[OH3] Main UI - main_widget - part 2 - The Weather Card
[:crayon: Add a primary screenshot or a logo here. The first image of the post will be promoted seen in the add-on list in the UI.]
[:crayon: Replace with your description.]
Screenshots
[:crayon: Upload other screenshots if necessary or remove the section.]
Changelog
Version 0.1
  • initial release
Resources
uid: main_widget_Weather_Card
tags: []
props:
  parameters:
    - default: OneCallAPIweatherandforecast_
      description: <b>Optional prefix</b> for item names
      label: Item prefix
      required: false
      type: TEXT
      groupName: general
    - description: <b>Additional prefix</b> for item names that belongs to another Things channel (valid for 'StationName' as it might differ)
      label: Additional item prefix
      required: false
      type: TEXT
      groupName: general
    - description: The number of hours you want to forecast (<u>default:</u> <b>12</b>)
      label: Number of hours to forecast
      required: false
      type: TEXT
      groupName: general
    - description: The number of days you want to forecast (<u>default:</u> <b>3</b>)
      label: Number of days to forecast
      required: false
      type: TEXT
      groupName: general
    - description: Show all informations at once (increases height)
      label: Big card
      required: false
      type: BOOLEAN
      groupName: lookandfeel
    - description: Use this only on screens with a very small view-width
      label: Mobile optimized
      required: false
      type: BOOLEAN
      advanced: true
    - description: Set a background-image which will be shown during the day (if empty it will fall back to the linear-gradient)
      label: Background image-url (day-cycle)
      required: false
      type: TEXT
    - description: Set a background-image which will be shown during the night (if empty it will fall back to the linear-gradient)
      label: Background image-url (night-cycle)
      required: false
      type: TEXT
    - description: Activate day & night Indication on hourly forecast (background color & sunrise / sunset indicator icon)
      label: Show sunrise & sunset
      required: false
      type: BOOLEAN
    - description: Overwrite the global font-color as rgb (<u>default:</u> <b>255,255,255<b>)
      label: Font color (rgb)
      required: false
      type: TEXT
    - description: Overwrite the global text shadow color as rgb (<u>default:</u> <b>0,0,0<b>)
      label: Text shadow color(rgb)
      required: false
      type: TEXT
    - label: Daytime background indication color
      required: false
      type: TEXT
      advanced: true
    - label: Nighttime background indication color
      required: false
      type: TEXT
      advanced: true
    - description: Overwrite the station location name
      label: Location title
      required: false
      type: TEXT
      groupName: localization
    - description: Format of the timestamp below the location-name (<u>default:</u> <b>DD. MMMM YYYY</b>)<br>Visit <a 'https://day.js.org/docs/en/display/format'>https://day.js.org/docs/en/display/format</a> for more informations.
      label: Timestamp format
      required: false
      type: TEXT
    - description: Acitvate 24-hour time-format (<u>default:</u> <b>12-hour clock-format</b>)
      label: 24h hour-format
      required: false
      type: BOOLEAN
    - description: Add suffix to the hourly-forecast timestamp
      label: Custom hour suffix
      required: false
      type: TEXT
    - label: Translation 'Feel'
      required: false
      type: TEXT
    - label: Translation 'Hourly'
      required: false
      type: TEXT
    - label: Translation 'Daily'
      required: false
      type: TEXT
    - label: Translation '%-Precipitation'
      required: false
      type: TEXT
    - label: Translation 'Now'
      required: false
      type: TEXT
    - label: Translation 'Today'
      required: false
      type: TEXT
    - label: Translation 'Sunrise at'
      required: false
      type: TEXT
    - label: Translation 'Sunset at'
      required: false
      type: TEXT
  parameterGroups:
    - name: general
      label: General settings
    - name: widgetAction
      context: action
      label: Action
      description: Action to perform when the element is clicked (<b>Experimental</b>)
    - name: lookandfeel
      label: Look & Feel
      description: Everything that influences the look & feel of the widget
    - name: localization
      label: Localization settings
      description: Set alternative wordings & date pattern
timestamp: Sep 11, 2022, 12:48:38 PM
component: f7-card
  class:
    - padding
  style:
    overflow: hidden
    height: "=(props.bigCard) ? '' : '160px'"
    -ms-user-select: none
    -moz-user-select: none
    -webkit-user-select: none
    user-select: none
    background: "=dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state ? 'linear-gradient(to bottom, #355b8e, #c0d4f0)' : 'linear-gradient(to bottom, #413D8F, #CE9FC8)'"
    border-radius: var(--weather-card-border-radius)
    --weather-card-color: "=(!props.fontColor) ? '255,255,255' : props.fontColor"
    --weather-card-text-shadow-color: "=(!props.textShadowColor) ? '0,0,0' : props.textShadowColor"
    --weather-card-text-color: rgba(var(--weather-card-color),1)
    color: var(--weather-card-text-color)
    --weather-card-border-radius: 20px
    --weather-font-size-xxsmall: 12px
    --weather-font-size-xsmall: 14px
    --weather-font-size-small: 16px
    --weather-font-size-normal: 18px
    --weather-font-size-large: 26px
    --weather-font-size-xlarge: 60px
    --weather-font-size-xxlarge: 70px
    --weather-text-shadow-light: 2px 2px rgba(var(--weather-card-text-shadow-color),.15)
    --weather-text-shadow-strong: 2px 2px rgba(var(--weather-card-text-shadow-color),.35)
    --weather-text-transform-time: uppercase
slots:
  default:
    - component: oh-link
        visible: "=props.widget_action && (vars.moreInfo === false || !vars.moreInfo) ? true : false"
        actionPropsParameterGroup: widgetAction
        color: white
        class:
          - no-padding
          - no-margin
        style:
          max-height: 192px
          width: 100%
