Thanks for your response.
I will study your code as i am Newbie with yaml.
Nikos
Nikos
Don’t hesitate to ask, ill try to help were I can.
Ok, just playing around visually with the widgets… I must say, its fun building/designin widgets. (This is just a work in progress (not functional yet, soon will be)
Plate on the left:
Middle plate:
Plate on the right:
What do you think about this? What do you like/Dislike?
Lemme know!
Looking really nice for a wall panel or similar!
First of all: Thank you everyone for sharing your examples. I learned a lot in this thread and I’m really satisfied with the current results in developing my own dashboards. That wouldn’t be possible without this community support, especially without the examples by @Integer and @BG56.
This is my main ui. I have three main dashboards (overview, room, logics), from which several subpages can be reached.
Overview:
with several subpages for example for weather…
…owntracks positions of the family (in this case for one familiy member)…
… and different subpages provided by the status cards at the bottom of the side, which change their color in dependency to their state. In this case heating state is greater than 0%, because of that the card is purple in the dashbord and offers this detailed page:
The second dashboard gives an overview over alle my rooms and locations:
Each “roomcard” leads to a detailed view of the described room, like the following living room example:
Maybe someone gets some ideas out of this examples, like I did because of the previous postings.
Regards,
Boris.
This is awesome!! I like the chart “Heizungsdaten”. Can you share your widget code?
Yes, of course. Variable declarations are in German, I hope this is not a problem.
uid: Livevisu Heizungsgraph Boden
tags:
- Live
- MainUI
props:
parameters:
- label: Raumbezeichnung
required: false
type: TEXT
- label: Hintergrundfarbe
required: false
type: TEXT
- context: item
label: Ist Temperatur
required: false
type: TEXT
- context: item
label: Soll Temperatur
required: false
type: TEXT
- context: item
label: Stellgröße Boden
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 12, 2021, 6:33:43 PM
component: f7-card
style:
noShadow: false
padding: 0px
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
background-color: "=props.bgcolor ? props.bgcolor : ''"
height: 340px
margin-left: 5px
margin-right: 5px
slots:
content:
- component: f7-block
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
- component: f7-icon
f7: thermometer
style:
margin-right: 10px
- component: Label
text: "=props.raum ? props.raum : ''"
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
top: 48px
left: 16px
flex-direction: row
slots:
default:
- component: Label
text: Heizungsdaten
style:
font-size: 17px
font-weight: 600
margin-left: 0px
margin-top: 0px
style:
margin-top: 10px
margin-left: -11px
margin-right: -11px
padding-left: 0px
padding-right: 0px
slots:
default:
- component: oh-chart
chartType: day
slots:
grid:
- component: oh-chart-grid
containLabel: false
show: true
top: "90"
bottom: "20"
right: 30
left: 30
xAxis:
- component: oh-time-axis
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
scale: true
min: "13"
max: "25"
gridIndex: 0
min: "0"
max: "100"
series:
- component: oh-time-series
name: Ist Temperatur
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: line
item: =props.isttemp
name: Soll Temperatur
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: line
item: =props.solltemp
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 1
type: bar
item: =props.stellbo
tooltip: []
raum: []
toolbox: []
dataZoom: []
legend:
- component: oh-chart-legend
show: true
top: 53
left: 2
visualMap: []
This is awesome @kuczerek! I like the clean design and structure of your overviews. Is it possible to share your yaml code of the implementations? Or at least share some background information about how you build it? Did u use the default oh cards/items/cells? Or did u rely on f7 components? I’m still looking around to build my own overview page
Really cool design @kuczerek I like it a lot.
Could you please give me a hint/tutorial how to create a widget like your “Übersicht aktuelle Heizungsdaten/Temperaturen im Heizungssystem”?
I ask because I planned a similar thing but with a little bit other pictures. I would like to add an heat-pump picture and replace the radiators with an “Fußbodenheizung” picture.
Thanks in advance
Hi @Eisi1482
thank you! I used a mix of f7 and openhab components, based on the widgets and page design of @integer. Every “card” in the page is an individual built widget, as you can see in the yaml code. The page design is based on openhab components, which are also working with the openhab page designer. I built the widgets by duplicating the examples of @integer and customizing the cards to my own needs. Most of them rely on f7 components. Since I was new to f7 and yaml it took a while to get a clue how to put everything together, especially to understand the interaction between f7 components and openhab. I often used the developer tools of my chrome browser, to investigate which css styles and css variables have to be changed, to get what I want.
For the pages I used the responsive design, because of that it is possible to use all pages on my mobile phone. Here comes the yaml code für the two dashboards. (I changed some descriptions for privacy reasons):
This is the general overview (first page)
layoutType: responsive
label: Übersicht
sidebar: false
blocks:
- component: oh-block
config: {}
slots:
default:
- component: oh-grid-row
config: {}
slots:
default:
- component: oh-grid-col
config: {}
slots:
default:
- component: widget:Livevisu Titel
header: Statusübersicht
config: {}
slots:
default:
config: {}
slots:
default:
- component: widget:Livevisu Trenner
header: Wetter und Familie
config: {}
slots:
default:
xlarge: "50"
width: "100"
slots:
default:
- component: widget:Livevisu Wettervorhersage
title: Wettervorhersage für XXX
width: "100"
xlarge: "50"
slots:
default:
- component: widget:Livevisu Owntracks Übersicht
config: {}
config: {}
slots:
default:
config: {}
slots:
default:
config: {}
slots:
default:
header: Allgemeine Infos
config: {}
slots:
default:
width: "100"
xlarge: "33"
slots:
default:
- component: widget:Livevisu ID3
config: {}
width: "100"
xlarge: "33"
slots:
default:
- component: widget:Livevisu Robaert
config: {}
width: "100"
xlarge: "33"
slots:
default:
- component: widget:Livevisu Kamera Eingang
config: {}
config: {}
slots:
default:
config: {}
slots:
default:
config: {}
slots:
default:
header: Statusinformationen
config: {}
slots:
default:
width: "5"
xlarge: "20"
slots:
default: []
xlarge: "10"
width: "33"
slots:
default:
- component: widget:Livevisu Aussenhaut Übersicht
door_numbers: hTuerOffenAnzahl
