I’m using OH2.5 and everything is working great. Now i was on the way to setup OH3 on new machine.
It seems like there is no Binding for Nuki, or I’m doing wrong?
Greetings
Sebastian
Greetings
Sebastian
Hi Sebastian,
there is a Nuki binding:
I’m using it and it is working as before in OH2.5.
Where are you looking?
Bob
Hi Bob,
thank you for the fast replay. You are right… i installed it, and was to fast looking for it, and now i recognized, that the “List” not showing installed Addons.
Have you managed to install the Nuki with all functionalities?
Hi Patrick,
not sure what you mean with “all functionalities” but I have it up and running and no problems so far.
I mean with lock, unlock, unlatch, Google Home connection and the respective settings etc.
I read a couple of times that’s important to have callbacks setup in order to save battery etc.
Does this makes sense?
Regards
Hi Patrick,
lock, unlock, unlatch etc. work. Google home connection I can’t tell. You can let the binding manage callbacks, that works for me.
What you don’t get is battery percentage (only low battery switch) - I think the Nuki guys said it would draw too much power to poll it…
I have to say I’m using the Nuki Hardware bridge, the android bridge seems to be a little less reliable as I read in the forum…
Thanks for the info. I also use the bridge.
Would you mind to share the integration code?
