curlyel
(Curlyel)
February 16, 2021, 6:46am
21
Sure.
Thatās the current look, slightly modified to grey stepper controls:
ā¦ and the widget code:
uid: Thermostat-Control
tags: []
props:
parameters:
- description: Thermostat to control
label: Description
required: false
type: TEXT
- context: item
description: Das Item fĆ¼r die gemessene Temperatur
label: Ist Temperature Item
required: true
type: TEXT
- context: command
description: Unterer Preset
label: Temperatur kalt
required: true
type: TEXT
- context: command
description: Normaler Preset
label: Temperatur normal
required: true
type: TEXT
- context: command
description: Oberer Preset
label: Temperatur warm
required: true
type: TEXT
- context: item
description: Das Item mit dem die Solltemperatur eingestellt wird
label: Setpoint Item
required: true
type: TEXT
timestamp: Feb 5, 2021, 1:04:45 PM
component: f7-card
outline: false
noBorder: false
padding: true
noShadow: false
style:
--f7-card-margin-horizontal: 5px
--f7-card-content-padding-vertical: 0px
--f7-card-content-padding-horizontal: 16px
--f7-card-border-radius: 15px
--f7-card-box-shadow: 0px 5px 10px rgba(0,0,0,0.15)
--f7-card-header-font-size: 14px
--f7-card-header-font-weight: 600
slots:
content:
- component: oh-label-card
noShadow: true
trendItem: =(props.tempItem)
action: analyzer
actionAnalyzerItems: =[props.tempItem,props.setpointItem]
item: =(props.tempItem)
title: =(props.Title)
icon: f7:thermometer
actionAnalyzerCoordSystem: time
vertical: false
- component: oh-stepper-card
noShadow: true
color-theme: gray
item: =(props.setpointItem)
large: false
autorepeat: true
fill: false
noBorder: true
raised: true
small: true
round: true
min: =(props.tempKalt-1)
max: =(props.tempWarm+1)
step: 0.5
- component: f7-row
class:
- padding-bottom
- padding-right
slots:
default:
- component: f7-col
slots:
default:
- component: oh-button
title: Kalt
action: command
actionItem: =(props.setpointItem)
actionCommand: =(props.tempKalt)
iconF7: thermometer_snowflake
iconColor: blue
textColor: blue
text: min
- component: f7-col
slots:
default:
title: Normal
action: command
actionCommand: =(props.tempNorm)
iconF7: thermometer
iconColor: orange
textColor: orange
text: ok
- component: f7-col
slots:
default:
title: Warm
action: command
actionCommand: =(props.tempWarm)
iconF7: thermometer_sun
iconColor: red
textColor: red
text: max
I love this widget due to its simplicity and good responsiveness. I have added a window icon to the thermostat that displays when a window is open. This works fine for one window.
visible: "=props.kontaktItem1 ? true : false"
icon: "=(items[props.kontaktItem1].state === 'OPEN') ? 'window-open' : 'window-closed'"
style:
position: absolute
bottom: 20%
left: 95%
transform: translate(-50%,-50%)
width: 10%
height: 20%
But how can I connect the icon to the states of more than one window? What is the syntax for an OR condition on the icon line.
I tried something like this:
icon: "=((items[props.kontaktItem1].state === 'OPEN') && (items[props.kontaktItem2].state === 'OPEN')) ? 'window-open' : 'window-closed'"
Itās probably something dead stupid, but Iām not getting it at the moment. I been reading descriptions on conditional (ternary) operator, but I think Iām just missing something easy.
Any help would be greatly appreciated.
Rob
Hi Rob,
you are pretty closeā¦ Do you want an AND condition or an OR condition. Your try is an AND oneā¦
This is what i use for an AND one as an example:
color: "=themeOptions.dark === 'light' && Number.parseFloat(items[props.itemDown].state.split(' ')[0]) < 150 ? 'red' : themeOptions.dark === 'light' && Number.parseFloat(items[props.itemUp].state.split(' ')[0]) < 35 ? 'red' : themeOptions.dark === 'dark' ? 'white' : 'black'"
for OR just do this in your example:
icon: "=((items[props.kontaktItem1].state === 'OPEN') ? 'window-open' : (items[props.kontaktItem2].state === 'OPEN')) ? 'window-open' : 'window-closed'"
Hey thanks, that was the solution to my problem. As a hobby programmer, I often find the right approach, but often also get caught out by silly syntax mistakes. Itās nice to know thereās help just round the corner.
Rob
nikos7179
(nikos7179)
December 10, 2021, 8:41pm
25
Can you show please where exactly you add this code in the widget, to show the windows state?
Nikos
iviax
(Max)
December 19, 2021, 9:35pm
26
Thanks alot for this great widget !
powerpolly
(Matthias P)
January 7, 2022, 8:28pm
27
really nice widget!!! is it possible to highlight the selected heat mode somehow, like the black border in this screenshot, or nicer
curlyel
(Curlyel)
January 8, 2022, 8:13am
28
The obvious solution might be the raised-option of oh-button:
title: Kalt
action: command
iconColor: blue
textColor: blue
text: min
raised: "=(items[props.setPointItem].state == props.tempKalt) ? 'true' : 'false'"
Unfortunately, the dynamic check of the current state does not work yetā¦
From a usability point of view Iād suggest to have all buttons raised except the selected one.
If something is raised, it can be clicked. If not it has already been selected.
This way it stays consistent with the temperature buttons above.
curlyel
(Curlyel)
January 8, 2022, 9:56am
30
Fully agree of course.
