Hi guys,
I’m migrating to 3.0 and want to do my thing with the Web Interfaced wherever possible.
Till now I get it working if I create the channels as string types
If I try to use a number var type I get a type conversion error, even the XPATH result are always digits, expect the NaN case.
Is there a possibility to convert directly into a number ?
my steps yet:
STEPS:
- Add HTTP Thing, → Base Url: http://192.168.178.205/measurements.xml
- Add a Channel → Type: String; State Transformation: XPATH(number(//Measurements/Measurement[@Type=‘AC_Voltage’]/@Value))
if the Channel is defined as numer:
2021-02-04 22:27:34.508 [WARN ] [.profiles.XPathTransformationProfile] - Could not transform state ‘UNDEF’ with function ‘(number(//Measurements/Measurement[@Type=‘AC_Voltage’]/@Value))’ and format ‘%.1f’
