I am on OH3.2. I am wondering whether the following code on Widget only works if the next navigated page appears on Side Bar? If so, is this intended or it is a bug? Thank you
I don’t recall ever seeing this behavior, but it has been a long time since I’ve been on 3.2. it is certainly not the case anymore; the navigate action should be completely independent of the sidebar visibility status.
Honestly, without knowing what the content of your props.targetPage is, it is impossible to say whether it is an old bug in 3.2 or whether you are just not formatting the value of the actionPage property properly.
actionPage is selected from a drop-down list on widget configuration in page design. It is unlikely formatting or typo error. Anyway, will try a later release and see how.
