I can confirm that this helped!
After removing the json file, it goes on.
For the moment, the start level stops after 70? Not sure if it’s normal at this stage?
I’ve now some things to clean up. I was using the addons file, some extra ‘onofficial binding’. So several errors pop up. So I’ll first try to clean that up, and check if it goes better after this.
For me, there wasn’t a lot in the file.
Seems to be a kind of test rule that at one moment, I created?
Maybe once in the old paperUI for testing the option to create rules through GUI?
I can confirm that I don’t have anything like that in my normal rule-files.
"753d47ce-1b06-4462-978e-efdce7863ce2": {
"class": "org.openhab.core.automation.Rule",
"value": {
"triggers": [
"id": "1",
"label": "it is a fixed time of day",
"description": "Triggers at a specified time",
"configuration": {
"properties": {
"time": "18:00"
"type": "timer.TimeOfDayTrigger"
"conditions": [],
"actions": [
"id": "2",
"label": "send a command",
"description": "Sends a command to a specified item.",
"configuration": {
"properties": {
"itemName": "Light_WO_HalGang",
"command": "ON"
"type": "core.ItemCommandAction"
"configuration": {
"properties": {}
"configDescriptions": [],
"uid": "753d47ce-1b06-4462-978e-efdce7863ce2",
"name": "Test",
"tags": [],
"visibility": "VISIBLE"
FWIW I also had this problem ('events.log stays empty) today, and none of the above-mentioned proposals worked for me. However in /var/lib/openhab there was a file dump-2021-05-04_144455-606.zip` which was 35Mb in size! Unfortunately my zip app reported the file as invalid, so I could not see what was inside. So I just deleted the dump file (“only real men delete dump files”) and restarted; and miraculously the events.log is now working. Go figure…
