[OH3] Main UI - main_widget - part 4 - The Rollershutter Card [3.3.0;3.4.9)
The main_widget rollershutter card is one of the sub widgets to let you control your rollershutters with a unique look and feel.
Apart from just controling your rollershutters with sending up and down commands, you can also send predefined values like 50% to your device.
Latest version now supports to control time based opening and closing of rollershutters with the new DateTime-trigger for rules.
Installation and Setup
This widget can be installed via the marketplace. For basic operation, no configuration is needed. If you would like to have “fancy names” for your rollershutter cards, please add the uiSemantics to your Equipment groups like described here
To use the time based triggers, there eare some additional steps needed.
  • Install the timepicker widget from the marketplace.
  • You will need 5 additional items in your rollershutter equipment group, here we take the rollershutters in the childroom as an example
    • A Switch item to enable/disable the automatic/time control [mandatory]
      • Name: modeBlindsChildAuto
      • Label: Timecontrol blinds childroom
      • Type: Switch
      • Category: Switch
      • Semantic Class: Control
      • Semantic Property: Level
    • 4 DateTime items for holding the different Times, openWeekday, closeWeekday, openWeekend, closeWeekend [optional]
      • Name: openBlindsChildWeekday
      • Label: Open Blinds Child Weekdays
      • Type: DateTime
      • Category: time
      • Semantic Class: Point
      • Semantic Property: Timestamp
        Please add the following State Description (pattern) as a metadata to al 4 of those items
        • %1$tH:%1$tM
      • You will then need to add initial states to the 4 items via API-Explorer.
    • Create 4 rules for opening and closing the rollershutter [optional]
      • When : it is a daten and time specified in an item → choose item “openBlindsChildWeekday”
      • Then : Send command up to rollershutter item
      • But only if
      • Ephemeris : it is a weekday
      • If modeBlindsChildAuto = ON
      • If Rollershutter state != 0
      Codepage for the rule:
      ‘’'csv
      configuration: {}
      triggers:
    • id: “1”
      configuration:
      itemName: openBlindsChildWeek
      timeOnly: true
      type: timer.DateTimeTrigger
      conditions:
    • inputs: {}
      configuration:
      offset: 0
      type: ephemeris.WeekdayCondition
    • inputs: {}
      configuration:
      itemName: modeBlindsChildAuto
      state: ON
      operator: =
      type: core.ItemStateCondition
    • inputs: {}
      configuration:
      itemName: rollershutterChild_Control
      state: “0”
      operator: “!=”
      actions:
    • inputs: {}
      configuration:
      command: UP
      type: core.ItemCommandAction
      Repeat this for all 4 times to control.
Screenshots
[:crayon: Upload other screenshots if necessary or remove the section.]
Changelog
Version 0.5
  • minor styling update
Version 0.4
  • changed some colors for better readability in dark mode
Version 0.3
  • fixed some design issues
Version 0.2
  • added time control and uiSemantics
Version 0.1
  • initial release
Resources
uid: main_widget_Rollershutter_Card
tags: []
props:
  parameters:
    - description: Title of the card
      label: Title
      required: false
      type: TEXT
    - context: item
      description: Group to control
      label: Rollershutter Group
      required: true
      type: TEXT
    - context: item
      description: Item to control
      label: Rollershutter Item
      required: true
      type: TEXT
    - context: item
      description: Rollershutter Mode
      label: Rollershutter Mode Item
      required: true
      type: TEXT
timestamp: Nov 3, 2022, 10:16:58 PM
component: f7-block
  style:
    background: "#F7F7F7"
    border-bottom-left-radius: var(--f7-card-expandable-border-radius)
    border-bottom-right-radius: var(--f7-card-expandable-border-radius)
    border-top-left-radius: var(--f7-card-expandable-border-radius)
    border-top-right-radius: var(--f7-card-expandable-border-radius)
    box-shadow: 5px 5px 15px 1px rgba(0,0,0,0.05)
    padding: 0px
slots:
  default:
    - component: f7-block
        style:
          align-items: center
          background: transparent
          display: flex
          flex-direction: row
          height: 60px
      slots:
        default:
          - component: oh-icon
              icon: iconify:mdi:window-shutter
              style:
                margin-left: 5px
                color: rgb(106,106,106)
                padding-right: 15px
              width: 40px
          - component: f7-row
              style:
                display: flex
                flex-direction: column
                flex-wrap: nowrap
            slots:
              default:
                - component: Label
                    style:
                      align-self: flex-end
                      display: flex
                      flex: 1 1 auto
                      flex-direction: row
                      flex-wrap: nowrap
                      font-size: 14px
                      font-weight: 400
                      justify-content: flex-end
                      padding-top: 10px
                      color: black
                    text: =props.Title
                - component: f7-row
                    style:
                      display: flex
                      flex-direction: row
                  slots:
                    default:
                      - component: f7-chip
                          style:
