The error message comes when the page containing the widget is opened in the browser and the Heating / Example Mode item is not linked to an item.
Hi @Tallman
thanks for the details.
I’ve found the little bug into the code. The error is by the defintion of the F7-Icon if no heatingModeItm is defined.
sorry for this.
I change the post above with version v1.8.1
I also included the array string for the icon selection.
Please give me a feedback if it works.
Change the line 510
f7: "=(items[props.heatingModeItem].state == 'Manuell' ? 'hand_raised' : items[props.heatingModeItem].state == 'Auto' ? 'arrow_2_squarepath' : items[props.heatingModeItem].state == 'Vacation' ? 'airplane' : 'thermometer')"
to:
f7: "=props.heatingModeItem ? (items[props.heatingModeItem].state == props.heatingModeArray.split(',')[0] ? 'hand_raised' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[1] ? 'arrow_2_squarepath' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[2] ? 'airplane' : 'thermometer') : ''"
It works great now! Thank you very much! The only thing I noticed was the location prop needs to be one single phrase, with a broken phrase (like a space in between two words) the pop-up won’t show. For me that is no big deal but just wanted to let you know.
It works, good work keep it up
Hi Nico,
fantastic The additions work all well. Now there are nearly all design-options possible.
The “pulsing Corona” is also a very nice feature, which I tested with a toggling switch of my office-lamp.
The wish of @Sas_Bibic (Translation) could be another interesting feature to make it more comfortable for users of different languages. But I don’t think that this is only done by changing the “state” to “displayState”.
For the moment I’m lucky with your solution and nosy for what is coming next.
cheers,
Peter
Dear all
Based on this wonderful widget (Thanks Nico)
I try to create widget for personal weather station
Any suggestion are welcome
Hi @Nico_R
Thank you again for your work.Popup menu looks really cool, and heating animation beautiful.
Unfortunately, I observe strange behavior of heating mode icon. On page open it displays default value (thermometer), when I switch to different mode icon switched to assigned to mode (airplane, hand, etc) but then i switch to another page and back to page with widget icon become again basic thermometer.
Widget version is 1.8.1
I am glad. In which German forum did you post it? Just out of interest because I’m from Germany too.
I tried to reproduce the error but didn’t succeed. When I switch between pages the icons stay as defined.
The icons are firmly defined in the code. The states of the string item are defined in the heatingMode array.
The first array key gets the hand_raised icon, the second key gets arrow_2_squarepath icon and the third key gets airplane. If you use more than 3 keys, the key> 3 always gets the thermometer.
Nico
I just thought, as your examples mostly shows “Klima Wohnzimmer”
Here’s the link for German-Forum, or here (may be you have to sign in to see the screen-shots)
@doctor64 I don’t know what kind of Thermostats you have, but my AVM-Fritz-Thermostats are “read-only” in the heating-mode. So if you make a change in the widget it will be set back after some seconds.
Changes are only possible inside the Fritz-Box-Web-UI.
Hi @Nico_R!
Sorry for false alarm, it was my fault. I just by old habit use spaces in heatingMode array, enter this:
AUTOMATIC, MANUAL, BOOST, VACATION
But spaces not ignored here, and of course strings “MANUAL” and " MANUAL" not matched, so default icon drawn.
Then I change array to:
AUTOMATIC,MANUAL,BOOST,VACATION
it start working as intended.
I think it will be common problem for people like me, with background in C or similar languages. I put space after comma by reflex! So i think it will be good to note somewhere what spaces not ignored.
Again, thank you very much for your excellent work!
Just a minor issue, and I not sure it related to Heating widget - i got lots of messages in openhab log like this:
[WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
Not sure of root source, but get it when I switch to test page with just one widget - heating. Try to define exampleModeItem, (normally i not use it) and seems like warning message stop appearing.
@fibu-freak I use EQ-3 MAX! Basic thermostats - they modes are controllable from OH binding. Anyway, problem is resolved, thank you for hint. You are right, mode item change state after few seconds - from " MANUAL" to “MANUAL”!
