sorry here is a bug in the popover code. I define a identifier to control this proplem.
Now the location props is required and this prop is the identifier if you use more than one widget.
V1.8.1
uid: widget_HeatingCSS_1.8.1
tags: []
props:
parameters:
- description: eg. living room
label: location and widget identifier
required: true
type: TEXT
- description: Visual size of the control in px (default 400px), without a size the design is responsive
label: size [px]
required: false
type: TEXT
- description: Minimum value
label: minTemp
required: true
type: TEXT
- description: Maximum value
label: maxTemp
required: true
- context: item
description: Item to control
label: Set point Item
required: true
type: TEXT
- context: item
label: Item for current temperature
required: true
type: TEXT
- description: Control item unit eg °C
label: unit
required: false
type: TEXT
- description: URL or path to a Image (if you use a local img eg. -> http://local-IP-Adress:8080/static/folder/img.svg )
label: URL or path to image
required: false
type: TEXT
advanced: true
- description: Heating mode strings as array eg. AUTO,MANU,OFF. The string will be send to the Heating-Mode-Item [String-Item]
label: Heating Mode Array
required: false
type: TEXT
advanced: true
- description: Example Mode Strings as Array eg. OFF,ON,BOOST. The string will be send to the Example-Mode-Item [String-Item]
label: Example Mode Array
required: false
type: TEXT
advanced: true
- context: item
description: Heating Mode Item [String-Item]
label: Heating Mode Item
required: false
type: TEXT
advanced: true
- context: item
description: Example Mode Item [String-Item] (eg. State of heating valve)
label: Example Mode Item
required: false
type: TEXT
advanced: true
- context: item
description: Valve Item [Switch-Item] (eg. State of heating valve) for Animation
label: Valve Item
required: false
type: TEXT
advanced: true
- label: Custom font-size current&set-point marker (eg. 1em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size center (eg. 2em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size buttons (eg. 1.8em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size footer (eg. 1em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Main-Color Thermostat
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color control ring
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color buttons
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color center
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color Typo
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color setPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color currentPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient startPoint
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient endPoint
required: false
type: TEXT
groupName: colors
advanced: true
parameterGroups:
- name: colors
label: Color-Settings
- name: fonts
label: Font-Settings
timestamp: Feb 22, 2021, 12:22:59 PM
component: f7-card
title: "=(props.location) ? 'Klima ' + props.location : ''"
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-row
resizableFixed: true
resizable-absolute: true
class:
- justify-content-center
slots:
default:
- component: f7-block
class: thermostat
style:
flex-shrink: 0
--f7-block-margin-vertical: 0px
--f7-block-padding-vertical: 0px
--f7-block-padding-horizontal: 0px
padding-left: 0px
padding-top: "=props.size ? props.size + 'px': '100%'"
width: "=props.size ? Number(props.size)+'px' : '100%'"
background: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
border-radius: 50%
box-sizing: content-box
border: 2px solid rgb(64, 60, 77)
slots:
default:
class: bar
style:
margin-top: 0px
position: absolute
width: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
height: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
top: 50%
left: 50%
transform: translate(-50%, -50%)
border-radius: 50%
slots:
default:
class: inner_bar
style:
margin-top: 0
position: absolute
top: 50%
left: 50%
width: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
height: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
border-radius: 100%
background-color: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
z-index: 4 !important
slots:
default:
style:
background: "='conic-gradient(transparent 0deg 160deg, ' + (props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)') + ' 160deg 200deg, transparent 200deg 360deg)'"
content: ""
display: block
position: absolute
width: 100%
height: 100%
bottom: "=props.size ? '-7px' : '-7px'"
left: 50%
transform: translate(-50%)
class: hold left
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
clip-path: "=props.size ? 'inset(0px 0px 0px ' + (Number(props.size)*0.89/2) + 'px)' : 'inset(0% 0% 0% 50%)'"
border-radius: 100%
background-color: rgb(58, 55, 73)
