With v3.4 there is an @ operator available which shows displayState if available and state if not available.
@(items[props.status])
It helped tidying up my widgetsđ
mmm iâve tried different ways but it doesnât work for me
iâm running OH snapshot 4.0.0
can you tell me why?
thanks a lot!
- component: Label
style:
color: black
margin-left: 2px
z-index: 98
text: @(items[props.opstateItem])
Does it not need to be
text: =@(items[props.opstateItem])
Iâm currently on stable 3.3.0
iâve tried but the state is reported as â-â.
that item should have both state and displayStateâŠ
Yes, that is correct.
And you need to have minimum version 3.4 M6.
actually iâm testing on 4.0.0 snapshot and still doesnât work for me
You should not include the items
object. The @
operator (and the @@
operator which forces just the state instead of the displayState
) acts directly on the item name string. So, in this case:
text: =@(props.opstateItem)
As always,great answer and also great explanation.
Thank you so much Justin!
Technically those are the 2 equivalences:
@<name> <=> items[<name>].displayState !== undefined ? items[<name>].displayState : items[<name>].state
@@<name> <=> items[<name>].state
et @@
are unary operators so due to their precedences parentheses may be useful, but not always.
For instance @props.itemName
alone is fine, but beware of the differences between:
@@itemsPrefix + '_Suffix` <=> items[itemsPrefix].state + '_Suffix'
and
@@(itemsPrefix + '_Suffix`) <=> items[itemsPrefix + '_Suffix'].state
Hi Andras,
many thanks for you Examples, especially the room Card. Quite useful as I was searching for a card that could open a group actionâŠ
bkumio
Finally I feel comfortable enough to post my example so far. Have had some great inspiration from @Integer and @BG56 but Iâm also inspired by the great design of @Dimitris in the new main widget topic. Thank you all.
I really like the simpleness of the Apple Home app and I try to copy that part, too. When Items are off they are semi-transparent and when one they become white. In some cases I will enable them to become a special color, for example the AlarmPartitionStatus may become red when there is an alarm.
The LightControl widget can be collapsed and expanded by clicking on the title and depending on the set properties will display a slider to dim, two sliders for dim and white tone or will display the color control with three sliders and a set of pre-defined colors.
My HarmonyControl will show the current activity when on and it then also features an off button. It can be expanded when off, but it automatically expanded when on.
Iâm currently working on a new widget for displaying status from the thermostate and a player widget for my future Chromecast.
Would you mind sharing the code of your widgets ?
Sure!
LightControl:
uid: LightControl
tags: []
props:
parameters:
- description: Header icon
label: Icon
required: false
type: TEXT
groupName: header
- description: Header text
label: Header
required: false
type: TEXT
groupName: header
- context: item
description: Item to control on/off
label: Item ON OFF
required: true
type: TEXT
groupName: setup
- context: item
description: Item to control brightness
label: Item brightness
required: false
type: TEXT
groupName: setup
- context: item
description: Item to control color temperature
label: Item light temperature
required: false
type: TEXT
groupName: setup
- context: item
label: Item light color
required: false
type: TEXT
groupName: setup
parameterGroups:
- name: header
description: Widget general settings
- name: setup
description: Widget specific settings
timestamp: Dec 29, 2022, 10:55:04 PM
component: f7-card
style:
background-color: "=items[props.itemSwitch].state === 'ON' ? 'rgba(255, 255, 255, 1)' : 'rgba(34, 34, 34, 0.3)'"
border-radius: 15px
box-shadow: 0px 0px
margin: 5px 5px
slots:
content:
- component: f7-row
style:
justify-content: left
slots:
default:
- component: oh-image
url: ='/static/icons/' + props.iconHeader + '.svg'
style:
height: 25px
margin-right: 10px
filter: '=items[props.itemSwitch].state === "ON" ? "brightness(1)" : "brightness(0) invert(1)"'