lock_numbers: hSchlossOffenAnzahl
window_numbers: hFensterOffenAnzahl
neeingang_cont: KNXSteuerEGNebeneingangstuerabgeschlossen
page: liveAussenhaut
width: "33"
xlarge: "10"
slots:
default:
- component: widget:Livevisu Störungen Übersicht
title: Störungen
icon_active: exclamationmark_triangle_fill
page: liveStoerungen
stoerungen_numbers: hStoerungen
icon_titel: info_circle
icon: checkmark_circle
icon_haupt: exclamationmark_circle
width: "33"
xlarge: "10"
slots:
default:
title: Alarme
page: liveAlarme
stoerungen_numbers: hAlarme
icon_haupt: exclamationmark_triangle
width: "33"
xlarge: "10"
slots:
default:
- component: widget:Livevisu Linkkarte mit Status Übersicht
title: Heizung
icon: flame
page: liveHeizungssteuerung
praefix: "Ø "
status: hHeizungStellantriebeDurchschnitt
bgcolor_acive: "#d5b1e6"
bgcolor_active: "#dad3f2"
width: "33"
xlarge: "10"
slots:
default:
title: Beschattung
icon: sun_max
page: liveBeschattung
status: hBeschattungAktiv
bgcolor_acive: lightgreen
bgcolor_active: lightgreen
width: "33"
xlarge: "10"
slots:
default:
title: Bewässerung
icon: drop
status: hBewaesserungAktiv
page: liveBewaesserung
width: "100"
xlarge: "20"
slots:
default: []
masonry: null
grid: []
This is the room overview (second page):
label: Räume und Orte
blocks:
config: {}
slots:
default:
config: {}
slots:
default:
config: {}
slots:
default:
header: Aktuelle Raum- und Ortsübersicht
config: {}
slots:
default:
config: {}
slots:
default:
header: Haus Erdgeschoss
config: {}
slots:
default:
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
- component: widget:Livevisu Raumkarte
text_header: Windfang
iconimage: windfang
lights: hEgWfVisuLichtAnAnzahl
power: hEgWfVisuSteckdosenAnAnzahl
heating: KNXHeizEGWindfangStatusStellgrosse
temp: KNXHeizEGWindfangIstTemperatur
settemp: KNXHeizEGWindfangSollTemperatur
door_state: KNXSteuerEGHaustuergeoffnet
door_lock: KNXSteuerEGHaustuerabgeschlossen
page: liveHausWindfang
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Küche
iconimage: kueche
lights: hEgKueVisuLichtAnAnzahl
heating: KNXHeizEGKucheStatusStellgrosse
settemp: KNXHeizEGKucheSollTemperatur
temp: KNXHeizEGKucheIstTemperatur
blinds_closed: hEgKueVisuRolladenstellung
windows_numbers: hEgKueVisuFensterOffenAnzahl
windows: hEgKueFenster
page: liveHausKueche
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Wohnzimmer
iconimage: wohnzimmer
lights: hEgWoVisuLichtAnAnzahl
power: hEgWoVisuSteckdosenAnAnzahl
blinds_closed: hEgWoVisuRolladenstellung
windows_numbers: hEgWoVisuFensterOffenAnzahl
heating: KNXHeizEGWohnzimmerStatusStellgrosse
temp: KNXHeizEGWohnzimmerIstTemperatur
settemp: KNXHeizEGWohnzimmerSollTemperatur
windows: hEgWoFenster
page: liveHausWohnzimmer
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Terasse
iconimage: terasse
lights: aTeVisuLichtAnAnzahl
power: aTeVisuSteckdosenAnAnzahl
blinds_closed: aTeVisuRolladenstellung
page: liveAussenTerasse
config: {}
slots:
default:
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Gästezimmer
iconimage: gaestezimmer
lights: hEgGaeVisuLichtAnAnzahl
power: hEgGaeVisuSteckdosenAnAnzahl
blinds_closed: hEgGaeVisuRolladenstellung
windows_numbers: hEgGaeVisuFensterOffenAnzahl
heating: KNXHeizEGGastezimmerStatusStellgrosse
temp: KNXHeizEGGastezimmerIstTemperatur
settemp: KNXHeizEGGastezimmerSollTemperatur
windows: hEgGaeFenster
page: liveHausGaestezimmer
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: WC
iconimage: wc
lights: hEgWcVisuLichtAnAnzahl
blinds_closed: hEgWcVisuRolladenstellung
windows_numbers: hEgWcVisuFensterOffenAnzahl
heating: hEgWcVisuAVGStellgroesse
temp: KNXHeizEGWCIstTemperatur
settemp: KNXHeizEGWCSollTemperatur
windows: hEgWcFenster
page: liveHausWc
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Hauswirtschaftsraum
iconimage: hauswirtschaftsraum
lights: hEgHwVisuLichtAnAnzahl
blinds_closed: hEgHwVisuRolladenstellung
windows_numbers: hEgHwVisuFensterOffenAnzahl
heating: KNXHeizEGHWRStatusStellgrosse
temp: KNXHeizEGHauswirtschaftsraumIstTemperatur
settemp: KNXHeizEGHauswirtschaftsraumSollTemperatur
windows: hEgHwFenster
door_state: KNXSteuerEGNebeneingangsturgeoffnet
door_lock: KNXSteuerEGNebeneingangstuerabgeschlossen
page: liveHausHauswirtschaftsraum
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Flur
iconimage: flur-eg
lights: hEgFlurVisuLichtAnAnzahl
power: hEgFlurVisuSteckdosenAnAnzahl
page: liveHausFlurEg
config: {}
slots:
default:
config: {}
slots:
default:
config: {}
slots:
default:
header: Haus Obergeschoss
config: {}
slots:
default:
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Schlafzimmer
iconimage: schlafzimmer
lights: hOgSchlafVisuLichtAnAnzahl
blinds_closed: hOgSchlafVisuRolladenstellung
windows_numbers: hOgSchlafVisuFensterOffenAnzahl
heating: KNXHeizOGSchlafzimmerStatusStellgrosse
temp: KNXHeizOGSchlafzimmerIstTemperatur
settemp: KNXHeizOGSchlafzimmerSollTemperatur
windows: hOgSchlafFenster
page: liveHausSchlafzimmer
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Kind1
iconimage: Kind1
lights: hOgNaVisuLichtAnAnzahl
blinds_closed: hOgNaVisuRolladenstellung
windows_numbers: hOgNaVisuFensterOffenAnzahl
heating: KNXHeizOGKind1StatusStellgrosse
temp: KNXHeizOGKind1IstTemperatur
settemp: KNXHeizOGKind1SollTemperatur
windows: hOgNaFenster
page: liveHausKind1
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Arbeitszimmer
iconimage: arbeitszimmer
lights: hOgArVisuLichtAnAnzahl
power: hOgArVisuSteckdosenAnAnzahl
windows_numbers: hOgArVisuFensterOffenAnzahl
heating: KNXHeizOGArbeitszimmerStatusStellgrosse
temp: KNXHeizOGArbeitszimmerIstTemperatur
settemp: KNXHeizOGArbeitszimmerSollTemperatur
windows: hOgArFenster
page: liveHausArbeitszimmer
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Kind2
iconimage: Kind2
lights: hOgNoVisuLichtAnAnzahl
blinds_closed: hOgNoVisuRolladenstellung
windows_numbers: hOgNoVisuFensterOffenAnzahl
heating: KNXHeizOGKind2StatusStellgrosse
temp: KNXHeizOGKind2IstTemperatur
settemp: KNXHeizOGKind2SollTemperatur
windows: hOgNoFenster
page: liveHausKind2
config: {}
slots:
default:
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Badezimmer
iconimage: badezimmer
lights: hOgBadVisuLichtAnAnzahl
blinds_closed: hOgBadVisuRolladenstellung
windows_numbers: hOgBadVisuFensterOffenAnzahl
heating: hOgBadVisuAVGStellgroesse
temp: KNXHeizOGBadIstTemperatur
settemp: KNXHeizOGBadSollTemperatur
windows: hOgBadFenster
page: liveHausBadezimmer
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Wurstekammer
iconimage: wurstekammer
lights: hOgWuVisuLichtAnAnzahl
page: liveHausTechnik
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Flur
iconimage: flur-og
lights: hOgFlVisuLichtAnAnzahl
page: liveHausFlurOg
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Dachboden
iconimage: dachboden
lights: hOgDachVisuLichtAnAnzahl
windows_numbers: hOgDachVisuFensterOffenAnzahl
