openHAB version: 3.0.1
I’ve seen several exemples where on the location standard page, locations groups are presented (ie: ground floor, first floor, …)
I’ve seen that a ‘separator’ could be used for that purpose.
I wonder from where this ‘separator’ could come in the yaml? I’d like to avoid to define them in the yaml files and wondering How to create them from the gui or the text config files?
Thank you for your help
In the overview window click on the pencil icon in the upper right corner to go to the UI editor for this special page. Then in the locations list click on the black menu button next to the item you want to be the first card in the new section and select Add Separator Before
You can then rename the separator to give it whatever title you like.