                            background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==0) ? "#6A6A6A" : (Number(items[props.RollerItem].state.split(" ")[0])==100) ? "#6A6A6A" : "Transparent"'
                            color: '=(Number(items[props.RollerItem].state.split(" ")[0])==0) ? "white" : (Number(items[props.RollerItem].state.split(" ")[0])==100) ? "white" : "#6A6A6A"'
                            font-size: 16px
                            font-weight: 200
                          text: '=(Number(items[props.RollerItem].state.split(" ")[0])==0) ? "OPEN" : (Number(items[props.RollerItem].state.split(" ")[0])==100) ? "CLOSED" : items[props.RollerItem].displayState ? items[props.RollerItem].displayState : items[props.RollerItem].state'
          - component: f7-row
              style:
                display: flex
                flex: 1 1 auto
                flex-direction: row
                flex-wrap: nowrap
            slots:
              default:
                - component: oh-link
                    action: toggle
                    actionCommand: ON
                    actionCommandAlt: OFF
                    actionItem: =props.RollerMode
                    style:
                      display: flex
                      flex-direction: row
                  slots:
                    default:
                          icon: iconify:material-symbols:astrophotography-auto
                          style:
                            color: '=items[props.RollerMode].state=="ON" ? "green" : "gray"'
                            margin-right: 10px
                          width: 40px
        style:
          align-items: center
          display: flex
          flex-direction: row
          height: 10px
      slots:
        default:
          - component: f7-row
              style:
                margin-left: 5px
                align-self: flex-start
                display: flex
                flex: 1 1 auto
                flex-direction: row
                flex-wrap: nowrap
                justify-content: flex-start
            slots:
              default:
                - component: oh-repeater
                    fetchMetadata: semantics,metadata
                    filter: loop.openWeek.type=="DateTime" && loop.openWeek.name.includes("open") && !(loop.openWeek.name.includes("Weekend"))
                    for: openWeek
                    groupItem: =props.RollerGroup
                    sourceType: itemsInGroup
                  slots:
                    default:
                          action: popover
                          popoverOpen: ="."+loop.openWeek.name
                          style:
                            color: black
                            height: 35px
                          text: Weekday
                          visible: '=items[props.RollerMode].state=="ON" ? true : false'
                        slots:
                          default:
                                style:
                                  background-color: "#D3D3D3"
                                  color: black
                                text: =items[loop.openWeek.name].displayState
                              slots:
                                media:
                                      color: red
                                      icon: f7:chevron_up
                            - component: f7-popover
                                backdrop: false
                                class: =loop.openWeek.name
                                closeByBackdropClick: true
                                closeByOutsideClick: true
                                closeOnEscape: true
                                style:
                                  --f7-popover-border-radius: 4px
                                  --f7-popover-width: 300px
                              slots:
                                default:
                                  - component: widget:timepicker
                                      item: =loop.openWeek.name
                                      timeFormat: 24h
                    filter: loop.closeWeek.type=="DateTime" && loop.closeWeek.name.includes("close") && !(loop.closeWeek.name.includes("Weekend"))
                    for: closeWeek
                  slots:
                    default:
                          action: popover
                          popoverOpen: ="."+loop.closeWeek.name
                          style:
                            height: 35px
                        slots:
                          default:
                                style:
                                  color: black
                                text: =items[loop.closeWeek.name].displayState
                              slots:
                                media:
                                      color: red
                                      icon: f7:chevron_down
                                backdrop: false
                                class: =loop.closeWeek.name
                                closeOnEscape: true
                                style:
                              slots:
                                default:
                                      item: =loop.closeWeek.name
                                      timeFormat: 24h
          - component: f7-row
              style:
                align-items: center
                display: flex
                flex: 1 1 auto
                flex-direction: row
                margin-top: 25px
            slots:
              default:
                - component: oh-button
                    action: command
                    actionCommand: UP
                    actionItem: =props.RollerItem