I just wanted to answer the question of @powerpolly and make him aware of the raised
option which is almost exactly what he was asking for
Personally, I still do prefer the simpler design without that additional raised effect.
btw.: Any clue why:
Is not getting updated dynamically when the setpoint item changes?
Maybe āraisedā is only evaluated once when displaying the button. Could be by design or might be a small bug, I havenāt tried it yet. Did you try rotating the device ? I expect that the button will get rendered again and will reflect the property state.
curlyel
(Curlyel)
January 8, 2022, 3:13pm
32
No, this seems not to be the case
After some investigation it turned out, that my comparision was simply wrong.
Iāve checked with the āwidget expression testerā in the developer sidebar and noticed finally, that comparing the props.tempKalt
etc. with the item state is a bad idea, because:
evaluates to:
{ "state": "17 Ā°C", "displayState": "17.0" }
Therefore, comparing the preset temps with the displayState
(instead of āstateā) solved this:
raised: =(items[props.setpointItem].displayState != props.tempKalt )
Disadvantage is, that the preset temperatures in the widget config need to match exactly the stateDescription
metadata for the setpoint items, %.1f
in my case to trigger the conditional clauses in the widgetā¦
curlyel
(Curlyel)
January 8, 2022, 3:28pm
33
According to @powerpolly 's question, Iāve updated the widget to reflect the selected preset temperature:
Important to make it work properly is to set the preset temperatures in the widget config exactly as the will appear in the displayState. Means if your displayState is %.1f
, then the preset should be for example 17.0
and not just 17
Here is the updated widget code:
tags: []
props:
parameters:
label: Description
required: false
type: TEXT
- context: item
required: true
type: TEXT
- context: command
required: true
- context: command
required: true
- context: command
required: true
- context: item
required: true
type: TEXT
timestamp: Jan 8, 2022, 3:58:24 PM
component: f7-card
outline: false
noBorder: false
padding: true
noShadow: false
style:
slots:
content:
noShadow: true
action: analyzer
vertical: false
noShadow: true
color-theme: gray
large: false
autorepeat: true
fill: false
noBorder: true
raised: true
small: true
round: true
step: 0.5
- component: f7-row
class:
- padding-bottom
slots:
default:
- component: f7-segmented
colorTheme: gray
strong: false
style:
width: 100%
round: true
raised: true
outline: true
class:
- segmented-round
slots:
default:
title: Kalt
action: command
actionItem: =props.setpointItem
actionCommand: =props.tempKalt
iconColor: '=(items[props.setpointItem].displayState == props.tempKalt) ? "white" : "blue"'
textColor: '=(items[props.setpointItem].displayState == props.tempKalt) ? "white" : "blue"'
text: min
round: true
small: true
active: =(items[props.setpointItem].displayState == props.tempKalt )
title: Normal
action: command
actionCommand: =props.tempNorm
iconF7: thermometer
iconColor: '=(items[props.setpointItem].displayState == props.tempNorm) ? "white" : "orange"'
textColor: '=(items[props.setpointItem].displayState == props.tempNorm) ? "white" : "orange"'
text: ok
round: true
small: true
active: =(items[props.setpointItem].displayState == props.tempNorm )
title: Warm
action: command
actionCommand: =props.tempWarm
iconColor: '=(items[props.setpointItem].displayState == props.tempWarm) ? "white" : "red"'
textColor: '=(items[props.setpointItem].displayState == props.tempWarm) ? "white" : "red"'
text: max
round: true
small: true
active: =(items[props.setpointItem].displayState == props.tempWarm)
powerpolly
(Matthias P)
January 8, 2022, 4:17pm
34
so great! many thanks! Iām still learning how to code those widget, not always easy for a non-programmerā¦
curlyel
(Curlyel)
January 8, 2022, 5:15pm
35
I wasnāt happy with the raised design for the presetsā¦therefore changed back to a flat version for the preset buttons while still highlighting which preset the current setpoint temperature is matching currently:
Here is the code:
tags: []
props:
parameters:
label: Description
required: false
type: TEXT
- context: item
required: true
type: TEXT
- context: command
required: true
- context: command
required: true
- context: command
required: true
- context: item
required: true
type: TEXT
timestamp: Jan 8, 2022, 6:21:18 PM
component: f7-card
outline: false
noBorder: false
padding: true
noShadow: false
style:
slots:
content:
noShadow: true
action: analyzer
vertical: false
noShadow: true
color-theme: gray
large: false
autorepeat: true
fill: false
noBorder: true
raised: true
small: false
round: true
step: 0.5
- component: f7-row
colorTheme: blue
class:
- padding-bottom
slots:
default:
- component: f7-col
slots:
default:
title: Kalt
color-theme: blue
action: command
text: min
round: true
small: true
- component: f7-col
slots:
default:
title: Normal
color-theme: orange
action: command
iconF7: thermometer
text: ok
round: true
small: true
- component: f7-col
slots:
default:
title: Warm
color-theme: red
action: command
text: max
round: true
small: true
izy
(Paul)
January 17, 2022, 11:04pm
36
Didnāt manage to add the window to the widgetā¦ could you please post your code?
Could somebody maybe give me a heads up on how to add Ā°C to the set temperature element?
Thank you!
A great Widget. I want add Battery Status and some other Informations but there is not enough space and i dont want see if allways. But i dont want increase the size of then Widget.
So i need a Second Window or something else.
Could i Open a new window If i Push a Button?
I dont know its possible.
Otherwise how could i invisible something when i press a Button? This Button has no Item or something else.
I think i need local variables to change the visible attribute of an other element?
