You should mention in the published widget which type of airconditioner/binding is supported, as you are going to hardcode the speedlevels.
Intesis binding e.g uses numbers 1-4, without any Level String…
mine is Daikin AC, with Daikin Binding. actually is implemted but not working in my widget. maybe i will publish another version specific per daikin binding.
here is documented “fanspeed”:
thanks
Just rename your Widget to be Daikin AC related, no second version needed.
Doing this entirely within a widget is a little complex. There are limitations to what you can use in the widget expressions, especially when it comes to array manipulation.
First you need to get an array of the different possible levels. This is most easily achieved by having the array entered as a widget parameter. Just as with things like the item state description:
You can set up parameter to be an array of text lines with the same
value=label
format.
parameters:
- context: text
description: value=label
label: Test Array
required: false
type: TEXT
multiple: true
The key here is the multiple=true
property. This allows you to enter an array. In this case your array would just be the command list you posted above:
That the easy part. And even though it seems a like an extra step instead of hard coding the array, it means that the widget can be more general as you can use any value=label
array.
Now, here’s some sample code that then uses variables to show what the conversion from array element to both command and readable label looks like.
uid: demo:step_array
tags: []
props:
parameters:
- context: text
label: Test Array
required: false
type: TEXT
multiple: true
parameterGroups: []
component: f7-card
title: "='Readable label: ' + ((vars.arrayResult) ? props.tArray[props.tArray.join('').substring(0,props.tArray.join('').search(vars.arrayResult)).split('=').length-1].split('=')[1] : 'Push a button')"
footer: "='Command: ' + ((vars.arrayResult) ? vars.arrayResult : 'None')"
slots:
default:
- component: oh-button
action: variable
actionVariable: arrayResult
actionVariableValue: =props.tArray[Math.min(props.tArray.join('').substring(0,props.tArray.join('').search(vars.arrayResult)).split('=').length,props.tArray.length-1)].split('=')[0]
text: Next Array Element
action: variable
actionVariableValue: =props.tArray[Math.max(props.tArray.join('').substring(0,props.tArray.join('').search(vars.arrayResult)).split('=').length-2,0)].split('=')[0]
text: Prev Array Element
To convert it to send the commands to items you just have to
- Change the
oh-buttons
to use the command action instead of the variable action - Change all the
vars.arrayResult
to the state of your item
thanks a lot for your help! learnt a new thing that will come useful
but i have an issue. maybe i’m doing something wrong…
when i change this:
action: variable
into this:
action: command
actionItem: =props.set_speed_item
actionCommand: =props.tArray[Math.min(props.tArray.join('').substring(0,props.tArray.join('').search(vars.arrayResult)).split('=').length,props.tArray.length-1)].split('=')[0]
and adding in props these:
- context: text
label: Array
required: false
type: TEXT
multiple: true
- context: item
label: Set Speed
required: false
type: TEXT
and the label is configured in this way:
- component: Label
visible: "=props.set_speed_item ? true : false"
text: =items[props.set_speed_item].displayState
i’m not able to move between array elements. or better, i’m only able to move between first and second object of the array.
what i’m doing wrong?
There’s still one more vars.arrayResult
that needs to be changed over to the item state in the action Command
line.
forgot to tell, but i tried to change also that into this:
actionCommand: =props.tArray[Math.min(props.tArray.join('').substring(0,props.tArray.join('').search(props.set_speed_item)).split('=').length,props.tArray.length-1)].split('=')[0]
it switch only from AUTO to SILENCE and from SILENCE to AUTO.
it won’t read other values…this issue seems to come only when i switch from
action: variable
to
action: command
could be this the issue?
That represents only the name of the item. Not the item state. In order to get the item state, you must use items[props.set_speed_item].state
. So, that is what must go into the search method:
search(items[props.set_speed_item].state)
oh yes! from test seems to work perfectly! i will test it with real device.
thanks a lot for your support! i was near to set the right item state in code, but i missed “[ ]”. thanks a lot again!
Hey @rubenfuser,
that looks really good.
One question:
Do you have an idea how get the footer colored?
When using the inspector of Chrome, the footer seems not to be at the bottom of the widget.
Could you have a look?
