@d0t the newer GE devices don’t require polling, so if you have anything other than the really old ones, you wouldn’t need to worry. The ones I have are older than the scene support as well, so I can’t really comment there. I gave up on GE after these ones started failing badly (about 50% of them).
It’s also possible that changing the profile wasn’t the direct fix, but the side-effect of it causing an item to unlink and relink.
@feens - all point taken there - I’ve started to question if I made a bad decision with buying many of these devices on clearance earlier this year So far so good, but time will tell what the failure rate is.
@chris or @Bruce_Osborne i am curious, is the profile required to be set, or is it just that maybe the links on the items didn’t register? I feel like somewhere there’s definitely an underlying bug, maybe in the OH2 → OH3 migration script/flow
What version are you using? There was a change introduced in OH3 to not send the binding linking information during startup. This required a change to bindings - it was requested a couple of days before OH3 was released and was not done in a number of bindings (including the ZWave). If you are using OH3.0 release, then it will have this issue still.
I have not worked with OH3 in a while. I do not change whatever profile is automatically set by the system. That is the plain English definition of default.
