RS Whiteboard
48 │ Active │ 80 │ 3.11.0 │ Apache Commons Lang
57 │ Active │ 80 │ 4.2.7 │ Apache Karaf :: OSGi Services :: Event
68 │ Active │ 80 │ 1.0.0.2 │ Apache ServiceMix :: Bundles :: javax.inject
72 │ Active │ 80 │ 1.3.0.1 │ Apache ServiceMix :: Specs :: Annotation API 1.3
73 │ Active │ 80 │ 2.3.0.3 │ Apache ServiceMix :: Specs :: JAXWS API 2.3
76 │ Active │ 80 │ 4.14.0 │ Apache XBean OSGI Bundle Utilities
77 │ Active │ 80 │ 4.14.0 │ Apache XBean :: Classpath Resource Finder
78 │ Active │ 80 │ 0.7.0 │ jose4j
79 │ Active │ 80 │ 2.17.0.v20190920-0401 │ EMF Common
80 │ Active │ 80 │ 2.20.0.v20190920-0401 │ EMF Ecore
81 │ Active │ 80 │ 2.14.0.v20190528-0725 │ EMF Change Model
82 │ Active │ 80 │ 2.16.0.v20190528-0725 │ EMF XML/XMI Persistence
83 │ Active │ 80 │ 3.10.400.v20190516-1504 │ Common Eclipse Runtime
112 │ Active │ 80 │ 0.9.0.v20200229-1009 │ org.eclipse.lsp4j
113 │ Active │ 80 │ 0.9.0.v20200229-1009 │ org.eclipse.lsp4j.jsonrpc
114 │ Active │ 80 │ 2.23.0.v20200831-0723 │ Xtend Runtime Library
115 │ Active │ 80 │ 2.23.0.v20200831-0723 │ Xtend Macro Interfaces
116 │ Active │ 80 │ 2.23.0.v20200831-0730 │ Xtext
117 │ Active │ 80 │ 2.23.0.v20200831-0745 │ Xtext Common Types
118 │ Active │ 80 │ 2.23.0.v20200831-0730 │ Xtext IDE Core
119 │ Active │ 80 │ 2.23.0.v20200831-0730 │ Xtext Utility
120 │ Active │ 80 │ 2.23.0.v20200831-0745 │ Xbase Model
121 │ Active │ 80 │ 2.23.0.v20200831-0745 │ Xbase Generic IDE Services
122 │ Active │ 80 │ 2.23.0.v20200831-0723 │ Xbase Runtime Library
124 │ Active │ 80 │ 7.1.0 │ org.objectweb.asm
126 │ Active │ 80 │ 7.1.0 │ org.objectweb.asm.commons
127 │ Active │ 80 │ 7.1.0 │ org.objectweb.asm.tree
128 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Core
129 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Audio
130 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: JAAS Authentication
131 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: OAuth2Client
132 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Automation
133 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Automation Media Modules
134 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Automation Script Modules
135 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Automation Script RuleSupport
136 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Automation REST API
137 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Binding XML
138 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration Core
139 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration Discovery
140 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration mDNS Discovery
141 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration Dispatcher
142 │ Active │ 75 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration XML
143 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Ephemeris
144 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: ID
145 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Console
146 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Console for OSGi runtime Karaf
147 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: HTTP Interface
148 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: HTTP Interface Authentication
150 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Monitor
151 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Network I/O
152 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: REST Interface
153 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Audio REST Interface
154 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Authentication Support for the REST Interface
155 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: REST Interface :: Core
156 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: REST mDNS Announcer
157 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Sitemap REST Interface
158 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: SSE Interface
159 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: REST Interface :: Swagger 1
160 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: UI REST Interface
161 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Voice REST Interface
162 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: mDNS Service
163 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Karaf Integration
164 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Core
165 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Items
166 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Item IDE
167 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Items Runtime
168 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Language Server
169 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Persistence
170 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Persistence IDE
171 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Persistence Runtime
172 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Rules
173 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Rule IDE
174 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Rules Runtime
175 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Script
176 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Script IDE
177 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Script Runtime
178 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Sitemap
179 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Sitemap IDE
180 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Sitemap Runtime
181 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Thing
182 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Thing IDE
183 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Model Thing Runtime
184 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Persistence
185 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Semantics
186 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: JSON Storage
187 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Thing
188 │ Active │ 75 │ 3.0.0 │ openHAB Core :: Bundles :: Thing XML
189 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Transformation Service
190 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: UI
191 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: UI Icon Support
192 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Voice
193 │ Active │ 80 │ 3.0.0 │ openHAB UI :: Bundles :: Main UI
