Maybe I’m getting it all wrong since I’m not the most experienced OH user. Certainly the scripts doc, especially the part about postUpdate
vs. sendCommand
is super confusing to me.
So here it goes: I have a OH3 installation with the HomeMatic binding, speaking to a CCU3. A motion event turns on a certain light via a rule:
2021-02-03 17:39:42.074 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Et_Bewegungsmelder_1_Motion' changed from OFF to ON
2021-02-03 17:39:42.088 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Et_Licht_1_State' received command ON
2021-02-03 17:39:42.094 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Et_Licht_1_State' predicted to become ON
2021-02-03 17:39:42.099 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Et_Licht_1_State' changed from OFF to ON
And the light turns on. Well, this time, a few seconds later a communication error about the light device was logged and the item “restarted”:
2021-02-03 17:39:46.118 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1PBU-FM:3014F711A0001F9A49922BFF:NEQ0275927' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2021-02-03 17:39:46.133 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1PBU-FM:3014F711A0001F9A49922BFF:NEQ0275927' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2021-02-03 17:39:46.146 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Et_Licht_1_State' changed from ON to OFF
See, the Light state was reset to OFF
, although it was still burning!
Then, after 5 minutes, when the light was supposed to be turned off via a rule, this happened:
2021-02-03 17:44:42.091 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Et_Licht_1_State' received command OFF
2021-02-03 17:44:42.094 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Et_Licht_1_State' predicted to become OFF
2021-02-03 17:44:42.279 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Et_Licht_1_State' changed from OFF to ON
The rule definitely set the light to off via sendCommand(OFF)
, but instead it turned on, so it stayed on! That’s not the desired result…
This is the whole rule:
var Timer ETLichtTimer = null
var String TAG = "et_bewegungslicht"
// Schaltet das Licht neben der Eingangstür für 300 Sekunden ein.
rule "Eingangstuer Licht an bei Bewegung"
Item Et_Bewegungsmelder_1_Motion changed to ON
if(ETLichtTimer !== null)
ETLichtTimer.cancel()
var String sun_state = LocalSun_Phase_SunPhaseName.state
if(sun_state != "DAYLIGHT" && sun_state != "SUN_RISE" && sun_state != "SUN_SET")
Et_Licht_1_State.sendCommand(ON)
ETLichtTimer = createTimer(now.plusSeconds(300), [ |
Et_Licht_1_State.sendCommand(OFF)
If I understand it correctly, this is what happened: the connection error reset the internal state of the light to OFF
although the light was still on (physically). And the subsequent sendCommand(OFF)
for some reason translated into a ON
command, perhaps because some internal state comparison went foul.
What can I do about it? Is this a bug? Is it expected behaviour?
