I have stumbled across this when I encountered some performance issue on my particular setup (synology NAS + docker image + rrd4j persistence).
I have since then uninstalled the rrd4j persistence service. I do however still use the jdbc mariadb persistence service.
My jdbc.cfg is fine, I have no issue connecting to my mariadb instance and persisting items, that all works well.
I have the following jdbc.persist, which gets loaded by openHAB (openhab.log says so):
Strategies {
everyMinute : "0 * * * * ?"
every15Minutes : "0 */15 * ? * *"
everyHour : "0 0 * * * ?"
everyDay : "22 0 * * * *"
default = everyChange
Items {
Person1LocationHistory, Person1LocationTimeHistory, Person2LocationHistory, Person2LocationTimeHistory, Person3LocationHistory, Person3LocationTimeHistory, Person4LocationHistory, Person4LocationTimeHistory : strategy = everyHour, restoreOnStartup
Corona_Incidences* : strategy=everyHour, restoreOnStartup
LastCall, SecondLastCall, ThirdLastCall, FourthLastCall : strategy = everyChange, restoreOnStartup
Using the REST API as well as my mariadb browser I noticed that since I upgraded to OH3 not only these items are being persisted, but seemingly all of my items are being persisted.
I was wondering how this works. I can imagine that at some point during my investigations I have had no jdbc.persist file. And I understand that this might have caused openHAB to fall back to the new default where every item gets persisted. Even if that was the case which could explain the many hundred item tables I see in the mariadb database, I would have expected that they don’t get updated anymore when using the jdbc.persist file from above.
If I use the REST API explorer it tells me that for all of these items persistence is actually active (http://192.168.178.34:8080/rest/persistence/items) or what does it mean if they all get listed in the response?
It seems to me that openhab is persisting my items even though I don’t want it to. For whatever reason that led to performance issues with rrd4j and luckily mariadb seems to be able to handle it, but I don’t want this type of workload on the machine.
Any tips on how to debug this or ideas how to solve it are much appreciated