windows: hDgFenster
page: liveHausDachboden
config: {}
slots:
default:
config: {}
slots:
default:
config: {}
slots:
default:
header: Außenbereich
config: {}
slots:
default:
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Garage
iconimage: garage
lights: gVisuLichtAnAnzahl
temp: KNXHeiz1wireGarageIstTemperatur
page: liveGarage
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Auffahrt
iconimage: auffahrt
lights: aAufVisuLichtAnAnzahl
power: aAufVisuSteckdosenAnAnzahl
temp: KNXHeiz1wireAussenIstTemperatur
page: liveAuffahrt
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Garten
iconimage: garten
lights: aGaVisuLichtAnAnzahl
power: aGaVisuSteckdosenAnAnzahl
page: liveGarten
width: "100"
small: "50"
medium: "33"
large: "25"
xlarge: "25"
slots:
default:
text_header: Gewächshaus
iconimage: gewaechshaus
lights: aGeVisuLichtAnAnzahl
page: liveGewaechshaus
masonry: []
grid: []
To center the cards in the middle of the page, for example the status cards in the bottom of the first dashboard, I created empty columns. Another possibility is changing the default css styles of the oh-pages, but I didn’t found a solution which was compatible with the openhab page designer.
The only problem is the perfomance of the pages. It takes a while (maybe two or three seconds) to load a new page. I’ve seen some other threads discussing this problem, but obviously there is no solution for this problem right now. I think most of the time is needed by Java Script operations in the client, because the time to load the page ist very dependent on my different clients. Right now I’m going to install a wall panel driven by a raspberry pie, I’m curious how this will work.
Hi @ToSa,
I picked some SVG graphics from https://www.svgrepo.com/ and combined them with https://inkscape.org/ to this SVG:
The widget displays the SVG image and puts temperature items to the right places. The temperature items are hardcoded and not defined via widget properties, because I didn’t need different instances of this widget
… replace the radiators with an “Fußbodenheizung” picture.
That would by nice. I didn’t find a self-explanatory picture for my underfloor heating. If you have a good proposal you’ll be welcome!
This is my yaml code:
uid: Livevisu Heizung Temperaturen
tags:
- Live
- MainUI
props:
parameters:
- description: rgba oder HEX
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 9, 2021, 6:49:43 PM
component: f7-card
style:
noShadow: false
padding: 0px
height: 340px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: flame
style:
margin-right: 10px
- component: Label
text: Temperaturen im Heizungssystem
style:
font-size: 12px
margin-top: 0px
style:
margin-top: 10px
flex-direction: row
display: flex
align-items: center
justify-content: space-around
slots:
default:
slots:
default:
- component: oh-image
url: /static/icons/heizung.svg
style:
height: 290px
opacity: 0.7
- component: f7-chip
text: "='Vorlauf: '+ items['KNXHeiz1wireSolarVorlaufIstTemperatur'].displayState"
style:
position: absolute
top: 250px
left: 130px
font-size: 14px
text: "='Rücklauf: '+ items['KNXHeiz1wireSolarRucklaufIstTemperatur'].displayState"
style:
position: absolute
top: 85px
left: 130px
font-size: 14px
text: "='Vorlauf: '+ items['KNXHeiz1wireHeizungVorlaufIstTemperatur'].displayState"
style:
position: absolute
top: 85px
left: 545px
font-size: 14px
text: "='Rücklauf: '+ items['KNXHeiz1wireHeizungRucklaufIstTemperatur'].displayState"
style:
position: absolute
top: 255px
left: 545px
font-size: 14px
text: "='Schicht: '+ items['KNXHeiz1wirePufferspeicherOben1IstTemperatur'].displayState"
style:
position: absolute
top: 54px
left: 348px
font-size: 14px
text: "='Schicht: '+ items['KNXHeiz1wirePufferspeicherOben2IstTemperatur'].displayState"
style:
position: absolute
top: 101px
left: 348px
font-size: 14px
text: "='Schicht: '+ items['KNXHeiz1wirePufferspeicherMitteIstTemperatur'].displayState"
style:
position: absolute
top: 148px
left: 348px
font-size: 14px
text: "='Schicht: '+ items['KNXHeiz1wirePufferspeicherUnten1IstTemperatur'].displayState"
style:
position: absolute
top: 195px
left: 348px
font-size: 14px
text: "='Schicht: '+ items['KNXHeiz1wirePufferspeicherUnten2IstTemperatur'].displayState"
style:
position: absolute
top: 242px
left: 348px
font-size: 14px
Wow Thanks a lot. Will have a deeper look the next days. I’m also new to the f7 framework and like you struggling with the interaction between oh and f7 components. So it’s good to have a starting point to customize from.
Hi, after some work I have a first draft version working.
The 3 way valve in the picture is switching according to the state of the item “HeishamonOutletDirection”.
Everything is hard coded and I’m not finished yet. But I would let you show my actual widget.
I painted the .svg with https://app.diagrams.net/ and saved it in Openhab Config folder /icons/classic. With the pictured saved in this directory the url paths in the yaml will work.
This is the yaml code
tags:
- Live
- MainUI
props:
parameters:
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 21, 2021, 7:35:46 PM
component: f7-card
style:
noShadow: false
padding: 0px
height: 480px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: flame
style:
margin-right: 10px
- component: Label
style:
font-size: 12px
margin-top: 0px
style:
margin-top: 10px
flex-direction: row
display: flex
align-items: center
slots:
default:
slots:
default:
lazy: true
position: absolute
visible: 0
url: "=items['HeishamonOutletDirection'].state === '1' ? '/icon/heizung3.svg?format=svg&anyFormat=true' : '/icon/heizung4.svg?format=svg&anyFormat=true'"
style:
height: 420px
opacity: 0.7
text: "='Vorlauf: '+ items['HeizungKesselThermischTempKesselDegreesSolarVorlauf'].displayState"
style:
position: absolute
top: 259px
left: 128px
font-size: 14px
text: "='Rücklauf: '+ items['HeizungKesselThermischTempKesselDegreesSolarRuecklauf'].displayState"
style:
position: absolute
top: 334px
left: 128px
font-size: 14px
text: "='Vorlauf: '+ items['HeatmeterFlowTemperature'].displayState"
style:
position: absolute
top: 300px
left: 620px
font-size: 14px
text: "='Rücklauf: '+ items['HeatmeterReturnTemperature'].displayState"
style:
position: absolute
top: 334px
left: 620px
font-size: 14px
text: "='Oben: '+ items['HeizungKesselThermischTempKesselDegreesKesselOben'].displayState"
style:
position: absolute
top: 58px
left: 417px
font-size: 14px
text: "='Mitte: '+ items['HeizungKesselThermischTempKesselDegreesKesselMitte'].displayState"
style:
position: absolute
top: 200px
left: 417px
font-size: 14px
text: "='Unten: '+ items['HeizungKesselThermischTempKesselDegreesKesselUnten'].displayState"
style:
position: absolute
top: 320px
left: 417px
font-size: 14px
Hi Boris,
awsome design
can you share the widget code aswell for the overviews?
