[ Add a primary screenshot or a logo here. The first image of the post will be promoted seen in the add-on list in the UI.]
[ Replace with your description.]
Screenshots
[ Upload other screenshots if necessary or remove the section.]
Changelog
Version 0.2
- fixed missing label for rollershutter an radiator control
Version 0.1
- initial release
Resources
uid: main_widget_Room_Card
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
component: f7-block
visible: '=!vars.objVar ? false : !vars.objVar.selectSection=="SECTION2" ? false : !vars.objVar.selectThing ? false : true'
style:
flex: 1 1 auto
overflow: scroll
margin-top: 1em
margin-bottom: -1em
slots:
default:
- component: oh-repeater
fetchMetadata: semantics,metadata,listWidget
for: equipmentItem
sourceType: itemsWithTags
itemTags: Blinds
filter: loop.equipmentItem.metadata.semantics.config.hasLocation == vars.objVar.room
slots:
default:
filter: '(loop.shutterItem.type=="Rollershutter") ? true : false'
for: shutterItem
groupItem: =loop.equipmentItem.name
sourceType: itemsInGroup
slots:
default:
- component: widget:main_widget_Rollershutter_Card
RollerItem: =loop.shutterItem.name
Title: =loop.shutterItem.label
visible: '=vars.objVar.selectThing=="Rollers" ? true : false'
for: equipmentItem
itemTags: Lightbulb
slots:
default:
- component: widget:main_widget_Light_Card
equipmentItem: =loop.equipmentItem.name
visible: '=vars.objVar.selectThing=="Lights" ? true : false'
for: equipmentItem
itemTags: RadiatorControl
slots:
default:
- component: widget:main_widget_RadiatorControl_Card
Title: =loop.equipmentItem.label
visible: '=vars.objVar.selectThing=="Climate" ? true : false'