Hi Alex,
as I understand the Array (heatingModeArray) and the corresponding Icons should be used in a certain order to interact with the “heatingModeIcon”. So my order is now MANUAL,AUTOMATIC,VACATION,…whateveryouwant:
MANUAL = handraised - Icon [0]
AUOMATIC = arrow_2_squarepath - Icon [1]
VACATION = airplane - Icon [2]
whateveryouwant = thermometer
Code-Line - 508 : f7: "=props.heatingModeItem ? (items[props.heatingModeItem].state == props.heatingModeArray.split(',')[0] ? 'hand_raised' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[1] ? 'arrow_2_squarepath' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[2] ? 'airplane' : 'thermometer') : ''"
As for me the “exampleModeArray” is more comfortable, I made a little change in Line 589:
f7: "=props.exampleModeItem ? (items[props.exampleModeItem].state == props.exampleModeArray.split(',')[0] ? 'thermometer' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[1] ? 'thermometer_sun' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[2] ? 'rocket' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[3] ? 'gauge' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[4] ? 'gauge_badge_minus' : 'wrench') : ''"
to get some fancy icons (not only “wrench”) for the “modes” I’m using there:
The Modes are:
…but the “WINDOW_OPEN” is no Option for me (it’s very special in the Binding)
Cheers - Peter
BTW: For the Boost-Mode I used that Icon:
I will improve this area with the next release
The same problem was already present here:
Unfortunately, I was not thoroughly enough in bug fixing sorry!
But now it should work and the error should no longer appear.
Look here in the adapted v1.8.1
@fibu-freak Thank you for helping others here with my mistakes before I can fix these
all the best,
Nico
Hi Nico,
I think there are no errors in your widget, I love it as it is.
It’s only the way to handle it the way you meant.
The warning message:
2021-02-28 13:42:36.771 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
is from my point of view no error in the widget. I think this message comes up, when your in testing mode (Widgets) and an item which has to be named/assigned in the interaction, isn’t initialized/named/assigned.
I’m still very impressed of your work.
Cheers,
Peter
Hi @fibu-freak,
I’ll spend some time trying to figure root of problems. Looks like i found something, but, unfortunately, I don’t know how to fix it.
For example, we have in code for example item
display: "=props.exampleModeItem ? '' : 'none'"
So if exampleModeItemnot defined it will be not shown on interface. But code still have
action: command
active: "=(items[props.exampleModeItem].state === loop.buttonlabel ? true : false)"
actionCommand: =loop.buttonlabel
actionItem: =props.exampleModeItem
I think what OH engine still trying to access item with name in exampleModeItem variable, and because it is undefined generate a warning.
Hi @doctor64 and @fibu-freak ,
That is not completely right. The error occurs because I refer to an item in expressions which is not defined.
The error is definitely in my code. I’ve tried to ensure it everywhere but quickly forgot in this new lines.
Your guess is completely correct.
I forgot to include the boolean operator in the expressions here.
I have figure the error out and adapt the correct expression in the code.
It must look like:
active: "=props.heatingModeItem ? (items[props.heatingModeItem].state === loop.buttonlabel ? true : false) : ''"
and
actionItem: "=props.heatingModeItem ? props.heatingModeItem : ''"
this for exampleModeItem and heatingModeItem.
The corrected code can be found here without a new tag version.
I hope this solves the bugs and you have fun agian with the widget.
Hello together,
I am facing some issue in the widget with rounding the value of temperature:
The item is defined as shown below:
Number:Temperature SollTemp_Bad "Soll Bad [%.1f °C]" <temperature> (gBadOGThermostat, gTemperature) ["Setpoint", "Temperature"] {channel="knx:device:MDT_IP:MDT_HS4:SollTemp_Bad", stateDescription=""[pattern="%.1f °C"]}
Any idea how to fix this issue.
Thanks in advance!
Hi @snowy
Please share your yaml and the two items set and current temperature.
Maybe then i can help.