          height: 100%
          position: absolute
          top: 0
          left: 0
          z-index: 98
    - component: f7-block
        class:
          - no-padding
          - no-margin
        style:
          background: "=dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state ? 'no-repeat 100% / cover url(' + props.backgroundUrlDay + ')' : 'no-repeat 100% / cover url(' + props.backgroundUrlNight + ')'"
          width: 100%
          height: 100%
          position: absolute
          top: 0
          left: 0
    - component: f7-row
        visible: "=(!vars.moreInfo) ? true : false"
      slots:
        default:
          - component: f7-col
              style:
                z-index: 95
            slots:
              default:
                - component: Label
                    text: "=!props.locationTitle ? items[(!props.itemPrefix2 ? (!props.itemPrefix ? '' : props.itemPrefix) : props.itemPrefix2) + 'StationName'].state : props.locationTitle"
                    style:
                      white-space: nowrap
                      overflow: hidden
                      text-overflow: ellipsis
                      letter-spacing: .75px
                      font-size: var(--weather-font-size-large)
                      text-shadow: var(--weather-text-shadow-strong)
                      font-weight: 600
                - component: Label
                    text: "=dayjs().format(props.dateScheme ? props.dateScheme : 'DD. MMMM YYYY')"
                    style:
                      white-space: nowrap
                      overflow: hidden
                      color: rgba(var(--weather-card-color),.7)
                      font-size: var(--weather-font-size-xxsmall)
                      text-shadow: var(--weather-text-shadow-light)
                - component: f7-row
                    class:
                      - align-items-center
                    style:
                      flex-wrap: nowrap
                  slots:
                    default:
                      - component: f7-icon
                          f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50n') ? 'cloud_fog_fill' : '?'"
                          style:
                            font-size: var(--weather-font-size-xxlarge)
                            padding-top: 5px
                            padding-bottom: 5px
                      - component: f7-col
                          visible: =props.mobile === true
                        slots:
                          default:
                            - component: Label
                                text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Temperature'].state.split(' ')[0] * 10) / 10 + '°'"
                                class:
                                  - padding-left
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                                  font-size: 31px
                                  line-height: 31px
                                  font-weight: 600
                            - component: Label
                                text: "=((!props.wordingFeel) ? 'Feel: ' : props.wordingFeel + ': ') + Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Apparenttemperature'].state.split(' ')[0]) + '°'"
                                class:
                                  - padding-left
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                                  font-size: var(--weather-font-size-small)
                - component: Label
                    text: "=items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Condition'].state"
                    style:
                      white-space: nowrap
                      overflow: hidden
          - component: f7-col
              visible: =!props.mobile
              class:
                - text-align-right
              style:
                align-self: "=props.bigCard ? 'flex-start' : 'flex-end'"
                z-index: 95
            slots:
              default:
                - component: Label
                    style:
                      white-space: nowrap
                      overflow: hidden
                      font-size: var(--weather-font-size-xlarge)
                      line-height: var(--weather-font-size-xlarge)
                      font-weight: 600
                - component: Label
                    style:
                      white-space: nowrap
                      overflow: hidden
                      font-size: var(--weather-font-size-normal)
                - component: f7-row
                    class:
                      - justify-content-flex-end
                    style:
                      flex-wrap: nowrap
                      font-size: var(--weather-font-size-xsmall)
                  slots:
                    default:
                      - component: Label
                          text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Humidity'].state.split(' ')[0]) + ' ' + items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Humidity'].state.split(' ')[1]"
                          tooltip: Humidity
                          style:
                            white-space: nowrap
                            overflow: hidden
                      - component: Label
                          text: =" | "
                          style:
                            color: rgba(var(--weather-card-color),.25)
                      - component: Label
                          text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Windspeed'].state.split(' ')[0]) + ' ' + items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Windspeed'].state.split(' ')[1]"
                          tooltip: Windspeed
                          style:
                            white-space: nowrap
                            overflow: hidden
    - component: oh-button
        colorTheme: white
        color: white
        iconMaterial: more_horiz
        iconSize: 20px
        action: variable
        actionVariable: moreInfo
        actionVariableValue: true
        visible: "=(props.bigCard) ? false : ((!vars.moreInfo || vars.moreInfo === false) ? true : false)"