visible: "=props.iconHeader ? true : false"
- component: Label
text: "=props.header ? props.header : 'Set header title'"
style:
font-size: var(--f7-card-header-font-size)
font-weight: var(--f7-card-header-font-weight)
color: '=items[props.itemSwitch].state === "ON" ? "black" : "white"'
--f7-list-item-after-text-color: '=items[props.itemSwitch].state === "ON" ? "black" : "white"'
- component: oh-toggle
item: =props.itemSwitch
style:
position: absolute
top: 20px
right: 20px
z-index: 100
--f7-toggle-active-color: "#F8BB00"
--f7-toggle-inactive-color: "#ccc"
- component: oh-link
action: variable
actionVariable: visiblePart
actionVariableValue: "=vars.visiblePart === true ? false : true"
style:
position: absolute
top: 0
left: 0
height: 55px
width: 100%
actionPosition: center
- component: f7-row
style:
justify-content: center
margin-top: 25px
visible: =vars.visiblePart === true && props.itemBrightness !== Null
slots:
default:
- component: oh-slider
item: =props.itemBrightness
min: 0
max: 100
style:
width: calc(100% - 20px)
--f7-range-bar-size: 10px
--f7-range-bar-border-radius: 8px
--f7-range-knob-size: 20px
--f7-range-knob-box-shadow: 0 2px 4px rgba(0, 0, 0, 0.3)
- component: f7-row
style:
margin-top: 10px
visible: =vars.visiblePart === true && props.itemLightTemperature !== Null
slots:
default:
item: =props.itemLightTemperature
min: 0
max: 100
style:
--f7-range-bar-border-radius: 10px
--f7-range-bar-active-bg-color: transparent
--f7-range-bar-bg-color: linear-gradient(to right, rgba(215, 226, 255), rgba(224, 238, 238),rgba(255, 215, 44, 0.5),rgba(255, 215, 44, 0.8))
--f7-range-label-text-color: black
- component: f7-row
style:
margin-top: 10px
--f7-range-bar-bg-color: linear-gradient(to right, rgba(246,158,81,0.8), rgba(246,158,81,0))
--f7-color-picker-slider-size: 10px
--f7-color-picker-slider-knob-size: 20px
width: 100%
visible: =vars.visiblePart === true && props.itemColor !== Null
slots:
default:
- component: oh-colorpicker
color: red
label: true
item: =props.itemColor
modules:
- hsb-sliders
- component: f7-row
style:
margin-top: 10px
slots:
default:
- component: oh-button
iconColor: yellow
iconF7: app_fill
iconSize: 25
action: command
actionItem: =props.itemColor
actionCommand: 60,100,100
style:
padding: 0px 5px
height: 35px
background: transparent
iconColor: orange
iconF7: app_fill
iconSize: 25
action: command
actionCommand: 30,100,100
style:
padding: 0px 5px
height: 35px
iconColor: deeporange
iconF7: app_fill
iconSize: 25
action: command
actionCommand: 15,100,100
style:
padding: 0px 5px
height: 35px
iconColor: red
iconF7: app_fill
iconSize: 25
action: command
actionCommand: 0,100,100
style:
padding: 0px 5px
height: 35px
iconColor: purple
iconF7: app_fill
iconSize: 25
action: command
actionCommand: 300,100,100
style:
padding: 0px 5px
height: 35px
iconColor: blue
iconF7: app_fill
iconSize: 25
action: command
actionCommand: 240,100,100
style:
padding: 0px 5px
height: 35px
iconColor: lightblue
iconF7: app_fill
iconSize: 25
action: command
actionCommand: 180,100,100
style:
padding: 0px 5px
height: 35px
iconColor: green
iconF7: app_fill
iconSize: 25
action: command
actionCommand: 120,100,100
style:
padding: 0px 5px
height: 35px
SimpleSwitch:
uid: SimpleSwitch
tags: []
props:
parameters:
label: Icon
required: false
type: TEXT
groupName: header
label: Header
required: false
type: TEXT
groupName: header
- context: item
label: Item
required: false
type: TEXT
groupName: setup
parameterGroups:
- name: header
- name: setup
timestamp: Dec 29, 2022, 10:55:19 PM
component: f7-card
style:
border-radius: 15px
box-shadow: 0px 0px
margin: 5px 5px
slots:
content:
- component: f7-row
style:
slots:
default:
style:
height: 25px
margin-right: 10px
- component: Label
style:
- component: f7-row
style:
margin-top: 25px
slots:
default:
style:
Let me double check my HarmonyControl first before I post it here. Want to make sure that itâs fully functioning
Very nice! Looks like the one iâve made too
I will take from your widget, the preset line colors,i forgot to add that could be useful.