200 │ Active │ 80 │ 1.0.0.201802012106 │ org.osgi:org.osgi.service.jaxrs
201 │ Active │ 80 │ 1.1.0.201802012106 │ org.osgi:org.osgi.util.function
202 │ Active │ 80 │ 1.1.0.201802012106 │ org.osgi:org.osgi.util.promise
203 │ Active │ 80 │ 1.5.0 │ ThreeTen-Extra
204 │ Active │ 80 │ 1.26.0 │ SnakeYAML
205 │ Active │ 80 │ 1.0.3 │ Units of Measurement Common Library
206 │ Active │ 80 │ 1.0.10 │ Units of Measurement Implementation for Java SE
207 │ Active │ 80 │ 1.4.13 │ XStream Core
208 │ Active │ 80 │ 2.20 │ Dagger
209 │ Active │ 80 │ 1.1.2 │ hivemq-mqtt-client
210 │ Active │ 80 │ 5.5.0 │ jna
211 │ Active │ 80 │ 5.5.0 │ jna-platform
212 │ Active │ 80 │ 1.6.2 │ JavaMail API
213 │ Active │ 80 │ 4.1.42.Final │ Netty/Buffer
214 │ Active │ 80 │ 4.1.42.Final │ Netty/Codec
215 │ Active │ 80 │ 4.1.42.Final │ Netty/Codec/HTTP
216 │ Active │ 80 │ 4.1.42.Final │ Netty/Common
217 │ Active │ 80 │ 4.1.42.Final │ Netty/Handler
218 │ Active │ 80 │ 4.1.42.Final │ Netty/Resolver
219 │ Active │ 80 │ 4.1.42.Final │ Netty/Transport
220 │ Active │ 80 │ 4.1.42.Final │ Netty/Transport/Native/Epoll
221 │ Active │ 80 │ 4.1.42.Final │ Netty/Transport/Native/Unix/Common
222 │ Active │ 80 │ 2.2.5 │ rxjava
223 │ Active │ 80 │ 1.0.0 │ IO.Socket Engine Client
224 │ Active │ 80 │ 1.0.0 │ IO.Socket Socket Client
225 │ Active │ 80 │ 20180813.0.0 │ JSON in Java
226 │ Active │ 80 │ 5.2.1 │ nrjavaserial
227 │ Active │ 80 │ 1.10.0 │ Apache Commons Codec
228 │ Active │ 80 │ 2.2.0 │ Commons IO
229 │ Active │ 80 │ 2.6 │ Commons Lang
230 │ Active │ 80 │ 3.6.0 │ Apache Commons Net
231 │ Active │ 80 │ 4.5.5 │ Apache Apache HttpClient OSGi bundle
232 │ Active │ 80 │ 4.4.9 │ Apache Apache HttpCore OSGi bundle
233 │ Active │ 80 │ 3.8.1.1 │ Apache ServiceMix :: Bundles :: okhttp
234 │ Active │ 80 │ 1.13.0.1 │ Apache ServiceMix :: Bundles :: okio
235 │ Active │ 80 │ 2.0.0 │ Californium (Cf) Core
236 │ Active │ 80 │ 2.0.0 │ Californium (Cf) Element Connector
237 │ Active │ 80 │ 2.0.0 │ Californium (Cf) OSGi
238 │ Active │ 80 │ 2.0.0 │ Scandium (Sc) Core
239 │ Active │ 80 │ 2.1.2 │ Java Concurrency Tools Core Library
240 │ Active │ 80 │ 2.5.2 │ JUPnP Library
241 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Astro Binding
242 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Bosch Indego Binding
243 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Chromecast Binding
244 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Denon / Marantz Binding
245 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: DMX Binding
246 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Doorbird Binding
247 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Exec Binding
248 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Gardena Binding
249 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: HTTP Binding
250 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: IpCamera Binding
251 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: KNX Binding
252 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: LG webOS Binding
253 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Mail Binding
254 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: MQTT Broker Binding
255 │ Active │ 81 │ 3.0.0 │ openHAB Add-ons :: Bundles :: MQTT Things and Channels
256 │ Active │ 82 │ 3.0.0 │ openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
257 │ Active │ 82 │ 3.0.0 │ openHAB Add-ons :: Bundles :: MQTT Homie Convention
258 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Netatmo Binding
259 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Network Binding
260 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: NTP Binding
261 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: OpenWeatherMap Binding
262 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Pushover Binding
263 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Seneye Binding
264 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: SNMP Binding
265 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: SolarEdge Binding
266 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Spotify Binding
267 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Systeminfo Binding
268 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: TRÅDFRI Binding
269 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: WiFiLED Binding
270 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: ZoneMinder Binding
271 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: ZWave Binding
272 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration UPnP Discovery
273 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration USB-Serial Discovery
274 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration USB-Serial Discovery for Linux using sysfs scanning
275 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Configuration Serial
276 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: MQTT Transport
277 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Serial Transport
278 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Serial Transport for RXTX
279 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: Serial Transport for RFC2217
280 │ Active │ 80 │ 3.0.0 │ openHAB Core :: Bundles :: UPnP Transport
281 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: IO :: openHAB Cloud Connector
282 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Persistence Service :: InfluxDB
283 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Persistence Service :: MapDB
284 │ Active │ 80 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Persistence Service :: RRD4j
285 │ Active │ 75 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: Exec
286 │ Active │ 75 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: JavaScript
287 │ Active │ 75 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: JSonPath
288 │ Active │ 75 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: Map
289 │ Active │ 75 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: RegEx
290 │ Active │ 75 │ 3.0.0 │ openHAB Add-ons :: Bundles :: Transformation Service :: Scale
291 │ Active │ 80 │ 3.0.0 │ openHAB UI :: Bundles :: Basic UI
292 │ Active │ 80 │ 3.0.0 │ openHAB UI :: Bundles :: HABPanel UI
293 │ Active │ 80 │ 3.0.0 │ openHAB UI :: Bundles :: Icon Set :: Classic
294 │ Active │ 80 │ 1.0.2 │ reactive-streams
Any idea where I should look?
ps this is a clone of my 2.5 machine. So no problem to startover.
