[ Add a primary screenshot or a logo here. The first image of the post will be promoted seen in the add-on list in the UI.]
[ Replace with your description.]
Screenshots
[ Upload other screenshots if necessary or remove the section.]
Changelog
Version 0.1
- initial release
Resources
uid: main_widget_Home_Card
tags: []
props:
parameters:
- description: Name for your weather location
label: Weather Location
required: false
type: TEXT
- context: item
description: Name of scenes group item
label: Scenes Group
required: false
type: TEXT
- context: item
description: Name of security group item
label: Security Group
required: false
type: TEXT
- context: item
description: Security Mode Item
label: Security Mode
required: true
type: TEXT
- context: item
description: Security PIN Item
label: Security PIN
required: false
type: TEXT
parameterGroups: []
component: f7-block
style:
flex: 1 1 auto
overflow: scroll
margin-top: -1em
margin-bottom: -1em
slots:
default:
- component: widget:main_widget_Weather_Card
bigCard: true
dateFormat: true
itemPrefix: OneCallAPIweatherandforecast_
locationTitle: =props.locationTitle
sunIndicator: true
visible: '=(!vars.objVar || ((vars.objVar.selectSection=="SECTION0") && !vars.objVar.selectThing)) ? true : false'
- component: oh-repeater
fetchMetadata: semantics,metadata,listWidget
for: sceneItem
groupItem: =props.scenesGroup
sourceType: itemsInGroup
slots:
default:
- component: widget:main_widget_Scene_Card
scene: =loop.sceneItem.name
sceneName: =loop.sceneItem.label
visible: '=vars.objVar ? ((vars.objVar.selectSection + vars.objVar.selectThing)=="SECTION0Scenes") ? true : false : false'
- component: widget:main_widget_Security_Card
securityGroup: =props.securityGroup
securityMode: =props.securityMode
referencePIN: =props.referencePIN
visible: '=vars.objVar ? ((vars.objVar.selectSection + vars.objVar.selectThing)=="SECTION0Security") ? true : false : false'