Thanks!
Here is the code for the Harmony widget:
uid: HarmonyControl
tags: []
props:
parameters:
label: Icon
required: false
type: TEXT
groupName: header
label: Header
required: false
type: TEXT
groupName: header
- context: item
description: Item to control Harmony
label: Item current activity
required: true
type: TEXT
groupName: setup
- description: 'Use JSON format [{"label": "Label", "icon": "Icon", "command": "Command to send"}, ...}]'
label: Activities
required: true
type: TEXT
groupName: setup
parameterGroups:
- name: header
- name: setup
timestamp: Jan 8, 2023, 10:53:50 PM
component: f7-card
style:
background-color: "=items[props.itemCurrentActivity].state !== 'PowerOff' ? 'rgba(255, 255, 255, 1)' : 'rgba(34, 34, 34, 0.3)'"
border-radius: 15px
box-shadow: 0px 0px
margin: 5px 5px
slots:
content:
- component: f7-row
style:
slots:
default:
style:
height: 25px
margin-right: 10px
filter: '=items[props.itemCurrentActivity].state !== "PowerOff" ? "brightness(1)" : "brightness(0) invert(1)"'
- component: Label
style:
color: '=items[props.itemCurrentActivity].state !== "PowerOff" ? "black" : "white"'
--f7-list-item-after-text-color: '=items[props.itemCurrentActivity].state !== "PowerOff" ? "black" : "white"'
action: command
actionItem: =props.itemCurrentActivity
actionCommand: PowerOff
actionFeedback: Uitgeschakeld
style:
position: absolute
top: 20px
right: 20px
z-index: 100
visible: "=items[props.itemCurrentActivity].state !== 'PowerOff' ? true : false"
slots:
default:
url: ='/static/icons/power-off.svg'
style:
height: 18px
action: variable
style:
position: absolute
top: 0
left: 0
height: 55px
width: 100%
- component: f7-row
style:
margin-top: 10px
margin-bottom: 10px
slots:
default:
- component: f7-chip
text: "=items[props.itemCurrentActivity].state === 'PowerOff' ? 'Uitgeschakeld' : items[props.itemCurrentActivity].state"
style:
background-color: "=items[props.itemCurrentActivity].state !== 'PowerOff' ? '#F8BB00' : '#8c8c8c'"
color: "#fff"
margin-left: 35px
font-size: 10px
height: 18px
- component: f7-row
visible: "=items[props.itemCurrentActivity].state !== 'PowerOff' || vars.visiblePart === true ? true : false"
style:
margin-top: 20px
class:
- text-align-center
slots:
default:
- component: oh-repeater
for: activity
sourceType: array
fragment: true
in: '=JSON.parse(props.activities)'
slots:
default:
- component: f7-col
slots:
default:
action: command
actionCommand: =loop.activity.command
actionFeedback: =loop.activity.label + " gestart"
slots:
default:
url: ='/static/icons/' + loop.activity.icon + '.svg'
style:
height: 18px
- component: f7-row
style:
margin-top: 10px
class:
- text-align-center
slots:
default:
for: activity
sourceType: array
fragment: true
slots:
default:
- component: f7-col
slots:
default:
action: command
slots:
default:
- component: Label
text: =loop.activity.label
style:
font-size: 11px
And Iâve got an âapplianceâ widget as well. I use it in conjunction with the HomeConnect binding to display dishwasher and washing machine status.