Cheers, Nic
Yes i achieved that. I will post the code:
uid: Conditioner Card v2
tags:
- MadeByEvil
props:
parameters:
- description: Small title on top of the card
label: Title
required: false
type: TEXT
- description: Icon on top of the card ( only f7 icons without "f7:" )
label: Icon
required: false
type: TEXT
- description: in rgba() or HEX or empty
label: Background Color
required: false
type: TEXT
- context: item
label: Current Temperature
required: false
type: TEXT
- context: item
label: Set Temperature
required: false
type: TEXT
- context: text
label: Array
required: false
type: TEXT
multiple: true
- context: item
label: Set Speed
required: false
type: TEXT
- context: item
label: Power ON/OFF
required: false
type: TEXT
- context: item
description: Modalità item
label: Modalità
required: false
type: TEXT
- context: item
description: Trendline item
label: Trendline
required: false
type: TEXT
parameterGroups:
- name: widgetAction
context: action
label: Action
description: Action to perform when the element is clicked
timestamp: Aug 6, 2022, 4:09:55 PM
component: f7-card
style:
noShadow: false
padding: 0px
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
height: 200px
margin-left: 5px
margin-right: 5px
slots:
content:
- component: f7-block
style:
position: absolute
top: -10px
left: 10px
flex-direction: row
display: flex
slots:
default:
- component: f7-icon
f7: =props.icon
style:
margin-right: 10px
visible: "=props.icon ? true : false"
- component: Label
text: "=props.title ? props.title : ''"
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
bottom: -20px
left: 16px
flex-direction: row
slots: {}
- component: Label
text: "=items[props.temp_item].displayState ? items[props.temp_item].displayState : items[props.temp_item].state"
style:
font-size: 20px
font-weight: 400
margin-left: 0px
margin-top: 10px
color: '=items[props.temp_item].state >= "22" ? "red" : items[props.temp_item].state <= "20" ? "blue" :"white"'
visible: '=items[props.heating_item].displayState == "Pompa di calore" ? "true" : items[props.heating_item].displayState == "Condizionatore" ? "true" : "false"'
iconColor: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "yellow" : items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "red" : items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "blue" : items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "orange" : "gray"'
iconF7: arrow_up_circle
iconSize: 35
action: command
actionItem: =props.set_temp_item
actionCommand: =Number(items[props.set_temp_item].state.split(' ')[0]) + 0.5
style:
position: absolute
top: 40px
right: 0px
height: 33px
background: transparent
z-index: 98
iconF7: arrow_down_circle
iconSize: 35
action: command
actionCommand: =Number(items[props.set_temp_item].state.split(' ')[0]) - 0.5
style:
position: absolute
top: 104px
right: 0px
height: 33px
z-index: 98
- component: Label
text: '=items[props.set_temp_item].state == "UNDEF" ? " " : items[props.set_temp_item].state'
style:
font-size: 12px
position: absolute
right: 8px
top: 80px
iconSize: 35
action: command
actionCommand: =props.tArray[Math.max(props.tArray.join('').substring(0,props.tArray.join('').search(items[props.set_speed_item].state)).split('=').length-2,0)].split('=')[0]
style:
position: absolute
top: 40px
right: 40px
height: 35px
z-index: 98
iconSize: 35
action: command
actionCommand: =props.tArray[Math.min(props.tArray.join('').substring(0,props.tArray.join('').search(items[props.set_speed_item].state)).split('=').length,props.tArray.length-1)].split('=')[0]
style:
position: absolute
top: 104px
right: 40px
height: 35px
z-index: 98
- component: Label
text: "=((items[props.set_speed_item].state) ? props.tArray[props.tArray.join('').substring(0,props.tArray.join('').search(items[props.set_speed_item].state)).split('=').length-1].split('=')[1] : 'Push a button')"
style:
color: red
font-size: 12px
position: absolute
right: 58px
top: 80px
style:
position: absolute
top: 50px
left: 15px
width: "=props.set_temp_item ? 'calc(100% - 55px)' : '100%' "
height: 120px
slots:
default:
- component: oh-trend
trendItem: =props.widgettrend
trendGradient:
- "#aa2b1d"
- "#cc561e"
- "#ef8d32"
- "#beca5c"
style:
--f7-theme-color-bg-color: transparent
background: var(--f7-theme-color-bg-color)
filter: opacity(50%)
position: absolute
width: 80%
height: 100%
top: 0px
left: 15px
z-index: 98
- component: oh-toggle
item: =props.power
color: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "yellow" : items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "red" : items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "blue" : items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "orange" : "black"'
style:
--f7-toggle-height: 20px
--f7-toggle-width: 40px
font-size: 100%
top: 115px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "blue" : "black"'
iconF7: snow
iconSize: 25
action: command
actionItem: =props.heating_item
actionCommand: COOL
style:
position: absolute
top: 165px
left: 25%
height: 35px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "red" : "black"'
iconF7: flame
iconSize: 20
action: command
actionCommand: HEAT
style:
position: absolute
top: 165px
left: 45%
height: 35px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "yellow" : "black"'
iconF7: drop
iconSize: 20
action: command
actionCommand: DEHUMIDIFIER
style:
position: absolute
top: 165px
left: 65%
height: 35px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "orange" : "black"'
iconF7: wind
iconSize: 20
action: command
actionCommand: FAN
style:
position: absolute
top: 165px
left: 85%
height: 35px
z-index: 98
- component: f7-card-footer
style:
top: 84px
left: -16px
width: 110%
background: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "#ffffb3" : items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "#ffc2b3" : items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "#b3b3ff" : items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "#ffd9b3" : "#3F3F3F"'
border-radius: 0 0 var(--f7-card-expandable-border-radius) var(--f7-card-expandable-border-radius)
This is the widget but not completely finished,but you will find what you need for footer