slots:
default:
class: fill fill1
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
border-radius: 100%
clip-path: "=props.size ? 'inset(0px ' + (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 20%,' + props.colorBarEndPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 20%,rgb(255, 73, 0) 100%)'"
z-index: 1 !important
transition: transform 0.6s
transform: "=(items[props.setPointItem].state.split(' ')[0] >= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > Number(props.maxTemp)) ? 'rotate(180deg)' : '')"
class: hold right
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
border-radius: 100%
z-index: 3 !important
transform: rotate(180deg)
slots:
default:
class: fill
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
border-radius: 100%
animation: right 1s linear both
class: fill fill2
style:
position: absolute
margin-top: 0px
width: 100%
height: 100%
border-radius: 50%
clip-path: "=props.size ? 'inset(0px '+ (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 40%,' + props.colorBarStartPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 40%,rgb(255, 158, 35) 100%)'"
transform: "=(items[props.setPointItem].state.split(' ')[0] <= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))+20)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp))) ? 'rotate(180deg)' : '')"
class: span
style:
margin-top: 0px
width: "=props.size ? (Number(props.size)*0.89) +'px' : '100%'"
font-weight: "=props.size ? (Number(props.size)*2) +'px' : 'calc(var(--f7-list-item-title-font-weight)*2)'"
position: absolute
bottom: 0px
text-align: center
text-transform: uppercase
font-size: "=props.fontSizeFooter ? props.fontSizeFooter : '1em'"
color: "=props.colorTypo ? props.colorTypo : 'rgb(87, 84, 95)'"
z-index: 99 !important
slots:
default:
- component: Label
text: Heating
class: shadow
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=(items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '6.25%'"
height: 86%
text-align: center
transition: 0.7s ease
animation: shadow 1.4s ease-out both
slots:
default:
class: shadow-cube
style:
margin-top: 0px
position: absolute
top: 0
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '100%'"
height: 0px
box-shadow: "=props.size ? '0 0 ' + (Number(props.size)*0.1125) +'px ' + (Number(props.size)*0.0325) + 'px ' + (props.colorSetMarker ? props.colorSetMarker : 'rgba(255, 158, 35, 0.5)'): '0 0 45px 13px rgba(255, 158, 35, 0.5)'"
class: markerContainer
style:
pointer-events: none
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=(items[props.currentPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.currentPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.currentPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
width: "=props.size ? (Number(props.size)*0.1) +'px' : '10%'"
height: 100%
text-align: center
opacity: 1
slots:
default:
class: markerCurrent
style:
margin-top: 0px
width: "=props.size ? (Number(props.size)*0.1) +'px' : '100%'"
height: "=props.size ? (Number(props.size)*0.1) +'px' : ''"
padding-top: "=props.size ? '' : '100%'"
background: "=props.colorCurrentMarker ? props.colorCurrentMarker : 'rgb(33, 150, 243)'"
position: absolute
transform: translate(-50%,-50%) rotate(45deg)
left: 50%
top: "=props.size ? (Number(props.size)*0.14) +'px' : '15%'"
border-radius: 0% 50% 50% 50%
box-shadow: 0 0 5px 1px rgb(48, 46, 56)
slots:
default:
class: number
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: translate(-50%, -50%) rotate(-45deg)
text-align: center
slots:
default:
- component: Label
text: =items[props.currentPointItem].state.split(' ')[0]
style:
font-size: "=props.fontSizeMarker ? props.fontSizeMarker : '1em'"
color: white
font-weight: bold
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
height: 100%
text-align: center
opacity: 1
slots:
default:
class: markerSet
style:
margin-top: 0px
background: "=props.colorSetMarker ? props.colorSetMarker : 'rgb(230, 74, 25)'"
position: absolute
transform: translate(-50%,-50%) rotate(-45deg)
left: 50%
top: "=props.size ? (Number(props.size)*Number(-0.0125)) +'px': '-2%'"
border-radius: 50% 50% 50% 0
z-index: 100 !important
slots:
default:
class: number
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: translate(-50%, -50%) rotate(45deg)
text-align: center
slots:
default:
- component: Label
text: =items[props.setPointItem].state.split(' ')[0]
style:
color: white
font-weight: bold
class: center
style:
margin-top: 0px
position: absolute
width: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
height: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
background: "=props.colorControlRing ? props.colorControlRing : 'rgb(227, 228, 237)'"
top: 50%
left: 50%
border-radius: 50%
box-shadow: 0px 15px 35px 11px rgba(46, 44, 58,0.60)
slots:
default:
class: buttonContainer
style:
display: "=props.heatingModeItem ? '' : 'none'"
