After upgrading i have this messages in log:
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field "value" on measurement "LokaleZeit_DatumUndZeit" is type integer, already exists as type float dropped=2
at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:144) ~[bundleFile:?]
at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2020-12-22 13:34:14.775 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field "value" on measurement "WZPresence_WZPresence" is type integer, already exists as type float dropped=1
Next error is via executeCommandLine:
Solved
executeCommandLine(“/home/pi/camoff.sh”,90000)
executeCommandLine(Duration.ofSeconds(2), "/home/pi/heater.php 5 " + WZHeizung.state.toString)
cannot convert from int to string error
https://i.imgur.com/QfD4q14.png
Design Patter time of day doesn’t work i get this error:
https://i.imgur.com/2rlNKg4.png
Hope someone has a solution for me.
Thank you very much.
