[OH3] Main UI - main_widget - Part 8 - The HVAC Card
[:crayon: Add a primary screenshot or a logo here. The first image of the post will be promoted seen in the add-on list in the UI.]
The HVAC widget card used by main_widget will show all kind of HVAC (air conditioner) equipment in a selected room and show controlls based on equipment group members.
Usage
All radiator controls need to have their own Group (Group->Equipment->HVAC ).
  • Equipment Group
    • Type: Group
    • Category: climate (not used)
    • Semantic Class: HVAC
  • Power / Switch Item
    • Type: Switch
    • Category: switch (not used)
    • Semantic Class: Control
    • Semantic Class: Power
  • Ambient Temperature
    • Type: Number or Number:Temperature
    • Category: temperature (not used)
    • Semantic Class: Measurement
    • Semantic Class: Temperature
  • Target Temperature
    • Semantic Class: Setpoint
  • Operation Mode
    • Type: String or Number
    • Category: temperature_cold (not used)
  • Fanspeed
    • Category: qualityofservice
    • Semantic Class: Wind
  • Vane Position
    • Category: movecontrol
Control Mode, Fanspeed and Vane Position use Item options. More Information with example for different thermostats will follow.
For a „fancy“ naming, the widget makes use of the uiSemantics.
Information on usage/configuration can be founde here
Changelog
Version 0.1
  • initial release
Resources
uid: main_widget_HVAC_Card
tags: []
props:
  parameters:
    - default: test
      description: Title of the card
      label: Title
      required: false
      type: TEXT
    - context: item
      description: HVAC Equipment Group
      label: HVAC Equipment Group
      required: false
      type: TEXT
    - context: item
      description: HVAC Power Item
      label: HVAC Power Item
      required: false
      type: TEXT
    - context: item
      description: HVAC Mode Item
      label: HVAC Mode Item
      required: false
      type: TEXT
timestamp: Nov 3, 2022, 10:55:42 PM
component: f7-block
  style:
    background: RGB(247, 247, 247)
    border-bottom-left-radius: var(--f7-card-expandable-border-radius)
    border-bottom-right-radius: var(--f7-card-expandable-border-radius)
    border-top-left-radius: var(--f7-card-expandable-border-radius)
    border-top-right-radius: var(--f7-card-expandable-border-radius)
    box-shadow: 5px 5px 15px 1px rgba(0,0,0,0.05)
    padding: 0px
slots:
  default:
    - component: f7-block
        style:
          align-items: center
          display: flex
          flex-direction: row
          height: 60px
      slots:
        default:
          - component: oh-icon
              icon: iconify:iconoir:air-conditioner
              style:
                margin-left: 5px
                color: rgb(106,106,106)
                padding-right: 15px
              width: 40px
          - component: f7-row
              style:
                display: flex
                flex-direction: column
                flex-wrap: nowrap
                padding-top: 10px
            slots:
              default:
                - component: Label
                    text: =props.Title
                - component: f7-row
                    style:
                      display: flex
                      flex-direction: row
                  slots:
                    default:
                      - component: oh-repeater
                          fetchMetadata: semantics,metadata,listWidget
                          filter: "(loop.tempItem.groupNames.indexOf(props.groupItem) >= 0) ? true : false"
                          for: tempItem
                          itemTags: Measurement,Temperature
                          sourceType: itemsWithTags
                        slots:
                          default:
                            - component: f7-chip
                                style:
                                  font-weight: 500
                                  justify-content: flex-end
                                text: =items[loop.tempItem.name].state
                          filter: "(loop.setpointItem.groupNames.indexOf(props.groupItem) >= 0) ? true : false"
                          for: setpointItem
                          itemTags: Setpoint,Temperature
                        slots:
                          default:
                                style:
                                  background: none
                                  color: '=(items[props.modeItem].state=="COOL") ? "#15B4B7" : (items[props.modeItem].state=="HEAT") ? "#E74239" : (items[props.modeItem].state=="DRY") ? "#E7D200" : "gray"'
                                  font-weight: 500
                                text: =items[loop.setpointItem.name].state
          - component: f7-row
              style:
                align-self: flex-end