uid: ApplianceStatus
tags: []
props:
parameters:
label: Icon
required: false
type: TEXT
groupName: header
label: Header
required: false
type: TEXT
groupName: header
- context: item
description: select item for operation state
label: Item
required: false
type: TEXT
groupName: setup
- context: item
description: select item for active program
label: Item
required: false
type: TEXT
groupName: setup
- context: item
description: select item for remaining time
label: Item
required: false
type: TEXT
groupName: setup
- context: item
description: select item for progress
label: Item
required: false
type: TEXT
groupName: setup
- context: item
description: select item for temperature
label: Item
required: false
type: TEXT
groupName: setup
- context: item
description: select item for spinspeed
label: Item
required: false
type: TEXT
groupName: setup
parameterGroups:
- name: header
- name: setup
timestamp: Jan 8, 2023, 10:12:11 PM
component: f7-card
style:
background-color: "=items[props.operationState].state === 'Run' ? 'rgba(255, 255, 255, 1)' : 'rgba(34, 34, 34, 0.3)'"
border-radius: 15px
box-shadow: 0px 0px
margin: 5px 5px
slots:
content:
- component: f7-row
style:
slots:
default:
style:
height: 25px
margin-right: 10px
filter: '=items[props.operationState].state === "Run" ? "brightness(1)" : "brightness(0) invert(1)"'
- component: Label
style:
color: '=items[props.operationState].state === "Run" ? "black" : "white"'
- component: f7-row
style:
margin-top: 10px
margin-bottom: 10px
slots:
default:
text: =items[props.operationState].displayState
style:
background-color: "=items[props.operationState].state === 'Run' ? '#F8BB00' : '#8c8c8c'"
color: "#fff"
margin-left: 35px
font-size: 10px
height: 18px
- component: f7-row
visible: "=items[props.operationState].state === 'Run' ? true : false"
style:
slots:
default:
style:
--f7-chip-bg-color: rgba(255, 255, 255, 0)
text: =items[props.activeProgram].state
iconColor: black
iconF7: info_circle
iconSize: 17
visible: =items[props.temperature]
style:
text: =items[props.temperature].displayState
visible: =items[props.spinSpeed]
style:
text: =items[props.spinSpeed].displayState
- component: f7-row
style:
slots:
default:
style:
text: "='Resterende tijd: ' + items[props.remainingTime].state"
iconColor: black
iconF7: clock
iconSize: 17
style:
text: "='Voortgang: ' + (items[props.progress].displayState === 'undefined') ? items[props.progress].displayState : items[props.progress].displayState"
iconColor: black
iconF7: percent
iconSize: 17
Feel free to use or modify them as you wish. This weeks project: thermostat âstatusâ widget to display what my heating actor is doing (per room).
Anything to show already ?
Not yet actually⊠Iâm still thinking about what exactly to display (related to what my KNX actor has available) and how to visualize. Also I donât have airco or cooling so itâs only for heating.
Iâll also share my Main UI. It all started with the âroomâ widgets which were from the beginning of OH3 I think. Afterwards I added additional widgets for turning on lights, dimmersâŠand tried to create or modify other ones:
Main screen
Additional window when pressing the wheel on the Media widget
Example when clicking on a room:
Example of the charts pages which opens when clicking on one of the numbers in the Energy widget:
Some random widget for checking devices etc (they are all filled by items which gets their values via rules):
eye
icon in the widgets above will show all items, without my specific filter (eg I only show batteries % below 40%, I only show GitHub releases of the last 15 daysâŠ) The list
icons shows the complete content of the group without any formatting
Really beautiful solutions, congratulations! May I ask, how you realized the water consumption? I want to to do the same - but my research on water-sensors failed (resp only had solutions really expensive or complicated).
