So I have a UI page with 10 stepper widgets to control the heating valve opening. They are being pooled by the backnet binding and that works perfectly. Some external controler does the valve control. So my openhab UI is mainly to view, but I used steppers to be able to manualy intervene . The steppers have a step set 5% to click less.
Now what happens when I open a layout page is that this widget immediately without being asked sends commands to the valve controller rounding up all the values to the 5 % step
Why , can that be prevented.
All items have autoupdate set to false.
2021-10-22 15:52:48.873 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_07_Postriscaldo_valve' changed from 28.999996185302734 to 32.99999237060547
2021-10-22 15:53:47.689 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_07_Postriscaldo_valve' changed from 32.99999237060547 to 28.999996185302734
2021-10-22 15:54:26.682 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Archive_01_Postriscaldo_valve' received command 15
2021-10-22 15:54:26.711 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Archive_03_Postriscaldo_valve' received command 45
2021-10-22 15:54:26.715 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Archive_06_Postriscaldo_valve' received command 40
2021-10-22 15:54:26.719 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Archive_05_Postriscaldo_valve' received command 55
2021-10-22 15:54:26.723 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Archive_04_Postriscaldo_valve' received command 30
2021-10-22 15:54:26.743 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Archive_07_Postriscaldo_valve' received command 30
2021-10-22 15:54:26.746 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Archive_08_Postriscaldo_valve' received command 30
2021-10-22 15:54:27.139 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_08_Postriscaldo_valve' changed from 31.34918212890625 to 30
2021-10-22 15:54:27.268 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_04_Postriscaldo_valve' changed from 31.55527114868164 to 30
2021-10-22 15:54:27.277 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_05_Postriscaldo_valve' changed from 55.667686462402344 to 55
2021-10-22 15:54:28.360 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_03_Postriscaldo_valve' changed from 46.23613357543945 to 45
2021-10-22 15:54:28.472 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_01_Postriscaldo_valve' changed from 14.28384780883789 to 15
2021-10-22 15:54:28.716 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_06_Postriscaldo_valve' changed from 42.02766418457031 to 40
2021-10-22 15:54:28.797 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_07_Postriscaldo_valve' changed from 28.999996185302734 to 30
2021-10-22 15:56:18.168 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Archive_02_Postriscaldo_valve' changed from 40.268898010253906 to 35.768890380859375
