Hi everybody!
Most of my KNX things/items work as expected, but i have some trouble with my dimmers: when i send a value (position) to the item, the postition is written to the KNX bus (and i can see with my own eyes that the lights react…) but openHAB doesn’t update the position-value. when i change the position value with my “old” openHAB2 setup the item DOES get the new position value. (the problems already exists on my OH2 setup but i just figured it out now…)
here’s my things:
//TUNNEL
Bridge knx:ip:bridge [
type="TUNNEL",
ipAddress="...",
portNumber=3671,
autoReconnectPeriod=60,
localSourceAddr="15.15.241"
Thing device generic [a
Type dimmer : Licht_Wohnzimmer "Licht Wohnzimmer" [switch="2/1/8+<2/1/108", position="2/1/15+<2/1/112", increaseDecrease="2/1/14" ]
item:
Dimmer Licht_Wohnzimmer "Licht Wohnzimmer [%d%%]" (gLichter_EG, Group_HabPanel_Dashboard) ["Switch"] {channel="knx:device:bridge:generic:Licht_Wohnzimmer", autoupdate="false" }
debug log if i send a value command to the item:
2021-09-25 22:10:49.186 [DEBUG] [nx.internal.client.AbstractKNXClient] - Wrote value '50' to datapoint 'command DP 2/1/15 'knx:ip:bridge', DPT id 5.001, low priority' (0. attempt).
2021-09-25 22:10:49.164 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Licht_Wohnzimmer' received command 50
no further entries.
this is debug log when i send the command on my other setup:
2021-09-25 22:11:55.670 [DEBUG] [.internal.handler.DeviceThingHandler] - onGroupWrite Thing 'knx:device:bridge:generic' received a GroupValueWrite telegram from '15.15.241' for destination '2/1/15'
2021-09-25 22:11:55.678 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Licht_Wohnzimmer' changed from 20 to 75
you can see in this entry that openHAB3 didn’t have the “old” value (which should be 50, not 20).
i have also tried to turn off my openHAB2 system and restart the KNX Binding on the openHAB3 binding but the problem persists.
is my configuration wrong or am i missing something else?
best regards,
Peter
