Hallo, need Help OH3
tried to set up Heating Modbus Gateway:
Following OH3 error:
Slave Bridge/Thing = “Online”, Poller Thing = “Error”, Data Thing = “no online Bridge”
Error with read: org.openhab.core.io.transport.modbus.internal.ModbusSlaveErrorResponseExceptionImpl: Slave responsed with error=10
Same Error config via Gui o. Textfile
Code:
/******************************OH3 - Haus2 - Heizung-Zentrale - Regin ExoDos - IP: 192.168.10.xxx - Login: Pw: ***********************/
Bridge modbus:tcp:slaveHz2 “Modbus slaveHz2” [ host=“192.168.10.xxx”, port=502, id=7 ] {
//C=00001-
Bridge poller slaveHz2C "Poller slaveHz2_C" [ start=0, length=1, refresh=1000, type="coil" ] {
Thing data slaveHz2C1 "Data slaveHz2_C1" [ readStart="0", readValueType="bit", readType="coil", writeStart="0", writeValueType="bit", writeType="coil" ]
// DI=10001-
Bridge poller slaveHz2DI "Poller slaveHz2_DI" [ start=0, length=1, refresh=1000, type="discrete" ] {
Thing data slaveHz2DI1 "Data slaveHz2_DI1" [ readStart="0", readValueType="bit", readType="discrete"]
// HR=40001-
Bridge poller slaveHz2HR "Poller slaveHz2_HR" [ start=0, length=1, refresh=1000, type="holding" ] {
Thing data slaveHz2HR1 "Data slaveHz2_HR1" [ readStart="0", readValueType="uint8", readType="holding" , writeStart="0", writeValueType="uint8", writeType="holding" ] // index Pos.GanzZahl daher uint8
//IR=30001-
Bridge poller slaveHz2IR "Poller slaveHz2_IR" [ start=0, length=1, refresh=1000, type="input" ] {
Thing data slaveHz2IR1 "Data slaveHz2_IR1"[ readStart="0", readValueType="uint8", readType="input" ] // index Pos.GanzZahl daher uint8