        class:
          - margin-top
          - margin-right
        style:
          position: absolute
          top: 0
          right: 0
          font-weight: 600
          z-index: 99
        colorTheme: white
        color: white
        iconMaterial: close
        iconSize: 20px
        action: variable
        actionVariableValue: false
        visible: "=(props.bigCard) ? false : ((vars.moreInfo || vars.moreInfo === true) ? true : false)"
        class:
          - margin-top
          - margin-right
        style:
          position: absolute
          top: 0
          right: 0
          font-weight: 600
          z-index: 99
        visible: =vars.moreInfo || props.bigCard === true
        class:
          - no-padding
          - no-margin
          - align-items-space-between
      slots:
        default:
          - component: f7-segmented
              strong: true
              textColor: white
              style:
                --f7-segmented-strong-button-active-box-shadow: 0px 4px 0 -1px rgba(var(--weather-card-color),1)
                --f7-segmented-strong-button-active-text-color: rgba(var(--weather-card-color),1)
                --f7-button-text-color: rgba(var(--weather-card-color),.5)
                --f7-segmented-strong-text-color: rgba(var(--weather-card-color),.5)
                --f7-segmented-strong-padding: 3px
                --f7-button-active-text-color: rgba(var(--weather-card-color),1)
                --f7-button-raised-box-shadow: none
                --f7-segmented-strong-button-active-bg-color: transparent
                --f7-button-border-radius: 0
                width: "=(props.bigCard) ? '100%' : 'calc(100% - 38px)'"
                padding-top: "=(props.bigCard) ? '16px' : '0'"
                background: transparent
                z-index: 999
                align-items: flex-end
            slots:
              default:
                    text: "=(!props.wordingForecastHours) ? 'Hourly' : props.wordingForecastHours"
                    active: =vars.tab === 'hourly_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: hourly_forecast
                    text: "=(!props.wordingForecastDays) ? 'Daily' : props.wordingForecastDays"
                    active: =vars.tab === 'daily_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: daily_forecast
                    text: "=(!props.wordingForecastPrecib) ? '%-Precipitation' : props.wordingForecastPrecib"
                    active: =vars.tab === 'precip_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: precip_forecast
              class:
                - no-padding
              style:
                border-bottom: 4px solid rgba(var(--weather-card-color),.5)
                margin-left: 4px
                margin-right: 4px
          - component: f7-swiper
              visible: =vars.tab === 'hourly_forecast' || !vars.tab
              navigation: true
              class:
                - padding-top
              params:
                initalSlide: 0
                runCallbacksOnInit: true
                grabCursor: true
                observer: true
                observeSlideChildren: true
                updateOnWindowResize: true
                spaceBetween: 5
                mousewheel: true
                keyboard: true
                watchOverflow: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "240":
                    slidesPerView: 2
                  "320":
                    slidesPerView: 3
                  "480":
                    slidesPerView: 4
                  "640":
                    slidesPerView: 5
              style:
                --swiper-navigation-size: 30px
                --swiper-navigation-color: var(--weather-card-text-color)
            slots:
              default:
                - component: oh-repeater
                    sourceType: range
                    for: hour
                    rangeStart: 0
                    rangeStop: "=(!props.forecastHours) ? 12 : Number(props.forecastHours)"
                    fragment: true
                  slots:
                    default:
                      - component: f7-swiper-slide
                          expandable: true
                          style:
                            background: "=(props.sunIndicator) ? ((dayjs().add(loop.hour,'hour').format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state && dayjs().add(loop.hour,'hour').format() <= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state) ? (!props.sunIndicatorColorDay ? 'rgba(255,255,255,.2)' : props.sunIndicatorColorDay) : (!props.sunIndicatorColorNight ? 'rgba(41,109,152,.2)' : props.sunIndicatorColorNight)) : 'none'"
                            border-radius: 5px
                        slots:
                          default:
                                visible: "=(dayjs().add(loop.hour,'hour').startOf('hour').format() === dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).startOf('hour').format() && props.sunIndicator === true)"
                                f7: sun_max_fill
                                tooltip: "=((!props.wordingSunrise) ? 'Sunrise at ' : props.wordingSunrise + ' ') + ((!props.dateFormat) ? dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).format('h:mm A') : dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).format('H:mm') + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix) ) + '<br><b>' + dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).fromNow() + '</b>'"
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                                visible: "=(dayjs().add(loop.hour,'hour').startOf('hour').format() === dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).startOf('hour').format() && props.sunIndicator === true)"
                                f7: moon_fill
                                tooltip: "=((!props.wordingSunset) ? 'Sunset at ' : props.wordingSunset + ' ') + ((!props.dateFormat) ? dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).format('h:mm A') : dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).format('H:mm') + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix) ) + '<br><b>' + dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).fromNow() + '</b>'"
