OH3 js rules gone
Today I have got my hands on OH3 (m1 and latest snapshot). I noticed the next generation rule engine is installed out of the box and I can create rules via the new Webui, great!
I have two DSL rules stored on the file system which are also visible in the UI, but I miss all my jsr223 (Javascript) rules stored on the file system.
Do I have to migrate those somehow manually or is this a bug?
Did you try restarting openHAB after the first startup? I fixed this bug and it is available in the OH3 snapshot build:
Tried right now with latest snapshot docker image without success. Still only DSL rules are shown to me. From the logs I only see errors related to Influxdb (data type) and mapdb (serialization), which seem to be known looking at other threads.
I think I ran into your issue too while testing some Groovy rules yesterday. You can probably get your rules loaded by installing an additional feature on the Console using:
feature:install openhab-core-automation-module-script-rulesupport
So we need to add that feature by default or it will not load JS rules from files. :slight_smile:
There’s now a PR to fix this:
That did the trick. Now I just need to change the namespaces…
java.lang.ClassNotFoundException: org.eclipse.smarthome.model.script.actions.ScriptExecution
I guess it just replacing ā€œeclipseā€ by ā€œopenhabā€?
Great!
Usually all you have to do is replace ā€œorg.eclipse.smarthomeā€ with ā€œorg.openhab.coreā€
If that results in ā€œorg.openhab.core.coreā€ you need to remove one ā€œ.coreā€.
You can also find these classes in the JavaDocs:
https://next.openhab.org/javadoc/latest/