                    iconColor: "#E74239"
                    iconF7: arrow_up_circle
                    iconSize: 35
                    style:
                      display: flex
                      flex-direction: row
                      flex-wrap: nowrap
                      height: 35px
                    action: command
                    actionCommand: STOP
                    iconF7: stop_circle
                    iconSize: 35
                    style:
                      display: flex
                      flex-direction: row
                      flex-wrap: nowrap
                      height: 35px
                    action: command
                    actionCommand: DOWN
                    iconF7: arrow_down_circle
                    iconSize: 35
                    style:
                      display: flex
                      flex-direction: row
                      flex-wrap: nowrap
                      height: 35px
        style:
          align-items: left
          display: flex
          flex-direction: row
          height: 15px
      slots:
        default:
          - component: f7-row
              style:
                margin-left: 5px
                display: flex
                flex: 1 1 auto
                flex-direction: row
                flex-wrap: nowrap
            slots:
              default:
                    filter: loop.openWeekend.type=="DateTime" && loop.openWeekend.name.includes("open") && (loop.openWeekend.name.includes("Weekend"))
                    for: openWeekend
                  slots:
                    default:
                          action: popover
                          popoverOpen: ="."+loop.openWeekend.name
                          style:
                            color: black
                            height: 35px
                          text: Weekend
                        slots:
                          default:
                                style:
                                  color: black
                                text: =items[loop.openWeekend.name].displayState
                              slots:
                                media:
                                      color: red
                                      icon: f7:chevron_up
                                backdrop: false
                                class: =loop.openWeekend.name
                                closeOnEscape: true
                                style:
                              slots:
                                default:
                                      item: =loop.openWeekend.name
                                      timeFormat: 24h
                    filter: loop.closeWeekend.type=="DateTime" && loop.closeWeekend.name.includes("close") && (loop.closeWeekend.name.includes("Weekend"))
                    for: closeWeekend
                  slots:
                    default:
                          action: popover
                          popoverOpen: ="."+loop.closeWeekend.name
                          style:
                            height: 35px
                        slots:
                          default:
                                style:
                                  color: black
                                text: =items[loop.closeWeekend.name].displayState
                              slots:
                                media:
                                      color: red
                                backdrop: false
                                class: =loop.closeWeekend.name
                                closeOnEscape: true
                                style:
                              slots:
                                default:
                                      item: =loop.closeWeekend.name
                                      timeFormat: 24h
        style:
          --f7-card-footer-border-color: transparent
          align-items: center
          background: "#F2F2F2"
          border-radius: 0 0 var(--f7-card-expandable-border-radius) var(--f7-card-expandable-border-radius)
          display: flex
          flex-direction: row
          height: 50px
      slots:
        default:
          - component: f7-row
              style:
                align-items: center
                display: flex
                flex: 1 1 auto
                flex-direction: row
                justify-content: space-around
            slots:
              default:
                    action: command
                    actionCommand: 20
                  slots:
                    default:
                          style:
                            color: black
                            background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==20) ? "#E74239" : "#D3D3D3"'
                          text: 20
                    action: command
                    actionCommand: 32
                  slots:
                    default:
                          style:
                            color: black
                            background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==32) ? "#E74239" : "#D3D3D3"'
                          text: 32
                    action: command
                    actionCommand: 50
                  slots:
                    default:
                          style:
                            color: black
                            background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==50) ? "#E74239" : "#D3D3D3"'
                          text: 50
                    action: command
                    actionCommand: 60
                  slots:
                    default:
                          style:
                            color: black
                            background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==60) ? "#E74239" : "#D3D3D3"'
                          text: 60
                    action: command
                    actionCommand: 80
                  slots:
                    default:
                          style:
                            color: black
                            background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==80) ? "#E74239" : "#D3D3D3"'
                          text: 80
                    action: command
                    actionCommand: 90
                  slots:
                    default:
                          style:
                            color: black
                            background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==90) ? "#E74239" : "#D3D3D3"'
                          text: 90```
Hi @hmerk:
I propose a small change to remove the repetition for the bottom row - and use a range-based repeater instead:
tags: []
props:
  parameters:
      label: Title
      required: false
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
timestamp: Nov 13, 2022, 9:57:05 PM
component: f7-block
  style:
    padding: 0px
slots:
  default:
        style:
          align-items: center
          display: flex
          flex-direction: row
          height: 60px
      slots:
        default:
              style:
                margin-left: 5px
                padding-right: 15px
              width: 40px
          - component: f7-row
              style:
                display: flex
                flex-wrap: nowrap
            slots:
              default:
                - component: Label
                    style:
                      color: black
                      display: flex
                      flex: 1 1 auto
                      flex-direction: row
                      flex-wrap: nowrap
                      font-size: 14px
                      font-weight: 400
                      padding-top: 10px
                    text: =props.Title
                - component: f7-row
                    style:
                      display: flex
                      flex-direction: row
                  slots:
                    default:
                          style:
                            font-size: 16px
                            font-weight: 200
          - component: f7-row
              style:
                display: flex
                flex: 1 1 auto
                flex-direction: row
                flex-wrap: nowrap
            slots:
              default:
                    action: toggle
                    actionCommand: ON
                    style:
                      display: flex
                      flex-direction: row
                  slots:
                    default:
                          style:
                            margin-right: 10px
                          width: 40px
        style:
          align-items: center
          display: flex
          flex-direction: row
          height: 10px
      slots:
        default:
          - component: f7-row
              style:
                display: flex
                flex: 1 1 auto
                flex-direction: row
                flex-wrap: nowrap
                margin-left: 5px
            slots:
              default:
                    for: openWeek
                  slots:
                    default:
                          action: popover
                          style:
                            color: black
                            height: 35px
                          text: Weekday
                        slots:
                          default:
                                style:
                                  color: black
                              slots:
                                media:
                                      color: red
                                      icon: f7:chevron_up
                                backdrop: false
                                closeOnEscape: true
                                style:
                              slots:
                                default:
                                      timeFormat: 24h
                    for: closeWeek
                  slots:
                    default:
                          action: popover
                          style:
                            height: 35px
                        slots:
                          default:
                                style:
                                  color: black
                              slots:
                                media:
                                      color: red
                                backdrop: false
                                closeOnEscape: true
                                style:
                              slots:
                                default:
                                      timeFormat: 24h
          - component: f7-row
              style:
                align-items: center
                display: flex
                flex: 1 1 auto
                flex-direction: row
                margin-top: 25px
            slots:
              default:
                    action: command
                    actionCommand: UP
                    iconSize: 35
                    style:
                      display: flex
                      flex-direction: row
                      flex-wrap: nowrap
                      height: 35px
                    action: command
                    actionCommand: STOP
                    iconF7: stop_circle