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                            - component: f7-row
                                class:
                                  - justify-content-center
                              slots:
                                default:
                                  - component: Label
                                      text: "=(loop.hour === 0) ? ((!props.wordingNow) ? 'Now' : props.wordingNow) : ((!props.dateFormat) ? dayjs().add(loop.hour,'hour').startOf('hour').format('h A') : dayjs().add(loop.hour,'hour').startOf('hour').format('H')) + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix)"
                                      style:
                                        text-transform: var(--weather-text-transform-time)
                                        font-weight: 700
                            - component: f7-col
                                class:
                                  - text-align-center
                              slots:
                                default:
                                      f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '50n') ? 'cloud_fog_fill' : '?'"
                                      style:
                                        padding-top: 5px
                                        padding-bottom: 5px
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Temperature'].state.split(' ')[0]) + '°'"
                                      style:
                                        font-weight: 400
              visible: =vars.tab === 'daily_forecast'
              navigation: true
              class:
                - padding-top
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                watchOverflow: true
                mousewheel: true
                keyboard: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "210":
                    slidesPerView: "=(!props.forecastDays) ? 2 : ((props.forecastDays < 2) ? Math.round(Number(props.forecastDays) + 1) : 2)"
                  "480":
                    slidesPerView: "=(!props.forecastDays) ? 3 : ((props.forecastDays < 3) ? Math.round(Number(props.forecastDays) + 1) : 3)"
                  "640":
                    slidesPerView: "=(!props.forecastDays) ? 4 : ((props.forecastDays < 4) ? Math.round(Number(props.forecastDays) + 1) : 4)"
              style:
            slots:
              default:
                    sourceType: range
                    for: day
                    rangeStart: 0
                    rangeStop: "=(!props.forecastDays) ? 3 : Number(props.forecastDays)"
                    fragment: true
                  slots:
                    default:
                          class: text-align-center
                        slots:
                          default:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      text: "=(loop.day === 0) ? ((!props.wordingToday) ? 'Today' : props.wordingToday) : dayjs().add(loop.day,'day').startOf('day').format('dddd')"
                                      style:
                                        font-weight: 700
                                f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '50n') ? 'cloud_fog_fill' : '?'"
                                style:
                                  padding-top: 5px
                                  padding-bottom: 5px
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + ((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + (loop.day_idx))) + '_Maxtemperature'].state.split(' ')[0])+'°'"
                                      style:
                                        font-weight: 400
                                  - component: Label
                                      text: =" | "
                                      style:
                                        color: rgba(255,255,255,.2)
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + ((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + (loop.day_idx))) + '_Mintemperature'].state.split(' ')[0])+'°'"
                                      style:
                                        font-weight: 400
              visible: =vars.tab === 'precip_forecast'
              navigation: true
              class:
                - padding-top
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                mousewheel: true
                keyboard: true
                watchOverflow: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "240":
                    slidesPerView: 2
                  "320":
                    slidesPerView: 3
                  "480":
                    slidesPerView: 4
                  "640":
                    slidesPerView: 5
              style:
            slots:
              default:
                    sourceType: range
                    for: hour
                    rangeStart: 0
                    rangeStop: "=(props.forecastHours === undefined) ? 12 : Number(props.forecastHours)"
                    fragment: true
                  slots:
                    default:
                          expandable: true
                          style:
                            border-radius: 5px
                        slots:
                          default:
                                f7: sun_max_fill
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                                f7: moon_fill
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        font-weight: 700
                            - component: f7-col
                                class:
                                  - text-align-center
                              slots:
                                default:
                                      f7: umbrella_fill
                                      style:
                                        padding-top: 5px
                                        padding-bottom: 5px
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1)) + '_Precipprobability'].state.split(' ')[0]) + '%'"
                                      style:
                                        font-weight: 400