cheers
Hi yekomS,
the most descriptions in the widgets are in German, but I hope that’s OK. This are the widgets:
uid: Livevisu Wettervorhersage
tags:
- Live
- MainUI
props:
parameters:
- description: Small title on top of the card
label: Title
required: false
type: TEXT
- label: Background Color
required: false
type: TEXT
- label: Backgroundimage
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 15, 2021, 6:18:03 PM
component: f7-card
style:
noShadow: false
class:
- padding: 0px
height: 150px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: cloud_sun
style:
margin-right: 10px
- component: Label
text: "=props.title ? props.title : ''"
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
top: 60px
left: 16px
width: 100%
slots:
default:
- component: f7-row
class:
- text-align-center
slots:
default:
- component: f7-col
style:
background: rgba(233, 196, 106, 0)
slots:
default:
- component: Label
text: Außentemp.
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: Heute
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: =dayjs().add(1,'day').startOf('day').format('dd')
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: =dayjs().add(2,'day').startOf('day').format('dd')
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: =dayjs().add(3,'day').startOf('day').format('dd')
style:
font-weight: 400
margin-bottom: 8px
- component: f7-row
style:
margin-top: 0px
class:
- text-align-center
slots:
default:
- component: f7-col
style:
border-right: 4
slots:
default:
- component: Label
text: =items['KNXHeiz1wireAussenIstTemperatur'].displayState
style:
font-size: 28px
line-height: 25px
- component: f7-col
style:
slots:
default:
f7: "=(items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '01d') ? 'sun_max' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '01n') ? 'moon_stars' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '02d') ? 'cloud_sun' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '02n') ? 'cloud_moon' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '03d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '03n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '04d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '04n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '09d') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '09n') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '10d') ? 'cloud_sun_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '10n') ? 'cloud_moon_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '11d') ? 'cloud_sun_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '11n') ? 'cloud_moon_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '13d') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '13n') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '50d') ? 'cloud_fog' : (items.LokaleWettervorhersageOneCallAPI_forecastTodayIconID.state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
f7: "=(items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '01d') ? 'sun_max' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '01n') ? 'moon_stars' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '02d') ? 'cloud_sun' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '02n') ? 'cloud_moon' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '03d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '03n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '04d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '04n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '09d') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '09n') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '10d') ? 'cloud_sun_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '10n') ? 'cloud_moon_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '11d') ? 'cloud_sun_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '11n') ? 'cloud_moon_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '13d') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '13n') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '50d') ? 'cloud_fog' : (items.LokaleWettervorhersageOneCallAPI_forecastTomorrowIconID.state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
f7: "=(items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '01d') ? 'sun_max' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '01n') ? 'moon_stars' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '02d') ? 'cloud_sun' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '02n') ? 'cloud_moon' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '03d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '03n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '04d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '04n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '09d') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '09n') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '10d') ? 'cloud_sun_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '10n') ? 'cloud_moon_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '11d') ? 'cloud_sun_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '11n') ? 'cloud_moon_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '13d') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '13n') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '50d') ? 'cloud_fog' : (items.LokaleWettervorhersageOneCallAPI_forecastDay2IconID.state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
f7: "=(items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '01d') ? 'sun_max' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '01n') ? 'moon_stars' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '02d') ? 'cloud_sun' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '02n') ? 'cloud_moon' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '03d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '03n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '04d') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '04n') ? 'cloud' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '09d') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '09n') ? 'cloud_heavyrain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '10d') ? 'cloud_sun_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '10n') ? 'cloud_moon_rain' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '11d') ? 'cloud_sun_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '11n') ? 'cloud_moon_bolt' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '13d') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '13n') ? 'cloud_snow' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '50d') ? 'cloud_fog' : (items.LokaleWettervorhersageOneCallAPI_forecastDay3IconID.state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-row
style:
margin-top: 0px
class:
- text-align-center
slots:
default:
- component: f7-col
style:
slots:
default:
- component: Label
text: ""
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items.LokaleWettervorhersageOneCallAPI_forecastTodayMinimaleTemperatur.state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items.LokaleWettervorhersageOneCallAPI_forecastTodayMaximaleTemperatur.state.split(' ')[0] * 1) / 1 + '°'
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items.LokaleWettervorhersageOneCallAPI_forecastTomorrowMinimaleTemperatur.state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items.LokaleWettervorhersageOneCallAPI_forecastTomorrowMaximaleTemperatur.state.split(' ')[0] * 1) / 1 + '°'
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items.LokaleWettervorhersageOneCallAPI_forecastDay2MinimaleTemperatur.state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items.LokaleWettervorhersageOneCallAPI_forecastDay2MaximaleTemperatur.state.split(' ')[0] * 1) / 1 + '°'
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items.LokaleWettervorhersageOneCallAPI_forecastDay3MinimaleTemperatur.state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items.LokaleWettervorhersageOneCallAPI_forecastDay3MaximaleTemperatur.state.split(' ')[0] * 1) / 1 + '°'
- component: oh-link
action: popup
actionModal: ='page:liveWetter'
style:
position: absolute
left: 0px
top: 0px
height: 150px
width: 100%
uid: Livevisu Owntracks Übersicht
tags:
- Live
- MainUI
props:
parameters:
required: false
type: TEXT
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 17, 2021, 11:58:31 AM
component: f7-card
style:
noShadow: false
class:
- padding: 0px
height: 150px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: placemark
style:
margin-right: 10px
- component: Label
text: Wo sind denn alle?
