- Platform information:
- Hardware: Raspi 4B
- OS: Linux/5.4.79-v7l+ (arm)
- Java Runtime Environment: 11.0.9 (Zulu11.43+88-CA)
- openHAB version: 3.1.0 “Build #2123”
- Issue of the topic: JSR223 Rules migration from OH 2.5.11 to OH 3.0.0
I did a complete fresh openhabian install on a Raspi 4B and updated to OH3 everything is up and running, including the Jython helper libraries, set up according to this
All Rules (30+) are up and running without any errors except one.
I struggle with the syntax and have no idea where to start.
Here is the rule which was working on OH 2.5.11
from core.rules import rule
from core.triggers import when
from core.date import DateTime
@rule("Muell")
@when("Time cron 0 0 17 1/1 * ? *")
def muell(event):
muellDateTime = DateTime(str(items["Muellkalender_Ergebnisstart1t"])) #Item State is DateTime Format
muellname = (str(items["Muellkalender_Ergebnistitel1"]))
now = DateTime.now()
if now.isAfter(muellDateTime.minusDays(1)) and now.isBefore(muellDateTime):
actions.get("telegram", "telegram:telegramBot:1f84b343").sendTelegram(-326642842, "Morgen ist " + muellname + ", nicht vergessen")
I know in OH 3 i have to import java.time
from java.time import ZonedDateTime as DateTime
from org.slf4j import LoggerFactory, Logger
log = LoggerFactory.getLogger("org.openhab.automation.JYTHON")
log.info("Loading test jython rule ")
@rule("Muell")
@when("Item TasmotaTest_state changed")
def muell(event):
muellDateTime = ir.getItem("Muellkalender_Ergebnisstart1").state
muellname = str(items["Muellkalender_Ergebnistitel1"])
#if now.isAfter(muellDateTime.minusDays(1)) and now.isBefore(muellDateTime):
# actions.get("telegram", "telegram:telegramBot:9b4ccbc1b4").sendTelegram(-326642842, "Morgen ist " + muellname + ", nicht vergessen")
log.info(str(muellDateTime))
log.info(muellname)
log.info(str(now))
If i log muellDateTime, muellname and now as string i get this output
If i run the full scipt i get this Log.
2021-01-08 19:41:27.150 [WARN ] [jsr223.jython ] - Traceback (most recent call last):
File "/etc/openhab/automation/lib/python/core/log.py", line 65, in wrapper
return function(*args, **kwargs)
File "/etc/openhab/automation/lib/python/core/rules.py", line 109, in execute
self.callback(inputs.get('event'))
File "<script>", line 77, in muell
AttributeError: 'org.openhab.core.library.types.DateTimeType' object has no attribute 'minusDays'
I have no Idea where to start.
Any help appreciated
Roli
