When I want to control a Scene from the Hue Bridge I have to transmit the string hashed?
instead of e.g. Scene „Abend" the hash “oyfFdwiMhCu5Opd”.
In the dashboard of the schematic model the names are displayed correctly.
Does anyone know how I can also enter the strings directly in Openhab3 in JavaScript without using the hash. Or does anyone know how I can create this hash? Unfortunately I don’t know how it was hashed… I was just guessing if it is a hash.
Thanks a lot
Enclosed the example script controlled by a rule
Is a simple light control for the bathroom
- Platform information:
- Hardware: Raspi 4 / 8Gb
- OS: Buster
- Java Runtime Environment: –
- openHAB version: 3.0.2 with Docker
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
var ScriptExecution = Java.type("org.openhab.core.model.script.actions.ScriptExecution");
var ZonedDateTime = Java.type("java.time.ZonedDateTime");
var timenow = ZonedDateTime.now();
//var nacht = DateTimeType.valueOf(itemRegistry.getItem('LokaleSonnendaten_Nacht_Start').getState().toString());
var auf = DateTimeType.valueOf(itemRegistry.getItem('LokaleSonnendaten_SonnenAufgang').getState().toString());
var aufende = DateTimeType.valueOf(itemRegistry.getItem('LokaleSonnendaten_SonnenAufgang_Ende').getState().toString());
var unter = DateTimeType.valueOf(itemRegistry.getItem('LokaleSonnendaten_Sonnenuntergang').getState().toString());
var unterende = DateTimeType.valueOf(itemRegistry.getItem('LokaleSonnendaten_Sonnenuntergang_Ende').getState().toString());
//var tag = DateTimeType.valueOf(itemRegistry.getItem('LokaleSonnendaten_Tag_Start').getState().toString());
var Bath_Timer;
var Bath_Dim_Timer;
var delaydim;
var delay;
logger.info('Badezimmer Regel Aktiv');
if (itemRegistry.getItem('BewegungsmelderBadezimmer_Bewegung').getState() == 'ON') {
logger.info('Bewegung im Bad erkannt');
this.delay = 600;
this.delaydim = 0;
if(timenow <= unter && timenow > aufende)
logger.info('Bad Tag');
events.sendCommand('Licht_Badezimmer_Scene', 'RKvPEeQ-5LFHxSN');
this.delaydim = 120;
else if(timenow <= unterende && timenow >= unter)
logger.info('Bad Abend');
events.sendCommand('Licht_Badezimmer_Scene', 'oyfFdwiMhCu5Opd');
this.delaydim = 180;
else if(timenow <= auf && timenow < aufende)
logger.info('Bad Morgen');
else
logger.info('Bad Nacht');
events.sendCommand('Licht_Badezimmer_Scene', 'SKlVi0Gqy5eCLW2');
this.delaydim = 60;
this.Bath_Dim_Timer = ScriptExecution.createTimer(ZonedDateTime.now().plusSeconds(this.delay), function(){
events.sendCommand('Licht_Badezimmer_Helligkeit', 20);});
if (this.Bath_Timer !== undefined) {
this.Bath_Timer.cancel();
this.Bath_Timer = undefined;
if (this.Bath_Dim_Timer !== undefined) {
this.Bath_Dim_Timer.cancel();
this.Bath_Dim_Timer = undefined;
if (itemRegistry.getItem('BewegungsmelderBadezimmer_Bewegung').getState() == 'OFF')
this.Bath_Dim_Timer = ScriptExecution.createTimer(ZonedDateTime.now().plusSeconds(this.delaydim), function(){
events.sendCommand('Licht_Badezimmer_Helligkeit', 10);
this.delay = 30 + delay;});
if(this.delay != 600)
this.Bath_Timer = ScriptExecution.createTimer(ZonedDateTime.now().plusSeconds(this.delay), function(){
events.sendCommand('Licht_Badezimmer_Schalter', OFF);});
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