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
top: 60px
left: 16px
width: 100%
--f7-grid-gap: 5px
slots:
default:
- component: f7-row
class:
- text-align-center
slots:
default:
- component: f7-col
style:
slots:
default:
- component: Label
text: Familie
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: Person1
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: Person2
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: Person3
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: Person4
style:
font-weight: 400
margin-bottom: 8px
- component: f7-row
style:
margin-top: 0px
class:
- text-align-center
slots:
default:
- component: f7-col
style:
border-right: 4
slots:
default:
action: navigate
actionPage: page:owntracksFamilie
actionPageTransition: f7-dive
url: /static/icons/familie.png
style:
height: 40px
- component: f7-col
style:
slots:
default:
action: popup
actionModal: page:owntracksPerson1
actionModalTransition: f7-dive
url: /static/icons/Person1.png
style:
height: 40px
- component: f7-col
style:
slots:
default:
action: popup
actionModal: page:owntracksPerson2
url: /static/icons/Person2.png
style:
height: 40px
- component: f7-col
style:
slots:
default:
action: popup
actionModal: page:owntracksPerson3
url: /static/icons/Person3.png
style:
height: 40px
- component: f7-col
style:
slots:
default:
action: popup
actionModal: page:owntracksPerson4
url: /static/icons/Person4.png
style:
height: 40px
- component: f7-row
style:
margin-top: 0px
class:
- text-align-center
slots:
default:
- component: f7-col
style:
slots:
default:
- component: Label
text: ""
- component: f7-col
style:
slots:
default:
- component: Label
text: =items['hPerson1PositionLastUpdateSince'].state
- component: f7-col
style:
slots:
default:
- component: Label
text: =items['hPerson2PositionLastUpdateSince'].state
- component: f7-col
style:
slots:
default:
- component: Label
text: =items['hPerson3PositionLastUpdateSince'].state
- component: f7-col
style:
slots:
default:
- component: Label
text: =items['hPerson4PositionLastUpdateSince'].state
The car and the mower widget are nearly the same, just with different pictures and items. This is the mover widget:
uid: Livevisu Robaert
tags:
- Live
- MainUI
props:
parameters:
required: false
type: TEXT
- description: Popup Seite
label: Page ID
required: false
parameterGroups: []
timestamp: Dec 22, 2021, 5:01:45 PM
component: f7-card
style:
noShadow: false
padding: 0px
height: 360px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: tree
style:
margin-right: 10px
- component: Label
text: Robärt
style:
font-size: 12px
margin-top: 0px
style:
display: flex
justify-content: center
align-content: center
margin-top: 35px
slots:
default:
url: ='/static/icons/robaert_schatten.png'
style:
width: 280px
margin: 0px
style:
display: flex
slots:
default:
style:
margin-top: 60px
width: 250px
display: flex
flex-direction: column
slots:
default:
- component: f7-row
slots:
default:
- component: f7-col
width: 70
slots:
default:
- component: Label
text: Status
- component: f7-col
width: 30
slots:
default:
- component: Label
text: =items['GardenaRobart_Status'].state
- component: f7-row
slots:
default:
- component: f7-col
width: 70
slots:
default:
- component: Label
text: Ladezustand
- component: f7-col
width: 30
slots:
default:
- component: Label
text: =items['GardenaRobart_Batterieladung'].displayState
- component: f7-row
slots:
default:
- component: f7-col
width: 70
slots:
default:
- component: Label
text: Aktivität
- component: f7-col
width: 30
slots:
default:
- component: Label
text: =items['GardenaRobart_Aktivitat'].displayState
- component: f7-row
slots:
default:
- component: f7-col
width: 70
slots:
default:
- component: Label
text: Verbindungsstatus
- component: f7-col
width: 30
slots:
default:
- component: Label
text: =items['GardenaRobart_Verbinungsstatus'].state
action: popup
actionModal: ='page:' + props.page
style:
position: absolute
left: 0px
top: 0px
height: 360px
width: 100%
uid: Livevisu Kamera Eingang
tags:
- Live
- MainUI
props:
parameters:
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 17, 2021, 9:56:37 AM
component: f7-card
style:
noShadow: false
padding: 0px
height: 360px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: videocam_fill
style:
margin-right: 10px
- component: Label
text: Kamera Eingang
style:
font-size: 12px
margin-top: 0px
style:
display: flex
margin-top: 20px
slots:
default:
url: ='http://192.x.x.x:8081/ipcamera.mjpeg'
action: popup
actionModal: ='page:liveKamera'
style:
height: 310px
uid: Livevisu Aussenhaut Übersicht
tags:
- Live
- MainUI
props:
parameters:
required: false
type: TEXT
label: Page ID
required: false
- context: item
label: Türgruppe (Number)
required: false
type: TEXT
- context: item
label: Schlossruppe (Number)
required: false
type: TEXT
- context: item
label: Fenstergruppe (Number)
required: false
type: TEXT
- context: item
label: Nebeneingangstürschloss (Contact)
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 12, 2021, 1:16:06 PM
component: f7-card
style:
noShadow: false
padding: 0px
background-color: "=items[props.window_numbers].state == 0 ? (items[props.door_numbers].state == 0 ? (items[props.neeingang_cont].state == 'OPEN' ? (props.bgcolor ? props.bgcolor : '') : 'orange' ) : 'orange' ) : 'orange'"
height: 150px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: info_circle
style:
margin-right: 10px
- component: Label
text: Verschluss Außenhaut
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
bottom: -90px
left: 10px
flex-direction: row
display: flex
slots:
default:
f7: house
style:
position: absolute
top: 60px
right: 15px
slots:
default:
- component: f7-row
class:
- justify-content-right
- align-items-center
- align-content-center
slots:
default:
- component: f7-col
slots:
default:
url: "=items[props.door_numbers].state > 0 ? '/static/icons/tuer-offen.svg' : '/static/icons/tuer-geschlossen.svg'"
style:
height: 25px
margin-bottom: 3px
- component: f7-col
slots:
default:
- component: Label
text: =items[props.door_numbers].state
style:
margin-left: 17px
margin-bottom: 7px
- component: f7-row
class:
slots:
default:
- component: f7-col
slots:
default:
f7: "=items[props.lock_numbers].state < 2 ? 'lock_open' : 'lock_fill'"
style:
color: black
margin-bottom: 8px
- component: f7-col
slots:
default:
- component: Label
text: =2 - items[props.lock_numbers].state
style:
margin-left: 17px
margin-bottom: 7px
- component: f7-row
class:
slots:
default:
- component: f7-col
slots:
default:
url: "=items[props.window_numbers].state > 0 ? '/static/icons/fenster-offen.svg' : '/static/icons/fenster-geschlossen.svg'"
style:
height: 25px
- component: f7-col
slots:
default:
- component: Label
text: =items[props.window_numbers].state
style:
margin-left: 17px
margin-bottom: 7px
action: navigate
actionPage: ='page:' + props.page
style:
position: absolute
left: 0px
top: 0px
height: 150px
width: 100%
The following widget ist used for failure and alarm
uid: Livevisu StörungsWarnungskarte
tags:
- Live
- MainUI
props:
parameters:
- label: Gerätebezeichung
required: false
type: TEXT
