i’m currently using the linky binding Linky - Bindings | openHAB
it work well, but does’nt pull everyday my electricity consumption.
I need to deactivate the thing and reactivate it to pull consumption.
Do you know how I can set up automatic pulling?
thank’s for your help
edit : maybe I can try to Enable and disable things every time I want an update, so I made a rules :
every day at 23:30
execute :
sendHttpPutRequest(“http://localhost:8080/rest/things/linky%3Alinky%3Adc1f72b527/enable”, “application/json”, “false”)
sendHttpPutRequest(“http://localhost:8080/rest/things/linky%3Alinky%3Adc1f72b527/enable”, “application/json”, “true”)
But I have a problem :
2020-12-07 18:44:44.138 [ERROR] [enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
Maybe in javascript I can access thing directly? I have juste the Item Registry