The Item definition
Number:Temperature ActualTemp_WZ "Ist Wohnzimmer [%.1f °C]" <temperature> (gLivingroomThermostat, gTemperature) ["Measurement", "Temperature"] {alexa="CurrentTemperature", channel="knx:device:MDT_IP:MDT_HS8:ActualTemp_WZ", stateDescription=""[pattern="%.1f °C"]}
Number:Temperature SollTemp_WZ "Soll Wohnzimmer [%.1f °C]" <temperature> (gLivingroomThermostat, gTemperature) ["Setpoint", "Temperature"] {channel="knx:device:MDT_IP:MDT_HS8:SollTemp_WZ", stateDescription=""[pattern="%.1f °C"]}
This is the YAML:
uid: widget_TestThermostat
tags: []
props:
parameters:
- description: eg. living room
label: location and widget identifier
required: true
type: TEXT
- description: Visual size of the control in px (default 400px), without a size the design is responsive
label: size [px]
required: false
type: TEXT
- description: Minimum value
label: minTemp
required: true
type: TEXT
- description: Maximum value
label: maxTemp
required: true
- context: item
description: Item to control
label: Set point Item
required: true
type: TEXT
- context: item
label: Change target value Item
required: true
type: TEXT
- context: item
label: Item for current temperature
required: true
type: TEXT
- description: Control item unit eg °C
label: unit
required: false
type: TEXT
- description: URL or path to a Image (if you use a local img eg. -> http://local-IP-Adress:8080/static/folder/img.svg )
label: URL or path to image
required: false
type: TEXT
advanced: true
- description: Heating mode strings as array eg. AUTO,MANU,OFF. The string will be send to the Heating-Mode-Item [String-Item]
label: Heating Mode Array
required: false
type: TEXT
advanced: true
- description: Example Mode Strings as Array eg. OFF,ON,BOOST. The string will be send to the Example-Mode-Item [String-Item]
label: Example Mode Array
required: false
type: TEXT
advanced: true
- context: item
description: Heating Mode Item [String-Item]
label: Heating Mode Item
required: false
type: TEXT
advanced: true
- context: item
description: Example Mode Item [String-Item] (eg. State of heating valve)
label: Example Mode Item
required: false
type: TEXT
advanced: true
- context: item
description: Valve Item [Switch-Item] (eg. State of heating valve) for Animation
label: Valve Item
required: false
type: TEXT
advanced: true
- label: Custom font-size current&set-point marker (eg. 1em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size center (eg. 2em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size buttons (eg. 1.8em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Custom font-Size footer (eg. 1em)
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Main-Color Thermostat
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color control ring
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color buttons
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color center
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color Typo
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color setPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color currentPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient startPoint
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient endPoint
required: false
type: TEXT
groupName: colors
advanced: true
parameterGroups:
- name: colors
label: Color-Settings
- name: fonts
label: Font-Settings
timestamp: Mar 3, 2021, 9:30:50 PM
component: f7-card
title: "=(props.location) ? 'Klima ' + props.location : ''"
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-row
resizableFixed: true
resizable-absolute: true
class:
- justify-content-center
slots:
default:
- component: f7-block
class: thermostat
style:
flex-shrink: 0
--f7-block-margin-vertical: 0px
--f7-block-padding-vertical: 0px
--f7-block-padding-horizontal: 0px
padding-left: 0px
padding-top: "=props.size ? props.size + 'px': '100%'"
width: "=props.size ? Number(props.size)+'px' : '100%'"
background: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
border-radius: 50%
box-sizing: content-box
border: 2px solid rgb(64, 60, 77)
slots:
default:
class: bar
style:
margin-top: 0px
position: absolute
width: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
height: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
top: 50%
left: 50%
transform: translate(-50%, -50%)
border-radius: 50%
slots:
default:
class: inner_bar
style:
margin-top: 0
position: absolute
top: 50%
left: 50%
width: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
height: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
border-radius: 100%
background-color: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
z-index: 4 !important
slots:
default:
style:
background: "='conic-gradient(transparent 0deg 160deg, ' + (props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)') + ' 160deg 200deg, transparent 200deg 360deg)'"
content: ""
display: block
position: absolute
width: 100%
height: 100%
bottom: "=props.size ? '-7px' : '-7px'"
left: 50%
transform: translate(-50%)
class: hold left
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
clip-path: "=props.size ? 'inset(0px 0px 0px ' + (Number(props.size)*0.89/2) + 'px)' : 'inset(0% 0% 0% 50%)'"
border-radius: 100%
background-color: rgb(58, 55, 73)
slots:
default:
class: fill fill1
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
border-radius: 100%
clip-path: "=props.size ? 'inset(0px ' + (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 20%,' + props.colorBarEndPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 20%,rgb(255, 73, 0) 100%)'"
z-index: 1 !important
transition: transform 0.6s
transform: "=(items[props.setPointItem].state.split(' ')[0] >= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > Number(props.maxTemp)) ? 'rotate(180deg)' : '')"
class: hold right
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
border-radius: 100%
z-index: 3 !important
transform: rotate(180deg)
slots:
default:
class: fill
style:
margin-top: 0px
position: absolute
width: 100%
height: 100%
border-radius: 100%
animation: right 1s linear both
class: fill fill2
style:
position: absolute
margin-top: 0px
width: 100%
height: 100%
border-radius: 50%
clip-path: "=props.size ? 'inset(0px '+ (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 40%,' + props.colorBarStartPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 40%,rgb(255, 158, 35) 100%)'"
transform: "=(items[props.setPointItem].state.split(' ')[0] <= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))+20)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp))) ? 'rotate(180deg)' : '')"
class: span
style:
margin-top: 0px
width: "=props.size ? (Number(props.size)*0.89) +'px' : '100%'"
font-weight: "=props.size ? (Number(props.size)*2) +'px' : 'calc(var(--f7-list-item-title-font-weight)*2)'"
position: absolute
bottom: 0px
text-align: center
text-transform: uppercase
font-size: "=props.fontSizeFooter ? props.fontSizeFooter : '1em'"
color: "=props.colorTypo ? props.colorTypo : 'rgb(87, 84, 95)'"
z-index: 99 !important
slots:
default:
- component: Label
text: Heating
class: shadow
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=(items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '6.25%'"
height: 86%
text-align: center
transition: 0.7s ease
animation: shadow 1.4s ease-out both
slots:
default:
class: shadow-cube
style:
margin-top: 0px
position: absolute
top: 0
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '100%'"
height: 0px
box-shadow: "=props.size ? '0 0 ' + (Number(props.size)*0.1125) +'px ' + (Number(props.size)*0.0325) + 'px ' + (props.colorSetMarker ? props.colorSetMarker : 'rgba(255, 158, 35, 0.5)'): '0 0 45px 13px rgba(255, 158, 35, 0.5)'"
class: markerContainer
style:
pointer-events: none
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=(items[props.currentPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.currentPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.currentPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
width: "=props.size ? (Number(props.size)*0.1) +'px' : '10%'"
height: 100%
text-align: center
opacity: 1
slots:
default:
class: markerCurrent
style:
margin-top: 0px
width: "=props.size ? (Number(props.size)*0.1) +'px' : '100%'"
height: "=props.size ? (Number(props.size)*0.1) +'px' : ''"
padding-top: "=props.size ? '' : '100%'"
background: "=props.colorCurrentMarker ? props.colorCurrentMarker : 'rgb(33, 150, 243)'"
position: absolute
transform: translate(-50%,-50%) rotate(45deg)
left: 50%
top: "=props.size ? (Number(props.size)*0.14) +'px' : '15%'"
border-radius: 0% 50% 50% 50%
box-shadow: 0 0 5px 1px rgb(48, 46, 56)
slots:
default:
class: number
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: translate(-50%, -50%) rotate(-45deg)
text-align: center
slots:
default:
- component: Label
text: =items[props.currentPointItem].state.split(' ')[0]
style:
font-size: "=props.fontSizeMarker ? props.fontSizeMarker : '1em'"
color: white
font-weight: bold
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
height: 100%
text-align: center
opacity: 1
slots:
default:
class: markerSet
style:
margin-top: 0px
background: "=props.colorSetMarker ? props.colorSetMarker : 'rgb(230, 74, 25)'"
position: absolute
transform: translate(-50%,-50%) rotate(-45deg)
left: 50%
top: "=props.size ? (Number(props.size)*Number(-0.0125)) +'px': '-2%'"
border-radius: 50% 50% 50% 0
z-index: 100 !important
slots:
default:
class: number
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: translate(-50%, -50%) rotate(45deg)