- label: F7 Icon Header
required: false
type: TEXT
- label: Störungsbezeichnung
required: false
type: TEXT
label: Hintergrundfarbe Normaler Zustand
required: false
type: TEXT
label: Hintergrundfarbe Aktivierter Zustand
required: false
type: TEXT
- label: F7 Icon Normaler Zustand
required: false
type: TEXT
- label: F7 Icon Aktivierter Zustand
required: false
type: TEXT
- context: item
label: Switch
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 15, 2021, 1:37:43 PM
component: f7-card
style:
noShadow: false
padding: 0px
background-color: "=props.bgcolor_open ? (items[props.switch].state == 'ON' ? 'red' : props.bgcolor ? props.bgcolor : '') : props.bgcolor ? props.bgcolor : ''"
height: 120px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: =props.icon_header
style:
margin-right: 10px
visible: "=props.icon_header ? true : false"
- component: Label
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
bottom: -15px
left: 16px
flex-direction: row
slots:
default:
- component: Label
text: "=props.stoerbez ? props.stoerbez : 'Set Props'"
style:
font-size: 17px
font-weight: 600
margin-left: 0px
margin-top: 0px
style:
position: absolute
bottom: -53px
left: 16px
flex-direction: row
slots:
default:
- component: Label
text: =items[props.switch].displayState
f7: "=items[props.switch].state == 'ON' ? props.icon_active : props.icon"
style:
position: absolute
bottom: -70px
right: 20px
opacity: 0.7
The following widget ist used for heating, shading and irrigation
uid: Livevisu Linkkarte mit Status Übersicht
tags:
- Live
- MainUI
props:
parameters:
- label: Title
required: false
type: TEXT
- label: f7 Icon Titel
required: false
type: TEXT
- label: f7 Icon normal
required: false
type: TEXT
- label: Status Präfix
required: false
type: TEXT
- label: Status Suffix
required: false
type: TEXT
- context: item
label: Statusitem
required: false
type: TEXT
required: false
type: TEXT
label: Hintergrundfarbe bei Statusitem > 0 oder ON
required: false
type: TEXT
label: Page ID
required: false
parameterGroups: []
timestamp: Dec 13, 2021, 2:27:25 PM
component: f7-card
style:
noShadow: false
padding: 0px
background-color: "=items[props.status].state > 0 ? (props.bgcolor_active ? props.bgcolor_active : '') : (items[props.status].state == 'ON' ? (props.bgcolor_active ? props.bgcolor_active : '') : (props.bgcolor ? props.bgcolor : ''))"
height: 150px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: "=props.icon_titel ? props.icon_titel : ''"
style:
margin-right: 10px
- component: Label
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
bottom: -90px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: "=props.icon ? props.icon : ''"
style:
position: absolute
top: 128px
right: 0px
slots:
default:
- component: Label
text: "=props.praefix ? (props.suffix ? props.praefix + items[props.status].displayState + props.suffix : props.praefix + items[props.status].displayState ) : (props.suffix ? items[props.status].displayState + props.suffix : items[props.status].displayState )"
style:
margin-right: 10px
action: navigate
style:
position: absolute
left: 0px
top: 0px
height: 150px
width: 100%
uid: Livevisu Raumkarte
tags:
- Live
- MainUI
props:
parameters:
- label: Ortsbezeichnung
required: false
type: TEXT
- description: Icon Name ohne ".png", im Ordner static/icons/
label: Icon
required: false
type: TEXT
- description: HEX or rgba
required: false
type: TEXT
label: Page ID
required: false
- context: item
label: Licht (Number)
required: false
type: TEXT
- context: item
label: Steckdosen (Number)
required: false
type: TEXT
- context: item
label: Rolladengruppe (Number)
required: false
type: TEXT
- context: item
required: false
type: TEXT
- context: item
label: Stellgröße
required: false
type: TEXT
- context: item
label: Ist-Temperatur
required: false
type: TEXT
- context: item
label: Soll-Temperatur
required: false
type: TEXT
- context: item
label: Fenstergruppe (Contact)
required: false
type: TEXT
- context: item
label: Türstatus
required: false
type: TEXT
- context: item
label: Türschloss Status
required: false
type: TEXT
timestamp: Dec 9, 2021, 7:42:02 AM
component: f7-card
style:
noShadow: false
class:
- padding: 0px
height: 125px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 50px
slots:
default:
- component: Label
text: "=props.ort ? props.ort : 'Set Props'"
style:
font-size: 17px
font-weight: 600
margin-left: 0px
margin-top: 0px
style:
position: absolute
bottom: -37px
left: 16px
slots:
default:
style:
--f7-chip-bg-color: rgba(255, 255, 255, 0)
visible: "=props.lights ? true : false"
text: "=(Number(items[props.lights].state) > 0) ? items[props.lights].state : ''"
iconColor: "=themeOptions.dark === 'dark' ? 'white' : 'black'"
iconF7: "=(Number(items[props.lights].state) > 0) ? 'lightbulb' : 'lightbulb_slash'"
iconSize: 18
- component: f7-badge
style:
--f7-badge-bg-color: rgba(255, 255, 255, 0)
visible: "=props.power ? true : false"
slots:
default:
url: "=items[props.power].state > 0 ? '/static/icons/steckdose.svg' : '/static/icons/steckdose_slash.svg'"
style:
height: 18px
style:
--f7-chip-padding-horizontal: 5px
text: "=items[props.power].state > 0 ? items[props.power].state : ''"
style:
--f7-chip-padding-horizontal: 10px
visible: "=props.heating ? (items[props.heating].state > 0 ? true : false) : false"
text: "=items[props.heating].state > 0 ? '' : ''"
iconF7: flame
iconSize: 18
style:
padding-right: 13px
visible: "=props.door_state ? true : false"
text: "=items[props.door_state].state === 'ON' ? '' : ''"
slots:
default:
url: "=items[props.door_state].state === 'OPEN' ? '/static/icons/tuer-offen.svg' : '/static/icons/tuer-geschlossen.svg'"
style:
height: 18px
style:
visible: "=items[props.windows].state === 'OPEN' ? true : false"
slots:
default:
url: ='/static/icons/fenster-offen.svg'
style:
height: 18px
style:
--f7-chip-padding-horizontal: 8px
text: "=items[props.windows_numbers].state > 0 ? items[props.windows_numbers].state : ''"
style:
visible: "=props.door_lock ? true : false"
text: "=items[props.door_lock].state === 'CLOSED' ? '' : ''"
iconF7: "=items[props.door_lock].state === 'CLOSED' ? 'lock_open' : 'lock'"
iconSize: 18
style:
visible: "=props.blinds_closed ? (items[props.blinds_closed].state > 0 ? true : false) : false"
slots:
default:
url: ='/static/icons/rolladen.svg'
style:
height: 18px
style:
text: "=items[props.blinds_closed].state == 0 ? 'oben' : Number(Math.floor(items[props.blinds_closed].state * 100)) + ' %'"
style:
position: absolute
bottom: -65px
left: 16px
slots:
default:
style:
visible: "=props.temp ? true : false"
text: "=(items[props.temp].displayState ? items[props.temp].displayState : items[props.temp].displayState) + (props.settemp ? ' (' + items[props.settemp].displayState + ')' : '')"
iconF7: thermometer
iconSize: 18
url: ='/static/icons/' + props.iconimage + '.png'
style:
position: absolute
left: 16px
top: 10px
height: 25px
opacity: 0.7
visible: "=props.iconimage ? true : false"
action: navigate
style:
position: absolute
left: 0px
top: 0px
height: 110px
width: 100%
First of all @Integer thanks for your nice work !
