Sometimes after a restart of OpenHab 3.0 the topics of one MQTT Things are not cā¦orrectly subscribed. I can send MQTT commands out from OpenHab, but updates to the topics are not reflected to the items. When this happens I can always find a specific error in the OpenHab log which seems to be related to the HomeAssistant handler, but it affects a generic MQTT Thing. Before the update to OpenHab 3.0 I did not have this problem. I've also reported this in the community forum: https://community.openhab.org/t/oh3-mqtt-somtimes-issues-after-starting/113104
When I try to disable and re-enable the generic MQTT Thing in the UI I also get the error `java.lang.ClassNotFoundException: org.slf4j.LoggerFactory` in the UI. My Things are configured via the UI and the Items with files. I have 13 MQTT Things and 2 brokers in total with a mix of Homeassistant, Homie and generic MQTT Things. The one that often fails after a restart also has a lot of channels. (69 in total) I've also created [this issue](https://github.com/openhab/openhab-addons/issues/9711) about a different warning that I get after every start regarding an HomeAssistant (ESPHome) Thing.
The only way to solve the problem at the moment is to restart OpenHab again, maybe even twice until the error in the log does not appear anymore. Below you can see the log and the Thing config of the generic Thing with a lot of channels.
## OpenHab Log
2021-01-05 23:34:39.028 [WARN ] [org.openhab.core.internal.common.WrappedScheduledExecutorService ] - Scheduled runnable ended with an exception:
at org.openhab.binding.mqtt.generic.MqttChannelTypeProvider.derive(MqttChannelTypeProvider.java:132) ~[?:?]
at org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery.publishResults(HomeAssistantDiscovery.java:197) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
## Generic MQTT Thing config
UID: mqtt:topic:zigbee2mqtt_local
label: zigbee2mqtt lokal
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:4ce1d806
channels:
- id: group_all_color
channelTypeUID: mqtt:colorHSB
label: Gruppe Alle Farbe
description: null
configuration:
transformationPatternOut: JS:zigbee2mqtt_color_to_json.js
commandTopic: zigbee2mqtt/group_all/set
stateTopic: zigbee2mqtt/group_all
transformationPattern: JS:zigbee2mqtt_json_to_color.js
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_pc_color
label: Gruppe PC Zimmer Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_pc/set
stateTopic: zigbee2mqtt/group_pc
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_kitchen_color
label: Gruppe KĆ¼che Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_kitchen/set
stateTopic: zigbee2mqtt/group_kitchen
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_bedroom_color
label: Gruppe Schlafzimmer Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_bedroom/set
stateTopic: zigbee2mqtt/group_bedroom
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_bathroom_color
label: Gruppe Badezimmer Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_bathroom/set
stateTopic: zigbee2mqtt/group_bathroom
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_livingroom_color
label: Gruppe Wohnzimmer Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_livingroom/set
stateTopic: zigbee2mqtt/group_livingroom
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_livingroom_front_color
label: Gruppe Wohnzimmer vorne Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_livingroom_front/set
stateTopic: zigbee2mqtt/group_livingroom_front
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_livingroom_back_color
label: Gruppe Wohnzimmer hinten Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_livingroom_back/set
stateTopic: zigbee2mqtt/group_livingroom_back
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: group_livingroom_standing_color
label: Gruppe Wohnzimmer Stehlampen Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/group_livingroom_standing/set
stateTopic: zigbee2mqtt/group_livingroom_standing
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: pc_1_color
label: PC Zimmer 1 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/pc_1/set
stateTopic: zigbee2mqtt/pc_1
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: pc_1_temperature
channelTypeUID: mqtt:dimmer
label: PC Zimmer 1 Temperatur
description: null
configuration:
transformationPatternOut: JS:zigbee2mqtt_dimmer_to_temp.js
transformationPattern: JS:zigbee2mqtt_temp_to_dimmer.js
- id: pc_2_color
label: PC Zimmer 2 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/pc_2/set
stateTopic: zigbee2mqtt/pc_2
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: pc_2_temperature
label: PC Zimmer 2 Temperatur
description: null
configuration:
- id: pc_3_color
label: PC Zimmer 3 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/pc_3/set
stateTopic: zigbee2mqtt/pc_3
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: pc_3_temperature
label: PC Zimmer 3 Temperatur
description: null
configuration:
- id: pc_4_color
label: PC Zimmer 4 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/pc_4/set
stateTopic: zigbee2mqtt/pc_4
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: pc_4_temperature
label: PC Zimmer 4 Temperatur
description: null
configuration:
- id: kitchen_1_color
label: KĆ¼che 1 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/kitchen_1/set
stateTopic: zigbee2mqtt/kitchen_1
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: kitchen_1_temperature
label: KĆ¼che 1 Temperatur
description: null
configuration:
- id: kitchen_2_color
label: KĆ¼che 2 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/kitchen_2/set
stateTopic: zigbee2mqtt/kitchen_2
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: kitchen_2_temperature
label: KĆ¼che 2 Temperatur
description: null
configuration:
- id: kitchen_3_color
label: KĆ¼che 3 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/kitchen_3/set
stateTopic: zigbee2mqtt/kitchen_3
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: kitchen_3_temperature
label: KĆ¼che 3 Temperatur
description: null
configuration:
- id: kitchen_4_color
label: KĆ¼che 4 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/kitchen_4/set
stateTopic: zigbee2mqtt/kitchen_4
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: kitchen_4_temperature
label: KĆ¼che 4 Temperatur
description: null
configuration:
- id: kitchen_5_color
label: KĆ¼che 5 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/kitchen_5/set
stateTopic: zigbee2mqtt/kitchen_5
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: kitchen_5_temperature
label: KĆ¼che 5 Temperatur
description: null
configuration:
- id: kitchen_bar_color
label: KĆ¼che Bar Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/kitchen_bar/set