text-align: center
slots:
default:
- component: Label
text: =items[props.setPointItem].state.split(' ')[0]
style:
color: white
font-weight: bold
class: center
style:
margin-top: 0px
position: absolute
width: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
height: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
background: "=props.colorControlRing ? props.colorControlRing : 'rgb(227, 228, 237)'"
top: 50%
left: 50%
border-radius: 50%
box-shadow: 0px 15px 35px 11px rgba(46, 44, 58,0.60)
slots:
default:
class: buttonContainer
style:
display: "=props.heatingModeItem ? '' : 'none'"
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=props.exampleModeItem ? 'translate(-50%, -50%) rotate(30deg)' : 'translate(-50%, -50%)'"
width: "=props.size ? (Number(props.size)*0.15) +'px' : '15%'"
height: 100%
text-align: center
opacity: 1
slots:
default:
- component: oh-button
popoverOpen: ='.' + props.location + '.popoverHeatingMode'
style:
width: 100%
height: 20%
position: absolute
bottom: 0%
left: 50%
color: "=props.colorButton ? props.colorButton + ' !important': ''"
slots:
default:
- component: f7-icon
style:
font-size: "=props.fontSizeButtons ? props.fontSizeButtons : '2em'"
position: absolute
top: 50%
margin-top: auto
- component: f7-popover
class: =props.location + ' popoverHeatingMode'
slots:
default:
noShadow: true
class:
- popover-close
action: variable
actionVariable: myVar
clearVariable: true
actionVariableValue: success
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
- component: oh-repeater
for: buttonlabel
in: =props.heatingModeArray.split(",")
containerStyle:
width: 100%
slots:
default:
color: "=props.colorButton ? props.colorButton : ''"
class: margin
text: =loop.buttonlabel
outline: true
action: command
style:
margin-top: 0px
position: absolute
top: 50%
left: 50%
transform: "=props.heatingModeItem ? 'translate(-50%, -50%) rotate(-30deg)' : 'translate(-50%, -50%)'"
height: 100%
text-align: center
opacity: 1
slots:
default:
popoverOpen: ='.' + props.location + '.popoverExampleMode'
style:
width: 100%
height: 20%
position: absolute
bottom: 0%
left: 50%
slots:
default:
f7: wrench
style:
position: absolute
top: 50%
margin-top: auto
class: =props.location + ' popoverExampleMode'
slots:
default:
noShadow: true
class:
- popover-close
action: variable
clearVariable: true
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
for: buttonlabel
in: =props.exampleModeArray.split(",")
containerStyle:
width: 100%
slots:
default:
class: margin
outline: true
action: command
active: "=props.exampleModeItem ? (items[props.exampleModeItem].state === loop.buttonlabel ? true : false) : ''"
actionItem: "=props.exampleModeItem ? props.exampleModeItem : ''"
style:
width: 30%
height: 50%
position: absolute
margin-top: 0px
top: 50%
left: 10%
action: command
actionItem: =props.changeTargetSwitchItem
actionCommand: OFF
slots:
default:
style:
position: absolute
top: 50%
margin-top: auto
f7: arrow_turn_left_down
style:
width: 30%
height: 50%
position: relative
margin-top: 0px
top: 50%
left: 90%
action: command
actionCommand: ON
slots:
default:
style:
position: absolute
top: 50%
margin-top: auto
f7: arrow_turn_right_up
class: valveAnimation
style:
z-index: -100 !important
display: "=(props.valveItem && items[props.valveItem].state == 'ON' )? '' : 'none'"
background: "=props.colorSetMarker ? 'radial-gradient(' + props.colorSetMarker +' 30%, transparent 50%)' : 'radial-gradient(var(--f7-theme-color) 30%, transparent 50%)'"
margin-top: 0px
position: absolute
width: 100%
height: 100%
top: 50%
left: 50%
border-radius: 50%
animation: skeleton-effect-fade 2s linear infinite
class: small
style:
margin-top: 0px
position: absolute
width: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
height: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
background: "=props.colorCenter ? props.colorCenter : 'rgb(248, 249, 250)'"
text-align: center
animation: bound-in-small 0.6s ease forwards
top: 50%
left: 50%
border-radius: 50%
box-shadow: 0px 5px 10px 5px rgba(96, 93, 111,0.19)
slots:
default:
class: heat
style:
font-size: "=props.size ? (Number(props.size)*0.0375) +'px' : '14px'"
font-weight: 300
slots:
default:
- component: Label
text: =props.location
class: heat
style:
font-size: "=props.fontSizeCenter ? props.fontSizeCenter : '2em'"
font-weight: 300
slots:
default:
- component: Label
text: "=props.unit ? items[props.setPointItem].state.split(' ')[0] + '' + props.unit : items[props.setPointItem].state.split(' ')[0]"
- component: oh-image
url: "=props.imgUrl ? props.imgUrl : 'https://community-openhab-org.s3-eu-central-1.amazonaws.com/original/2X/7/7d388a86c95471f89b1bb911d96d7609a3e3a059.svg'"
style:
position: absolute
left: 50%
width: 40%