I’ve updated your weather widget to allow configuration through the props of all used data.
If the names of the items in your system are not identically as in the code, you get ? as also shown in sceenshot from @BG56 .
Bellow the updated code.
Also a question : Where do I need to put the OneCall API Thing ? Any specific file location (I’m using RPI 3). Would be great to get this also working
uid: Cell_Weather_2
#Added forecast data with props to accomodate with individual coding
tags: []
props:
parameters:
label: Title
required: false
type: TEXT
required: false
type: TEXT
required: false
type: TEXT
- context: item
description: Item of Forecast today IconID
label: Forecast_Today_IconID
required: false
type: TEXT
- context: item
description: Item of Forecast tomorrow IconID
label: Forecast_Tomorrow_IconID
required: false
type: TEXT
- context: item
description: Item of Forecast Day2 IconID
label: Forecast_Day2_IconID
required: false
type: TEXT
- context: item
description: Item of Forecast Day3 IconID
label: Forecast_Day3_IconID
required: false
type: TEXT
- context: item
description: Item of Forecast Day4 IconID
label: Forecast_Day4_IconID
required: false
type: TEXT
- context: item
description: Item of Forecast today MinTemp
label: Forecast_Today_MinTemp
required: false
type: TEXT
- context: item
description: Item of Forecast tomorrow MinTemp
label: Forecast_Tomorrow_MinTemp
required: false
type: TEXT
- context: item
description: Item of Forecast Day2 MinTemp
label: Forecast_Day2_MinTemp
required: false
type: TEXT
- context: item
description: Item of Forecast Day3 MinTemp
label: Forecast_Day3_MinTemp
required: false
type: TEXT
- context: item
description: Item of Forecast Day4 MinTemp
label: Forecast_Day4_MinTemp
required: false
type: TEXT
- context: item
description: Item of Forecast today MaxTemp
label: Forecast_Today_MaxTemp
required: false
type: TEXT
- context: item
description: Item of Forecast tomorrow MaxTemp
label: Forecast_Tomorrow_MaxTemp
required: false
type: TEXT
- context: item
description: Item of Forecast Day2 MaxTemp
label: Forecast_Day2_MaxTemp
required: false
type: TEXT
- context: item
description: Item of Forecast Day3 MaxTemp
label: Forecast_Day3_MaxTemp
required: false
type: TEXT
- context: item
description: Item of Forecast Day4 MaxTemp
label: Forecast_Day4_MaxTemp
required: false
type: TEXT
parameterGroups: []
timestamp: Dec 25, 2021, 2:41:53 PM
component: f7-card
style:
noShadow: false
class:
- padding: 0px
height: 150px
margin-left: 5px
margin-right: 5px
slots:
content:
style:
position: absolute
top: -5px
left: 16px
flex-direction: row
display: flex
slots:
default:
f7: cloud_sun
style:
margin-right: 10px
- component: Label
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
top: 60px
left: 16px
width: 100%
slots:
default:
- component: f7-row
class:
- text-align-center
slots:
default:
- component: f7-col
style:
slots:
default:
- component: Label
text: Vandaag
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
style:
font-weight: 400
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
- component: Label
text: =dayjs().add(4,'day').startOf('day').format('dd')
style:
font-weight: 400
margin-bottom: 8px
- component: f7-row
style:
margin-top: 0px
class:
- text-align-center
slots:
default:
- component: f7-col
style:
slots:
default:
f7: "=(items[props.item_Forecast_Today_IconID].state === '01d') ? 'sun_max' : (items[props.item_Forecast_Today_IconID].state === '01n') ? 'moon_stars' : (items[props.item_Forecast_Today_IconID].state === '02d') ? 'cloud_sun' : (items[props.item_Forecast_Today_IconID].state === '02n') ? 'cloud_moon' : (items[props.item_Forecast_Today_IconID].state === '03d') ? 'cloud' : (items[props.item_Forecast_Today_IconID].state === '03n') ? 'cloud' : (items[props.item_Forecast_Today_IconID].state === '04d') ? 'cloud' : (items[props.item_Forecast_Today_IconID]d.state === '04n') ? 'cloud' : (items[props.item_Forecast_Today_IconID].state === '09d') ? 'cloud_heavyrain' : (items[props.item_Forecast_Today_IconID].state === '09n') ? 'cloud_heavyrain' : (items[props.item_Forecast_Today_IconID].state === '10d') ? 'cloud_sun_rain' : (items[props.item_Forecast_Today_IconID].state === '10n') ? 'cloud_moon_rain' : (items[props.item_Forecast_Today_IconID].state === '11d') ? 'cloud_sun_bolt' : (items[props.item_Forecast_Today_IconID].state === '11n') ? 'cloud_moon_bolt' : (items[props.item_Forecast_Today_IconID].state === '13d') ? 'cloud_snow' : (items[props.item_Forecast_Today_IconID].state === '13n') ? 'cloud_snow' : (items[props.item_Forecast_Today_IconID].state === '50d') ? 'cloud_fog' : (items[props.item_Forecast_Today_IconID].state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
f7: "=(items[props.item_Forecast_Tomorrow_IconID].state === '01d') ? 'sun_max' : (items[props.item_Forecast_Tomorrow_IconID].state === '01n') ? 'moon_stars' : (items[props.item_Forecast_Tomorrow_IconID].state === '02d') ? 'cloud_sun' : (items[props.item_Forecast_Tomorrow_IconID].state === '02n') ? 'cloud_moon' : (items[props.item_Forecast_Tomorrow_IconID].state === '03d') ? 'cloud' : (items[props.item_Forecast_Tomorrow_IconID].state === '03n') ? 'cloud' : (items[props.item_Forecast_Tomorrow_IconID].state === '04d') ? 'cloud' : (items[props.item_Forecast_Tomorrow_IconID].state === '04n') ? 'cloud' : (items[props.item_Forecast_Tomorrow_IconID].state === '09d') ? 'cloud_heavyrain' : (items[props.item_Forecast_Tomorrow_IconID].state === '09n') ? 'cloud_heavyrain' : (items[props.item_Forecast_Tomorrow_IconID].state === '10d') ? 'cloud_sun_rain' : (items[props.item_Forecast_Tomorrow_IconID].state === '10n') ? 'cloud_moon_rain' : (items[props.item_Forecast_Tomorrow_IconID].state === '11d') ? 'cloud_sun_bolt' : (items[props.item_Forecast_Tomorrow_IconID].state === '11n') ? 'cloud_moon_bolt' : (items[props.item_Forecast_Tomorrow_IconID].state === '13d') ? 'cloud_snow' : (items[props.item_Forecast_Tomorrow_IconID].state === '13n') ? 'cloud_snow' : (items[props.item_Forecast_Tomorrow_IconID].state === '50d') ? 'cloud_fog' : (items[props.item_Forecast_Tomorrow_IconID].state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
