It started as another widget from someone else, i have made changes, added gradient background. changed styling and added colour options. Along with being able to set the main item, which will control all things. toggle, slider, colour and stepper.
But you can individually set each components item if you wish.
I have the toggle controlling the wall switch which turns on the light.
Then i have the slider and colour controlling those channels for the bulb itself.
uid: darkLiquid_card
tags:
- small
- dark
- custom
- liquid
props:
parameters:
- label: Headline text
required: false
type: TEXT
groupName: header
- label: Subheadline text
required: false
type: TEXT
groupName: header
- context: item
description: Set an item which you want to control
label: Item
required: false
type: TEXT
groupName: general
- description: Show state of the item
label: Show state
required: false
type: BOOLEAN
groupName: general
- description: The value symbol shown after the item-value
label: Value symbol
required: false
type: TEXT
groupName: general
- description: valueSymbol high or low
label: Value symbol position
required: false
type: BOOLEAN
groupName: general
advanced: true
- description: Set the lowest value, that your item can have. (<b>default:</b> 0)
label: Items MIN value
required: false
type: TEXT
groupName: general
- description: Set the highest value, that your item can have. (<b>default:</b> 100)
label: Items MAX value
required: false
type: TEXT
groupName: general
- description: Show trend graph instead of liquid background
label: Trend graph
required: false
type: BOOLEAN
groupName: general
- label: Icon image url
required: false
type: TEXT
groupName: images
- description: Activating Stepper element to control item which you selected above
label: Show stepper buttons
required: false
type: BOOLEAN
groupName: controls
- context: item
label: Stepper Item
required: false
type: TEXT
groupName: controls
- description: Activating Toggle element to control item which you selected above
label: Show toggle
required: false
type: BOOLEAN
groupName: controls
- context: item
label: Toggle Item
required: false
type: TEXT
groupName: controls
- description: Activating Slider element to control item which you selected above
label: Show slider
required: false
type: BOOLEAN
groupName: controls
- context: item
label: Slider Item
required: false
type: TEXT
groupName: controls
- description: Activating Colour element to control item which you selected above
label: Show colour
required: false
type: BOOLEAN
groupName: controls
- context: item
label: Colour Item
required: false
type: TEXT
groupName: controls
parameterGroups:
- name: header
label: Header area
- name: general
label: General settings
description: Most important widget settings
- name: controls
label: Control settings
description: Controls to manipulate your item-state (only use one of them)
- name: images
label: Images
timestamp: Jan 21, 2021, 7:50:03 PM
component: f7-block
style:
position: relative
-ms-user-select: None
-moz-user-select: None
-webkit-user-select: None
user-select: None
class:
- no-padding
- no-margin
slots:
default:
- component: oh-image
url: "=props.heroIcon ? props.heroIcon : ''"
style:
position: absolute
top: -5px
left: -10px
width: 100%
max-width: min(max(50px, 15vw), 80px)
z-index: 99
- component: f7-card
outline: true
style:
max-height: 200px
border-radius: 20px
overflow: hidden
position: relative
background-image: url('https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQLycUzU8qMBcjTUr6NyLvwa-zlDsycKy7Ajg&usqp=CAU')
background-repeat: no-repeat
background-size: 100%
background-color: black
background-blend-mode: lighten
slots:
default:
- component: f7-card-content
style:
height: 100%
display: flex
flex-direction: column
position: relative
z-index: 999
slots:
default:
- component: f7-row
style:
z-index: 999
slots:
default:
- component: f7-col
slots:
default:
- component: Label
propsParameterGroup: header
text: '=(props.headline) ? props.headline : ""'
style:
position: relative
left: 30px
white-space: nowrap
text-overflow: ellipsis
overflow: hidden
display: block
width: 80%
color: rgba(255,255,255,1)
letter-spacing: .75px
font-size: min(max(70px, 4vw), 25px)
font-weight: 600
- component: Label
actionPropsParameterGroup: header
text: '=(props.subheadline) ? props.subheadline : ""'
style:
position: relative
left: 30px
white-space: nowrap
overflow: hidden
color: rgba(255,255,255,.7)
font-size: min(max(50px, 2.5vw), 15px)
- component: oh-icon
class: '=props.showColour ? props.showColour : "display-none"'
icon: colorlight
action: group
actionGroupPopupItem: "=(props.colouritem) ? props.colouritem : props.item "
style:
height: min(max(30px, 2.5vw), 40px)
position: absolute
--f7-button-bg-color: ='hsl(' + items.ZigbeeTallLoungeLamp_Colour.state.split(",") [0] + ', ' + items.ZigbeeTallLoungeLamp_Colour.state.split(",") [1] + '%, 70%)'
right: 20px
top: 20px
z-index: 999
- component: f7-row
style:
z-index: 999
slots:
default:
- component: f7-col
width: 100
class: '=props.valueSymbolPos ? props.valueSymbolPos : "align-items-flex-end"'
style:
display: flex
justify-content: flex-start
position: relative
slots:
default:
- component: Label
text: "=(items[props.item].displayState) ? items[props.item].displayState : items[props.item].state"
class: '=props.showState ? props.showState : "display-none"'
style:
text-shadow: 2px 2px rgba(0,0,0,.25)
font-size: 20px
font-weight: 600
- component: Label
text: =props.valueSymbol
style:
font-size: 20px
font-weight: 600
- component: f7-row
style:
padding-top: 10px
padding-bottom: 10px
slots:
default:
- component: f7-col
class: justify-content-flex-end
style:
max-height: 28px
display: flex
padding-bottom: 8px
slots:
default:
- component: oh-stepper
class: '=props.showStepper ? props.showStepper : "display-none"'
raised: true
buttonsOnly: true
small: true
autorepeat: true
min: =props.minValue
max: =props.maxValue
step: 4
color: white
style:
margin-right: 20px
item: "=(props.stepperitem) ? props.stepperitem : props.item "
- component: oh-toggle
color: white
class: '=props.showToggle ? props.showToggle : "display-none"'
item: "=(props.toggleitem) ? props.toggleitem : props.item "
style:
right: 10px
--f7-toggle-handle-color: rgba(255,255,255,1)
--f7-toggle-inactive-color: rgba(255,255,255,0.2)
- component: f7-row
slots:
default:
- component: f7-col
class: justify-content-flex-start
slots:
default:
- component: oh-slider
color: white
class: '=props.showSlider ? props.showSlider : "display-none"'
step: "1"
item: "=(props.slideritem) ? props.slideritem : props.item "
style:
margin-left: 10px
width: calc(100% - 20px)
--f7-range-bar-size: 18px
--f7-range-bar-border-radius: 10px
--f7-range-knob-size: 25px
--f7-range-bar-bg-color: rgba(255,255,255,0.2)
--f7-range-bar-active-bg-color: linear-gradient(to right, rgba(255,255,255,0), rgba(255,255,255,0.8))
--f7-range-knob-box-shadow: 0 2px 4px rgba(0, 0, 0, 0.3)
- component: oh-trend
visible: "=props.showTrend ? true : false"
trendItem: =props.item
trendGradient:
- "#FFE7DD"
- "#FFD1BD"
style:
position: absolute
bottom: 0
left: 0
width: 100%
height: 100%
opacity: 0.4
