Some of you may experienced in OH2.x that HmIP-BROLL had a strange behaviour in OH: with Proxy and rules the Level had to be recalculated not to reach 100% and OPen close was inverted.
Now I tried OH3 with the UI configuration only.
Its very close to work with alexa without all the work-arounds.
Remaining Problem: Giving the command CLOSE it opens / Giving the command OPEN it closes.
I have not seen a possibility in the Web UI to change this, Is there a possibility to change the Mappings manually?
Something like:
Rollershutter EG_WO_Rollladen_links “Rollladen Wohnzimmer links” (RRD4J,Rollos,West) [“Blinds”] {alexa=“RangeController.rangeValue” [category=“INTERIOR_BLIND”, friendlyNames="@Setting.Opening", supportedRange=“0:100:10”, unitOfMeasure=“Percent”, actionMappings="Close=100,Open=0,Lower=(-10),Raise=(+10)", stateMappings=“Closed=100,Open=0:99”] }
