- Platform information:
- Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
- OS: OpenHabian
- Java Runtime Environment: Zulu11.43+88-CA
- openHAB version: 3.0
- Issue of the topic: Rules that use method getEvent fail with error.
- If logs where generated please post these here using code fences:
2020-12-29 18:26:50.286 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘Neeo-1’ failed: ‘getEvent’ is not a member of ‘java.lang.String’; line 7, column 20, length 24 in Neeo
Everything worked fine on 2.5 before I upgraded to 3.0.