stateTopic: zigbee2mqtt/kitchen_bar
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bedroom_1_color
label: Schlafzimmer 1 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bedroom_1/set
stateTopic: zigbee2mqtt/bedroom_1
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bedroom_1_temperature
label: Schlafzimmer 1 Temperatur
description: null
configuration:
- id: bedroom_2_color
label: Schlafzimmer 2 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bedroom_2/set
stateTopic: zigbee2mqtt/bedroom_2
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bedroom_2_temperature
label: Schlafzimmer 2 Temperatur
description: null
configuration:
- id: bedroom_3_color
label: Schlafzimmer 3 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bedroom_3/set
stateTopic: zigbee2mqtt/bedroom_3
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bedroom_3_temperature
label: Schlafzimmer 3 Temperatur
description: null
configuration:
- id: bedroom_4_color
label: Schlafzimmer 4 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bedroom_4/set
stateTopic: zigbee2mqtt/bedroom_4
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bedroom_4_temperature
label: Schlafzimmer 4 Temperatur
description: null
configuration:
- id: bedroom_5_color
label: Schlafzimmer 5 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bedroom_5/set
stateTopic: zigbee2mqtt/bedroom_5
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bedroom_5_temperature
label: Schlafzimmer 5 Temperatur
description: null
configuration:
- id: bedroom_6_color
label: Schlafzimmer 6 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bedroom_6/set
stateTopic: zigbee2mqtt/bedroom_6
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bedroom_6_temperature
label: Schlafzimmer 6 Temperatur
description: null
configuration:
- id: bedroom_table_color
label: Schlafzimmer Nachttisch Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bedroom_table/set
stateTopic: zigbee2mqtt/bedroom_table
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_front_1_color
label: Wohnzimmer vorne 1 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_front_1/set
stateTopic: zigbee2mqtt/livingroom_front_1
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_front_1_temperature
label: Wohnzimmer vorne 1 Temperatur
description: null
configuration:
- id: livingroom_front_2_color
label: Wohnzimmer vorne 2 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_front_2/set
stateTopic: zigbee2mqtt/livingroom_front_2
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_front_2_temperature
label: Wohnzimmer vorne 2 Temperatur
description: null
configuration:
- id: livingroom_front_3_color
label: Wohnzimmer vorne 3 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_front_3/set
stateTopic: zigbee2mqtt/livingroom_front_3
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_front_3_temperature
label: Wohnzimmer vorne 3 Temperatur
description: null
configuration:
- id: livingroom_front_top_color
label: Wohnzimmer vorne oben Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_front_top/set
stateTopic: zigbee2mqtt/livingroom_front_top
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_front_top_temperature
label: Wohnzimmer vorne oben Temperatur
description: null
configuration:
- id: livingroom_front_left_color
label: Wohnzimmer vorne links Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_front_left/set
stateTopic: zigbee2mqtt/livingroom_front_left
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_front_right_color
label: Wohnzimmer vorne rechts Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_front_right/set
stateTopic: zigbee2mqtt/livingroom_front_right
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_back_1_color
label: Wohnzimmer hinten 1 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_back_1/set
stateTopic: zigbee2mqtt/livingroom_back_1
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_back_1_temperature
label: Wohnzimmer hinten 1 Temperatur
description: null
configuration:
- id: livingroom_back_2_color
label: Wohnzimmer hinten 2 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_back_2/set
stateTopic: zigbee2mqtt/livingroom_back_2
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_back_2_temperature
label: Wohnzimmer hinten 2 Temperatur
description: null
configuration:
- id: livingroom_back_3_color
label: Wohnzimmer hinten 3 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_back_3/set
stateTopic: zigbee2mqtt/livingroom_back_3
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_back_3_temperature
label: Wohnzimmer hinten 3 Temperatur
description: null
configuration:
- id: livingroom_back_top_color
label: Wohnzimmer hinten oben Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_back_top/set
stateTopic: zigbee2mqtt/livingroom_back_top
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_back_top_temperature
label: Wohnzimmer hinten oben Temperatur
description: null
configuration:
- id: livingroom_back_left_color
label: Wohnzimmer hinten links Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_back_left/set
stateTopic: zigbee2mqtt/livingroom_back_left
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: livingroom_back_right_color
label: Wohnzimmer hinten rechts Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/livingroom_back_right/set
stateTopic: zigbee2mqtt/livingroom_back_right
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bathroom_1_color
label: Badezimmer 1 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bathroom_1/set
stateTopic: zigbee2mqtt/bathroom_1
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bathroom_1_temperature
label: Badezimmer 1 Temperatur
description: null
configuration:
- id: bathroom_2_color
label: Badezimmer 2 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bathroom_2/set
stateTopic: zigbee2mqtt/bathroom_2
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bathroom_2_temperature
label: Badezimmer 2 Temperatur
description: null
configuration:
- id: bathroom_3_color
label: Badezimmer 3 Farbe
description: null
configuration:
commandTopic: zigbee2mqtt/bathroom_3/set
stateTopic: zigbee2mqtt/bathroom_3
off: 42,46,0
onBrightness: 100
on: 42,46,100
- id: bathroom_3_temperature
label: Badezimmer 3 Temperatur
description: null
configuration:
- id: huetap_1
channelTypeUID: mqtt:string
label: Hue Tap 1
description: null
configuration:
stateTopic: zigbee2mqtt/huetap_1
transformationPattern: JSONPATH:$.action
- id: huetap_2
label: Hue Tap 2
description: null
configuration:
stateTopic: zigbee2mqtt/huetap_2
## Your Environment
OpenHab 3.0 running on Rasperry Pi 4 (OpenHabian)
I hope those infos are sufficient to analyze the problem.
