What does the exception say?
Does the trace contain the token? Usually it should be visible as json and contains the expiration time. Could you check that as soon as you experience the problem?
This is what I got:
2021-03-01 21:49:06.510 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying ',, Remember to take out the garbage. PMD and home garbage is collected tomorrow!': Missing service configuration.
org.openhab.core.voice.TTSException: Missing service configuration.
at org.openhab.voice.googletts.internal.GoogleTTSService.synthesize(GoogleTTSService.java:308) ~[?:?]
at org.openhab.core.voice.internal.VoiceManagerImpl.say(VoiceManagerImpl.java:221) [bundleFile:?]
at org.openhab.core.model.script.actions.Voice.say(Voice.java:121) [bundleFile:?]
at org.openhab.core.model.script.actions.Voice.say(Voice.java:39) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1176) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1151) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1137) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1082) [bundleFile:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:992) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:955) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:236) [bundleFile:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:216) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:472) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:256) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:459) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:240) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:202) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:47) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:30) [bundleFile:?]
at com.sun.proxy.$Proxy303.apply(Unknown Source) [?:?]
at org.openhab.core.model.script.actions.ScriptExecution.lambda$0(ScriptExecution.java:82) [bundleFile:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:166) [bundleFile:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:76) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Ok, I looked up the code which you can find here on line 308:
This points to the API not being initialized. So letâs dive deeper:
Here is the code located: openhab2-addons/GoogleCloudAPI.java at master · fguiraldelli/openhab2-addons · GitHub
Lookout for âinitializedâ. Without going too deep into the code, what I can see is that in any case we should see an logger.error entry before the problem happens.
The next time the problem happen you should see either
- âError initializing the serviceâ which means the initial initializing of the binding fails (which I doubt because it was running for some time)
- âGoogle client is not initialized!â but in this case the voices should be empty (which I should have seen in my case if I had set the debug to Error âŠ)
Maybe you can check the current logs if that appears somewhere.
Stefan
OK, It has happened again. Now I got error initializing. After I enter the authentication code again everything works. I thought that this is maybe related to restart of OH, because last week I had it hanging and needed to restart, so I tried openhab service restart, however the new authentication works after restart.
I remember I left my Google project in test phase could this be an issue?
2021-03-11 21:30:07.798 [WARN ] [ce.googletts.internal.GoogleCloudAPI] - Error initializing Google Cloud TTS service: Error fetching access token. Invalid authcode? Please generate a new one.
2021-03-11 21:30:07.801 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying ',, Remember to take out the garbage. Paper is collected tomorrow!': Could not read from Google Cloud TTS Service
org.openhab.core.voice.TTSException: Could not read from Google Cloud TTS Service
at org.openhab.voice.googletts.internal.GoogleTTSService.synthesize(GoogleTTSService.java:333) ~[?:?]
at com.sun.proxy.$Proxy1396.apply(Unknown Source) [?:?]
I need to correct the above posting as this refers to OH2 but you are on OH3. Anyways, when I look into the code it happens in the GoogleCloudAPI.getAccessToken() or getAuthorizationHeader() most likely in synthesizeSpeech() ->synthesizeSpeechByGoogle().
Though I kind of see where it could happen, I didnât write the code and we would need to set the log level to âDEBUGâ to have a clearer idea. But even then it will be probably hard for me to find out the real issue behind it. I looked up who wrote the whole code and the author originally was Gabor Bicskei and the latest change came from Kai Kreuzer (but the latter could be misleading as this part was refactored or moved by a major commit). You may want to ask them for further support.
cheers
Stefan
I has same issue and I was working a couple of hour without success. Thanks!
There is no need of new Client ID for fixing. Requesting of a new Authorization Code is enough. This is for one time use.
Thnx for the solution !
Here is the link to google console cloud
https://console.cloud.google.com/
I recieved the popup at the top of the page
and then the following
As stated above I authenticated again
Hmm I always had a full account and I still lost authentication⊠Weâll see if yours will persist! Fingers crossed!
I upgraded the account to full and set the application to production. Last Thursday it made announcement, but today I got this error (I didnt touch anything before that):
2021-03-20 10:12:01.367 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying 'The barbecue is too cold!88.00 degrees': Missing service configuration.
at com.sun.proxy.$Proxy1951.apply(Unknown Source) [?:?]
Yeah I thought so, it looses auth every now and then for me, too. No idea why thoughâŠ
I did the authentication yesterday still doesnât work
It does not work for me again. I changed googletts to trace logging but I do not get any error message. It simply does not download the voicelist. SO voice can not be selected and that is the reason of it does not work.
If you are not getting the voices it is an indirect sign that you arenât authenticated though I donât know why this is the case. It is working for me since weeks now (knock on wood)
This is my suspicion as well. I had also expired trial peiod isssue as described some weeks ago. But as I was granted it. It had started to work. Then I did some updates. Currently I use:
runtimeInfo:
version: 3.1.0
buildString: "Build #2300"
Thatâs why I changed log to trace for
<Logger level="TRACE" name="org.openhab.binding.GoogleTTS"/>
but I do not see any connection error. It would be good to see where the problem is.
Finally I created a new Project + Oauth2 ID and now it works.
I have also problems with the google TTS. It stoped working in openhab2 then i migrated to openhab 3, and it wasnât solved
I think something weird happens on openhab side.
This is the logging which i get when i try to send a message âTest Durchsageâ to TTS:
2021-05-31 16:20:14.914 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying 'Test Durchsage': Missing service configuration.
at org.openhab.core.voice.internal.VoiceManagerImpl.say(VoiceManagerImpl.java:223) ~[?:?]
at org.openhab.core.model.script.actions.Voice.say(Voice.java:121) ~[?:?]
at org.openhab.core.model.script.actions.Voice.say(Voice.java:39) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1192) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1167) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1153) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:971) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:247) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:131) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1183) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:991) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
After i purge the cache:
It works again for some time, not long, normally on the next day it stopped working.
I also still have problems. but must say that my free trial period of the cloud had also expired. I have now upgraded at google and the first time a new Authorization code created and imported.
Letâs see how long this goes well now.
However, my error message in the log is:
org.openhab.core.voice.TTSException: No TTS service can be found for voice googletts:deDEStandardC
Did someone solved this? Iâm getting also the same error:
2021-08-15 19:07:38.860 [ERROR] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://accounts.google.com/o/oauth2/token failed with error code invalid_grant, description Token has been expired or revoked.
2021-08-15 19:07:38.864 [WARN ] [ce.googletts.internal.GoogleCloudAPI] - Error initializing Google Cloud TTS service: Error fetching access token. Invalid authcode? Please generate a new one.
When I generate a new Code it works for about one day then again it stops working. Google itself compains with:
Iâm using OH 3.1.0. Any hint?
My TTS service failed also, when I upgraded to 3.x. Iâve created a new project, and somehow Iâve set the type to Desktop. It worx fine since then. I use this client ID on OH settings.
I still get this problem reguarly despite being âDesktopâ now on OH3. It appears to lose the authentication every few weeks. No idea why. Anyone else me this and found a solution?
I know it doesnât help to solve your problem but when I followed the whole setup on Google side it worked for me ever since, so I wonder if it is really related to openHAB.
