[WARN ] [.accessories.HomekitAccessoryFactory] - Accessory of type SmokeSensor must have following characteristics [SMOKE_DETECTED_STATE]. Found only []
[WARN ] [mekit.internal.HomekitChangeListener] - Could not add device BatteryLevel: Missing mandatory characteristics
Also the temprature is set to 10,0°C at the start - after some times it switches to normal (23,0°-25,0°)
on temperature: 10,0°C is the default lowest temperature. probably SensorTemperature has no value at the beginning
smoke detector. binding thinks that you have 2 different smoke detectors
“AlarmSmoke” and “BatteryLevel” and the “BatteryLevel” has no SmokeDetectedState characteristics.
you need to put them in one group so that binding understands that these are 2 characteristics of the same smoke detectors, e.g.
Group gSmokeAlarm "Smoke alarm" {homekit="SmokeSensor}
Switch AlarmSmoke "Smoke alarm" (EG_Technikraum, gSmokeAlarm) {homekit="SmokeSensor.SmokeDetectedState",channel="zwave:device:dummy:node40:alarm_smoke"}
Number BatteryLevel "Batterieladung" (EG_Technikraum, gSmokeAlarm) {homekit="SmokeSensor.BatteryLowStatus",channel="zwave:device:dummy:node40:battery-level"}
I do not know how the homekit addon works but openHAB has its state (luckily updating homekit devices dont need a full openHAB reboot). I guess the homekit addon asks every 5 minutes to update?
For my understanding: do I need to put each smoke detector into the same group or do I need to split them gSmokeAlarm1, gSmokeAlarm2 ?
homekit reads the values on start of home app. home app request values from openhab and afterwards openhab sends updates to home app on every changes. it can take 2-3 seconds depending on number of devices.
please check what it the value of SensorTemperature when you see 10,0°C
one group = one device. you need a separate group for every smoke detector.
Note: you only need a group if you have more than one characteristics for the same device, e.g. in your case you track smoke alarm and battery, so, 2 characteristics => you need a group.
if you would not need the battery but only smoke alarm then you would not need a group.
BatteryLowStatus expects a switch or contact item with ON/OFF value.
if you link it to a number, it will interpret number = 0 as OFF, means not warning and all numbers >1 as ON, means low batter warning.
probably not the best mapping, but this is how it is currently works. to fix it, i would create a separate item of type switch and make a rule, that will update this switch depending on Batterieladung.