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=props.exampleModeItem ? 'translate(-50%, -50%) rotate(30deg)' : 'translate(-50%, -50%)'"
width: "=props.size ? (Number(props.size)*0.15) +'px' : '15%'"
height: 100%
text-align: center
opacity: 1
slots:
default:
- component: oh-button
popoverOpen: ='.' + props.location + '.popoverHeatingMode'
style:
width: 100%
height: 20%
position: absolute
bottom: 0%
left: 50%
color: "=props.colorButton ? props.colorButton + ' !important': ''"
slots:
default:
- component: f7-icon
f7: "=props.heatingModeItem ? (items[props.heatingModeItem].state == props.heatingModeArray.split(',')[0] ? 'hand_raised' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[1] ? 'arrow_2_squarepath' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[2] ? 'airplane' : 'thermometer') : ''"
style:
font-size: "=props.fontSizeButtons ? props.fontSizeButtons : '2em'"
position: absolute
top: 50%
margin-top: auto
- component: f7-popover
class: =props.location + ' popoverHeatingMode'
slots:
default:
noShadow: true
class:
- popover-close
action: variable
actionVariable: myVar
clearVariable: true
actionVariableValue: success
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
- component: oh-repeater
for: buttonlabel
in: =props.heatingModeArray.split(",")
containerStyle:
width: 100%
slots:
default:
color: "=props.colorButton ? props.colorButton : ''"
class: margin
text: =loop.buttonlabel
outline: true
action: command
active: "=(items[props.heatingModeItem].state === loop.buttonlabel ? true : false)"
actionCommand: =loop.buttonlabel
actionItem: =props.heatingModeItem
style:
display: "=props.exampleModeItem ? '' : 'none'"
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=props.heatingModeItem ? 'translate(-50%, -50%) rotate(-30deg)' : 'translate(-50%, -50%)'"
height: 100%
text-align: center
opacity: 1
slots:
default:
popoverOpen: ='.' + props.location + '.popoverExampleMode'
style:
width: 100%
height: 20%
position: absolute
bottom: 0%
left: 50%
slots:
default:
f7: wrench
style:
position: absolute
top: 50%
margin-top: auto
class: =props.location + ' popoverExampleMode'
slots:
default:
noShadow: true
class:
- popover-close
action: variable
clearVariable: true
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
for: buttonlabel
in: =props.exampleModeArray.split(",")
containerStyle:
width: 100%
slots:
default:
class: margin
outline: true
action: command
active: "=(items[props.exampleModeItem].state === loop.buttonlabel ? true : false)"
actionItem: =props.exampleModeItem
style:
width: 30%
height: 50%
position: absolute
margin-top: 0px
top: 50%
left: 10%
action: command
actionItem: =props.setPointItem
actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) > Number(props.minTemp) ? Number(items[props.setPointItem].state.split(' ')[0]) - 0.5 : ''"
slots:
default:
style:
position: absolute
top: 50%
margin-top: auto
f7: arrow_turn_left_down
style:
width: 30%
height: 50%
position: relative
margin-top: 0px
top: 50%
left: 90%
action: command
actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) < Number(props.maxTemp) ? Number(items[props.setPointItem].state.split(' ')[0]) + 0.5 : ''"
slots:
default:
style:
position: absolute
top: 50%
margin-top: auto
f7: arrow_turn_right_up
class: valveAnimation
style:
z-index: -100 !important
display: "=(props.valveItem && items[props.valveItem].state == 'ON' )? '' : 'none'"
background: "=props.colorSetMarker ? 'radial-gradient(' + props.colorSetMarker +' 30%, transparent 50%)' : 'radial-gradient(var(--f7-theme-color) 30%, transparent 50%)'"
margin-top: 0px
position: absolute
width: 100%
height: 100%
top: 50%
left: 50%
border-radius: 50%
animation: skeleton-effect-fade 2s linear infinite
class: small
style:
margin-top: 0px
position: absolute
width: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
height: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
background: "=props.colorCenter ? props.colorCenter : 'rgb(248, 249, 250)'"
text-align: center
animation: bound-in-small 0.6s ease forwards
top: 50%
left: 50%
border-radius: 50%
box-shadow: 0px 5px 10px 5px rgba(96, 93, 111,0.19)
slots:
default:
class: heat
style:
font-size: "=props.size ? (Number(props.size)*0.0375) +'px' : '14px'"
font-weight: 300
slots:
default:
- component: Label
text: =props.location
class: heat
style:
font-size: "=props.fontSizeCenter ? props.fontSizeCenter : '2em'"
font-weight: 300
slots:
default:
- component: Label
text: "=props.unit ? items[props.setPointItem].state.split(' ')[0] + '' + props.unit : items[props.setPointItem].state.split(' ')[0]"
- component: oh-image
url: "=props.imgUrl ? props.imgUrl : 'https://community-openhab-org.s3-eu-central-1.amazonaws.com/original/2X/7/7d388a86c95471f89b1bb911d96d7609a3e3a059.svg'"
style:
position: absolute
left: 50%
width: 40%
