- openHABian 3.3.0 on rPi4 4GB
I have a rule migrated from OH2, modified to fit the OH3 calls; however, it throws a script error as it feels like. It runs for a few days without an error, and then has a day where it throws an error.
The rule runs to completion.
The error is:
2022-12-05 11:26:11.091 [INFO ] [.core.model.script.Irrigation1.07.07] - ... Valve 4 deltaVolume is.............. 48
2022-12-05 11:26:11.098 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'irrigation1-8' failed: null in irrigation1
2022-12-05 11:26:25.061 [INFO ] [.core.model.script.Irrigation1.06.11] - Irrigation1: group finished.
This is the rule:
rule "Irrigation 1: Irrigation valves OFF"
Member of gIrrigation1 received command OFF
// figure out which valve was shut OFF
// e.g. Irrigation1_1
val nameParts = triggeringItem.name.split('_')
val valveNumber = nameParts.get(1)
val valveFlow = PumpStation1_Flow.state as Number
val pumpMeter = PumpStation1_Meter.state as Number
// subtract the memorised meter reading at valve ON event
// from the current meter reading
val valveVolume = pumpMeter - g_MemoriseMeterRead
// ----- update valve flow
// get current flow rate from irrigation controller as update via MQTT;
// should be reflective of mean at end of valve duration
// and send flow rate for this session to item
if (PUBLISH == 1) mqttActions.publishMQTT(mqttTopicRoot + "Flow" + valveNumber, valveFlow.toString)
if (DEBUG == 2)
logInfo(logPrefix + "80", "... Valve {} is now OFF - flow was....... {}", valveNumber, valveFlow.toString)
// ----- update volumes
// send valve volume to valve volume item for site map display
// we are updating the item via MQTT! Why? Why not postUpdate()?
if (PUBLISH == 1) mqttActions.publishMQTT(mqttTopicRoot + "Volume" + valveNumber, valveVolume.toString)
if (DEBUG == 1)
logInfo(logPrefix + "07.01", "... Valve {} volume is................... {}", valveNumber, valveVolume.toString)
// 20210429 added on the suspicion of things not updating fast enough
Thread::sleep(500)
if (DEBUG == 1)
logInfo(logPrefix + "07.02", "... Valve {} volume is (after delay)..... {}", valveNumber, valveVolume.toString)
// update SessionMemory by ading this valve's volume to it
var sessionMemory = (PumpStation1_LastSessionMemory.state as Number) + valveVolume
if (DEBUG == 1)
logInfo(logPrefix + "07.03", "... new sessionMemory is (prev+current). {}", sessionMemory)
PumpStation1_LastSessionMemory.postUpdate(sessionMemory)
Thread::sleep(500)
if (DEBUG == 1)
logInfo(logPrefix + "07.04", "... updated LastSessionMemory is (=83).. {}", PumpStation1_LastSessionMemory.state.toString)
// check for valve volume out of tolerance and send email
// e.g. Irrigation1_1_BaseVolume
// build the item name
// next line from https://community.openhab.org/t/rules-dsl-get-item-from-string-name/48279
val baseVolumeItem = ScriptServiceUtil.getItemRegistry.getItem("Irrigation1_" + valveNumber + "_BaseVolume") as GenericItem
// e.g. 320
val baseVolume = (baseVolumeItem.state as Number).intValue
// e.g. -22 = 298 - 320
val deltaVolume = valveVolume.intValue - baseVolume
if (DEBUG == 1)
logInfo(logPrefix + "07.05", "... Valve {} baseVolume is set to........ {}", valveNumber, baseVolume)
logInfo(logPrefix + "07.06", "... Valve {} valveVolume is.............. {}", valveNumber, valveVolume.intValue)
logInfo(logPrefix + "07.07", "... Valve {} deltaVolume is.............. {}", valveNumber, deltaVolume)
// e.g. 15 litres plus/minus
val toleranceVolume = (PumpStation1_ToleranceVolume.state as Number).intValue
// Generate email message
var mailSubject = "OH3 Irrigation1: Valve " + valveNumber + " is " + Math::abs(deltaVolume)
if (Math::abs(deltaVolume) > toleranceVolume)
if (deltaVolume > 0)
mailSubject = mailSubject + " litres more"
else
mailSubject = mailSubject + " litres less"
mailSubject = mailSubject + " than the baseline of " + baseVolume + " litres."
mailActions.sendMail(
emailToMax,
mailSubject,
"Please check sprinklers attached to valve " + valveNumber + "..."
Now, before I get grief for this weird item update via MQTT; I thought about it today, Why I would do such a thing. The only answer I could come up with was: I did back then (not even today) figure out how to build an item name.
This rule is switching off a number of valves.
Any hints appreciated.
