- Platform information:
- Hardware: Raspberry Pi 4 Model B Rev 1.1 details: BCM2711 rev: c03111
- Host: openhabian Kernel: 5.15.61-v7l+ armv7l bits: 32
- Distro: Raspbian GNU/Linux 11 (bullseye)
- OH Version: 3.3.0 (Build)
- Installation method: openhabian
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab | openhab:openhab
OPENHAB_CONF | /etc/openhab | openhab:openhab
OPENHAB_LOGDIR | /var/log/openhab | openhab:openhabian
OPENHAB_BACKUPS | /var/lib/openhab/backups | openhab:openhab
Fontail does not show latest log file entries.
Openhab is not writing these since last reboot.
Please note: I just restarted openhab which fixed the problem.
However, I am still curious as to why this happened.
# [2022-10-30 18:27] openhabian@openhabian /var/log $
sudo journalctl -u frontail
-- Journal begins at Sat 2022-06-04 23:39:30 AEST, ends at Sun 2022-10-30 18:27:33 AEST. --
Oct 25 08:28:10 openhabian systemd[1]: Started Frontail openHAB instance, reachable at http://openhabian:9001.
sudo systemctl status frontail.service
â—Ź frontail.service - Frontail openHAB instance, reachable at http://openhabian:9001
Loaded: loaded (/etc/systemd/system/frontail.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-10-25 08:28:10 AEST; 5 days ago
Docs: https://github.com/mthenw/frontail
Main PID: 748 (node)
Tasks: 12 (limit: 4915)
CPU: 1min 18.509s
CGroup: /system.slice/frontail.service
├─748 node /usr/lib/node_modules/frontail/bin/frontail --disable-usage-stats --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/preset/openhab_AEM.json --theme openhab_AEM --lines 2000>
└─946 tail -n 200 -F /var/log/openhab/openhab.log /var/log/openhab/events.log
The interesting bit is:
Yet only see entries up to Oct 15.
The file system shows me log files with time stamps from Oct 15.:
# [2022-10-30 18:29] openhabian@openhabian /var/log/openhab $
la
total 204K
drwxrwxr-x 1 openhab openhabian 4.0K Oct 25 08:24 ./
drwxr-xr-x 1 root root 4.0K Oct 30 00:00 ../
-rw-rw-r-- 1 openhab openhab 0 Jun 4 23:00 audit.log
-rw-r--r-- 1 openhab openhab 1.2K Oct 15 21:51 events.log
-rw-r--r-- 1 openhab openhab 152 Jun 5 13:44 events.log.1.gz
-rw-r--r-- 1 openhab openhab 792 Jun 7 07:35 events.log.2.gz
-rw-r--r-- 1 openhab openhab 1.1K Jun 7 08:31 events.log.3.gz
-rw-r--r-- 1 openhab openhab 11K Jul 23 22:34 events.log.4.gz
-rw-r--r-- 1 openhab openhab 14K Oct 15 21:46 events.log.5.gz
-rw-r--r-- 1 openhab openhab 1.4K Oct 15 21:51 openhab.log
-rw-r--r-- 1 openhab openhab 22K Jun 7 07:35 openhab.log.1.gz
-rw-r--r-- 1 openhab openhab 30K Jun 7 08:31 openhab.log.2.gz
-rw-r--r-- 1 openhab openhab 71K Jul 23 22:34 openhab.log.3.gz
-rw-r--r-- 1 openhab openhab 561 Jul 23 23:03 openhab.log.4.gz
-rw-r--r-- 1 openhab openhab 482 Jul 25 22:45 openhab.log.5.gz
-rw-r--r-- 1 openhab openhab 361 Jul 26 21:56 openhab.log.6.gz
-rw-r--r-- 1 openhab openhab 2.7K Oct 15 21:46 openhab.log.7.gz
-rwxr-xr-x 1 openhab openhab 0 Jun 27 16:19 Readme.txt*
I can’ make sense of this.
This happened after a reboot.
Anyway, I thought before I post, I restart openhab.
Before I did, I restarted the fontail service.
I deleted the event.log and openhab.log files.
Then issued the command openhab-cli stop
What puzzles me is: why did the openhab not write to the log files?
Is this a known issue?
Any hints appreciated.