                    iconSize: 35
                    style:
                      display: flex
                      flex-direction: row
                      flex-wrap: nowrap
                      height: 35px
                    action: command
                    actionCommand: DOWN
                    iconSize: 35
                    style:
                      display: flex
                      flex-direction: row
                      flex-wrap: nowrap
                      height: 35px
        style:
          align-items: left
          display: flex
          flex-direction: row
          height: 15px
      slots:
        default:
          - component: f7-row
              style:
                display: flex
                flex: 1 1 auto
                flex-direction: row
                flex-wrap: nowrap
                margin-left: 5px
            slots:
              default:
                    for: openWeekend
                  slots:
                    default:
                          action: popover
                          style:
                            color: black
                            height: 35px
                          text: Weekend
                        slots:
                          default:
                                style:
                                  color: black
                              slots:
                                media:
                                      color: red
                                      icon: f7:chevron_up
                                backdrop: false
                                closeOnEscape: true
                                style:
                              slots:
                                default:
                                      timeFormat: 24h
                    for: closeWeekend
                  slots:
                    default:
                          action: popover
                          style:
                            height: 35px
                        slots:
                          default:
                                style:
                                  color: black
                              slots:
                                media:
                                      color: red
                                backdrop: false
                                closeOnEscape: true
                                style:
                              slots:
                                default:
                                      timeFormat: 24h
        style:
          align-items: center
          display: flex
          flex-direction: row
          height: 50px
      slots:
        default:
          - component: f7-row
              style:
                align-items: center
                display: flex
                flex: 1 1 auto
                flex-direction: row
            slots:
              default:
                    sourceType: array
                    for: buttonLabel
                    in: ["20","32","50","60","80"]
                    fragment: true
                  slots:
                    default:
                          action: command
                          actionCommand: =loop.buttonLabel
                        slots:
                          default:
                                style:
                                  background-color: '=(Number(items[props.RollerItem].state.split(" ")[0])==loop.buttonLabel) ? "#E74239" : "#D3D3D3"'
                                  color: black
                                text: =loop.buttonLabel
Nice, reduces some lines of code.
Will check later.
Good to hear, that you like it.
Your widgets are really great :slight_smile:
Thanks, but the kudos go to the team, I am just one part of it.
Hello Hans-Jörg,
I am using your widget right now, thank you very much for that.
I tried to use 4 rules for all shutters grouping the DateTime items.
However, it turns out the DateTime groups can not be used as a trigger:
Do you have an idea how to make this more elegant to combine some rules?
Marco
Please let‘s move discussion to development topic, will answer there.
Hi Jörg,
found your widget. Looks great. One questions for my understanding.
For what do I need the RollerGroup?
I thought that one card belongs to one rollershutter?
Hi Thorsten,
Thanks, great you like it.
We need the group cause it will also hold the 4 DateTime Items for the schedules and the Switch Item for enabling/disabling the schedules.
Hi Hans-Jörg,
no I have some questions about getting it to work.
I have installed the timepicker, created the group , and the date-time items.
I also set initila state with the rest api.
But I will not show everything on the run-mode screen.
Here you will see pictures from the run-mode, from the development view, and the config.
So what is missing that the items with the time is not shown on the run view?
I did not create the rules. Is it that?
The rules will run at scheduled tim, so without them, DateTime Items don‘t make sense.
Please show us your Item definitions.
Edit: Is the switch item set to ON? If not, items are not shown.
OK, thanks. It was the switch. Set it to off,because have not created the rules.
For those, who like textual rules.
I had issues with the rules created in Paper UI. After a restart the rules were not triggered anymore.
Textual rules do not have this issue.
rule "Rolllaeden runter Wochentags"
	Time is closeBlindsWeekday timeOnly
  if (Ephemeris.isWeekend() == false && SwitchTimeControlRollladen.state == ON) {
        Rollaeden.sendCommand(DOWN)
Thanks for sharing
This is a different issue, disabling and reenabling makes them work again.