                display: flex
                flex: 1 1 auto
                flex-direction: row
                flex-wrap: nowrap
            slots:
              default:
                - component: oh-toggle
                    item: =props.powerItem
                    style:
                      --f7-toggle-active-color: =(items[props.modeItem].state=="COOL")?"#15B4B7":(items[props.modeItem].state=="HEAT")?"#E74239":(items[props.modeItem].state=="DRY")?"#E7D200":"gray"
                      --f7-toggle-inactive-color: gray
        style:
          align-items: center
          display: flex
          flex-direction: row
        visible: =items[props.powerItem].state=="ON"
      slots:
        default:
              for: tempItem
            slots:
              default:
                - component: oh-trend
                    trendGradient: =[(items[props.modeItem].state=='COOL')?('#15B4B7'):(items[props.modeItem].state=='HEAT')?('#E74239'):(items[props.modeItem].state=='DRY')?('#E7D200'):('gray'),('gray')]
                    trendItem: =loop.tempItem.name
                    trendSampling: 5
          - component: f7-row
              style:
                display: flex
                flex-direction: row
                flex-wrap: nowrap
            slots:
              default:
                - component: oh-link
                    action: command
                    actionCommand: =Number(items[loop.setpointItem.name].state.split(' ')[0]) + 0.5
                    actionItem: =loop.setpointItem.name
                  slots:
                    default:
                          icon: f7:arrow_up_circle
                          style:
                          width: 35px
                    action: command
                    actionCommand: =Number(items[loop.setpointItem.name].state.split(' ')[0]) 1 0.5
                  slots:
                    default:
                          icon: f7:arrow_down_circle
                          style:
                            margin-left: 20px
                          width: 35px
        style:
          --f7-card-footer-border-color: transparent
          align-items: center
          background: RGB(242, 242, 242)
          border-radius: 0 0 var(--f7-card-expandable-border-radius) var(--f7-card-expandable-border-radius)
          display: flex
          flex-direction: row
          flex-wrap: nowrap
          height: 50px
      slots:
        default:
              action: command
              actionCommand: COOL
              actionItem: =props.modeItem
            slots:
              default:
                    color: '=(items[props.modeItem].state=="COOL") ? "#15B4B7" : "gray"'
                    icon: iconify:ion:snow
                    width: 25px
              action: command
              actionCommand: HEAT
              style:
                margin-left: 25px
            slots:
              default:
                    color: '=(items[props.modeItem].state=="HEAT") ? "#E74239" : "gray"'
                    icon: iconify:ion:flame-sharp
                    width: 25px
              action: command
              actionCommand: DRY
              style:
                margin-left: 25px
            slots:
              default:
                    color: '=(items[props.modeItem].state=="DRY") ? "#E7D200" : "gray"'
                    icon: iconify:material-symbols:cool-to-dry-rounded
                    width: 25px
              filter: "(loop.fanspeedItem.groupNames.indexOf(props.groupItem) >= 0) ? true : false"
              for: fanspeedItem
              itemTags: Control,Wind
            slots:
              default:
                    action: options
                    actionItem: =loop.fanspeedItem.name
                    style:
                      margin-left: 120px
                  slots:
                    default:
                          text: "=items[loop.fanspeedItem.name].displayState ? items[loop.fanspeedItem.name].displayState : items[loop.fanspeedItem.name].state"
                          color: gray
                          icon: iconify:material-symbols:mode-fan
                          width: 25px
              filter: "(loop.vanesItem.groupNames.indexOf(props.groupItem) >= 0) ? true : false"
              for: vanesItem
              itemTags: Control,Opening
            slots:
              default:
                    action: options
                    actionItem: =loop.vanesItem.name
                    style:
                      margin-left: 20px
                  slots:
                    default:
                          text: "=items[loop.vanesItem.name].displayState ? items[loop.vanesItem.name].displayState : items[loop.vanesItem.name].state"
                          color: gray
                          icon: f7:move
                          width: 25px