f7: "=(items[props.item_Forecast_Day2_IconID].state === '01d') ? 'sun_max' : (items[props.item_Forecast_Day2_IconID].state === '01n') ? 'moon_stars' : (items[props.item_Forecast_Day2_IconID].state === '02d') ? 'cloud_sun' : (items[props.item_Forecast_Day2_IconID].state === '02n') ? 'cloud_moon' : (items[props.item_Forecast_Day2_IconID].state === '03d') ? 'cloud' : (items[props.item_Forecast_Day2_IconID].state === '03n') ? 'cloud' : (items[props.item_Forecast_Day2_IconID].state === '04d') ? 'cloud' : (items[props.item_Forecast_Day2_IconID].state === '04n') ? 'cloud' : (items[props.item_Forecast_Day2_IconID].state === '09d') ? 'cloud_heavyrain' : (items[props.item_Forecast_Day2_IconID].state === '09n') ? 'cloud_heavyrain' : (items[props.item_Forecast_Day2_IconID].state === '10d') ? 'cloud_sun_rain' : (items[props.item_Forecast_Day2_IconID].state === '10n') ? 'cloud_moon_rain' : (items[props.item_Forecast_Day2_IconID].state === '11d') ? 'cloud_sun_bolt' : (items[props.item_Forecast_Day2_IconID].state === '11n') ? 'cloud_moon_bolt' : (items[props.item_Forecast_Day2_IconID].state === '13d') ? 'cloud_snow' : (items[props.item_Forecast_Day2_IconID].state === '13n') ? 'cloud_snow' : (items[props.item_Forecast_Day2_IconID].state === '50d') ? 'cloud_fog' : (items[props.item_Forecast_Day2_IconID].state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
f7: "=(items[props.item_Forecast_Day3_IconID].state === '01d') ? 'sun_max' : (items[props.item_Forecast_Day3_IconID].state === '01n') ? 'moon_stars' : (items[props.item_Forecast_Day3_IconID].state === '02d') ? 'cloud_sun' : (items[props.item_Forecast_Day3_IconID].state === '02n') ? 'cloud_moon' : (items[props.item_Forecast_Day3_IconID].state === '03d') ? 'cloud' : (items[props.item_Forecast_Day3_IconID].state === '03n') ? 'cloud' : (items[props.item_Forecast_Day3_IconID].state === '04d') ? 'cloud' : (items[props.item_Forecast_Day3_IconID].state === '04n') ? 'cloud' : (items[props.item_Forecast_Day3_IconID].state === '09d') ? 'cloud_heavyrain' : (items[props.item_Forecast_Day3_IconID].state === '09n') ? 'cloud_heavyrain' : (items[props.item_Forecast_Day3_IconID].state === '10d') ? 'cloud_sun_rain' : (items[props.item_Forecast_Day3_IconID].state === '10n') ? 'cloud_moon_rain' : (items[props.item_Forecast_Day3_IconID].state === '11d') ? 'cloud_sun_bolt' : (items[props.item_Forecast_Day3_IconID].state === '11n') ? 'cloud_moon_bolt' : (items[props.item_Forecast_Day3_IconID].state === '13d') ? 'cloud_snow' : (items[props.item_Forecast_Day3_IconID].state === '13n') ? 'cloud_snow' : (items[props.item_Forecast_Day3_IconID].state === '50d') ? 'cloud_fog' : (items[props.item_Forecast_Day3_IconID].state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-col
style:
slots:
default:
f7: "=(items[props.item_Forecast_Day4_IconID].state === '01d') ? 'sun_max' : (items[props.item_Forecast_Day4_IconID].state === '01n') ? 'moon_stars' : (items[props.item_Forecast_Day4_IconID].state === '02d') ? 'cloud_sun' : (items[props.item_Forecast_Day4_IconID].state === '02n') ? 'cloud_moon' : (items[props.item_Forecast_Day4_IconID].state === '03d') ? 'cloud' : (items[props.item_Forecast_Day4_IconID].state === '03n') ? 'cloud' : (items[props.item_Forecast_Day4_IconID].state === '04d') ? 'cloud' : (items[props.item_Forecast_Day4_IconID].state === '04n') ? 'cloud' : (items[props.item_Forecast_Day4_IconID].state === '09d') ? 'cloud_heavyrain' : (items[props.item_Forecast_Day4_IconID].state === '09n') ? 'cloud_heavyrain' : (items[props.item_Forecast_Day4_IconID].state === '10d') ? 'cloud_sun_rain' : (items[props.item_Forecast_Day4_IconID].state === '10n') ? 'cloud_moon_rain' : (items[props.item_Forecast_Day4_IconID].state === '11d') ? 'cloud_sun_bolt' : (items[props.item_Forecast_Day4_IconID].state === '11n') ? 'cloud_moon_bolt' : (items[props.item_Forecast_Day4_IconID].state === '13d') ? 'cloud_snow' : (items[props.item_Forecast_Day4_IconID].state === '13n') ? 'cloud_snow' : (items[props.item_Forecast_Day4_IconID].state === '50d') ? 'cloud_fog' : (items[props.item_Forecast_Day4_IconID].state === '50n') ? 'cloud_fog' : '?'"
style:
margin-bottom: 8px
- component: f7-row
style:
margin-top: 0px
class:
- text-align-center
slots:
default:
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items[props.item_Forecast_Today_MinTemp].state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items[props.item_Forecast_Today_MaxTemp].state.split(' ')[0] * 1) / 1 + '°'
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items[props.item_Forecast_Tomorrow_MinTemp].state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items[props.item_Forecast_Tomorrow_MaxTemp].state.split(' ')[0] * 1) / 1 + '°'
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items[props.item_Forecast_Day2_MinTemp].state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items[props.item_Forecast_Day2_MaxTemp].state.split(' ')[0] * 1) / 1 + '°'
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items[props.item_Forecast_Day3_MinTemp].state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items[props.item_Forecast_Day3_MaxTemp].state.split(' ')[0] * 1) / 1 + '°'
- component: f7-col
style:
slots:
default:
- component: Label
text: =Math.round(items[props.item_Forecast_Day4_MinTemp].state.split(' ')[0] * 1) / 1 + '° / ' + Math.round(items[props.item_Forecast_Day4_MaxTemp].state.split(' ')[0] * 1) / 1 + '°'
Love the simplicity of your widgets!
With the Climate/thermostat one, do you know how I would modify in a way that clicking the button turns on the main air conditioning switch?
Hi Boris,
thx a lot
btw: deutsch ist kein Problem
