Hi, is it possible to switch between Light and Dark mode in the Main UI depending on an item state? I have a wall display. I want to use dark mode when it is dark and light mode during the day.
I don’t know if that’s possible but my understanding is if you set the dark mode to auto it will get the light/dark mode from the system. So is it possible to have your device change between light and dark mode itself? Newer Android versions have that option in settings. If the display is running something else I can’t help but at least you might have a path to look towards a solution.
I am also looking for this feature. The theme will not change automatically with the device theme unless you reload the page. At least that’s how it is on my android…
It would be cool to switch it with an item!
I think it should be possible to add that to the app. Maybe you could create a ticket?
